Kodak ps50 software
waloshin2015
waloshin2015 Regular Member • Posts: 451
Kodak ps50 software
I own a Kodak ps50 I originally bought it for Mac but would like to use on windows. Unfortunately the usb dongle and software is still $300 usd for this vintage scanner and Vuescan does not support it. Any other software that does?
 waloshin2015's gear list:waloshin2015's gear list
Nikon D600 Fujifilm X-E2S
bmoag Senior Member • Posts: 2,137
Re: Kodak ps50 software
If you have the software and dongle for use with an Apple computer you might want to consider learning how to dual boot/hackintosh if you do not have a suitable Apple machine. Most likely the Kodak software is limited to an older version of OSX.
Another approach which may or may not work would be to run the needed version of OSX in a virtual machine under Windows. It is easy to install OSX in the free version of Virtual Box if you follow the instructions available on several web sites. If the scanner worked under those conditions you would have to find a way to export the scans (e.g. save to an external drive).
Unless you need to scan stacks of images it might be easier just to get a Windows compatible flatbed scanner--that would cost a lot less than $300.
 bmoag's gear list:bmoag's gear list
Canon EOS Rebel T7i Nikon Z6
