Some recent images from the Caribbean (Roatan)
Started Oct 16, 2019 | Discussions
PHXAZCRAIG
PHXAZCRAIG Forum Pro • Posts: 19,651
During a two-week 34-dive trip I somehow ended up rating almost 500 shots as 4-stars, but I'm now cutting those down!   Been working through post-processing them all on my large monitors and fixing a lot of post-processing issues.
Images were taken with a Nikon D850 in a Nauticam housing.  Dual or single YS-D1 strobes.  (One of my strobes failed the first week so a lot of shots are single strobe).  Lenses were 105vr behind flat port of 16-35vr behind 230mm dome port with 90mm extension and Sea and Sea Internal Correction Lens.
Here are some I like.
Star Horseshoe Worm - one of many
I like the various colors you find in anemones
Banded Coral Shrimp - one of many
Magnificent Feather Duster
Common Octopus eat the divemaster's lunch.
Florida Corralimorphs
Looking up inside Calvin's Crack
A cluster of Painted Tunicates
Christmas Tree Worm detail
Queen Angelfish
Yellowhead Jawfish
Now I need to make a second pass through all the shots to cull a few more and to make white balance more consistent between shots in sequences.
Phoenix Arizona Craig
www.cjcphoto.net
"In theory, practice and theory are the same. In practice, they're not."
Nikon D80 Nikon D200 Nikon D300 Nikon D700 Nikon 1 V1 +45 more
Nikon D850
daveco2
daveco2 Contributing Member • Posts: 953
Re: Some recent images from the Caribbean (Roatan)
Excellent.  Now, we need to see the 3 stars.
 daveco2's gear list:daveco2's gear list
Sony RX100 Sony a7R II Sony a7R III
PHXAZCRAIG
OP PHXAZCRAIG Forum Pro • Posts: 19,651
I've got something like 490 4-stars at the moment...   I'm going through the 3-stars now, elevating a few, eliminating more.
www.cjcphoto.net
PHXAZCRAIG
Here are some 3-stars
I up-rated these after doing some work on them.
www.cjcphoto.net
daveco2
Re: Here are some 3-stars
Amazing spot-on focus.  Are these autofocus only or with manual (or position) tweak, what we would call DMF on a Sony system?
What's that green crook thing across your finger?
PHXAZCRAIG
If an image is out of focus, I almost always delete it immediately, unless it has very compelling subjects.  (Like the fish chamber).
I never hooked up the focus ring for the 105vr.  Spot autofocus only, and it's seriously good and seriously better than the D810.
For the 16-35vr, I have the zoom ring hooked up, which means there is no manual focus possible.  (Only one control for zooming or focusing).
I assume you mean the Wire Coral across divemaster David's finger.  And a Wire Shrimp on the Wire Coral as well.
Wire Shrimp are actually too small for the 105vr.   All the shots are heavy crops. It needs a magnifying diopter/wet lens attached, and then it would be quite challenging to find the target, focus on it (Wire Shrimp move very quickly when they want.  It's like trying to focus on fruit flies buzzing around in moonlight).   Wire Coral has the characteristic of a) growing at depth and b) extending horizontally out from a vertical wall.   This means when I'm taking a shot of a Wire Shrimp, I'm entirely floating and controlling my buoyancy while trying to frame, focus and shoot.   It makes simple shots of little critters more rewarding when they come out well.
www.cjcphoto.net
Hector1959 Forum Member • Posts: 50
Nice shots. Superb
