Re: Why does my pictures look different in lightroom and photoshop?
e73 wrote:
Thank you all for your help, most kind of you! I realize now that it's the "wide color gamut" on my new monitor that got me confused. Now when I've aware of that I guess I kind find a way to work around it. Howewwah, I guess I have to decide if I should prepare my images for wide color gamut monitors or for plain sRGB monitors. Personally, I'm not all that picky, for me sRGB works just fine. I don't do much printing etc. and when I do, I'm perfectly happy with the sRGB color quality.
Thanx again / Mattias
You do not need prepare images in any specific way for viewing on a wide color monitor.
You need do the 3 things I said in my reply.
You can make the images still in sRGB.
Your "problem" was you were viewing your images in non color-managed apps (specifically Windows Photos) on a wide-gamut monitor set to its native gamut. Being non color-managed means those apps take the file RGB numbers and either assume an sRGB monitor response, or else put the file RGB numbers to the graphics card direct. What you need do is use only color-managed apps which do the translation of the file RGB numbers to the actual measured color response of the monitor (means they use the profile built by your Spyder5 device's software(*)) - and this is true even if the monitor is itself regular nominal sRGB.
The only real needed fix is always use color-managed apps on a profiled monitor - that is what you should do and indeed should already have been doing, even with your previous monitor.
If you want, you can put your new monitor locally (on its own menus) into sRGB mode and then profile it and continue to use it that way, but if you do that you would not be able to see the richer colors in (for example) Adobe RGB images. An sRGB image viewed through a color-managed app on a wide-color monitor profiled in its wider native space will look exactly as it should.
Summary is - stop using Windows Photos! Find another similar color-managed image viewer. Also use a color-managed browsers (some social media sites strip the profile from images uploaded, but let's not go to that detail - as that was not your problem as you described it - FB for example uses its own lighweight sRGB-like image profile).
(*) I do not know if you can vary it in the Express software, but build an ICC version 2 profile for your monitor as that is compatible with more apps.
