Dust alert system on K5IIs
Started Oct 14, 2019 | Discussions
puttin
puttin Veteran Member • Posts: 7,958
This is a handy feature to see the dust on the sensor. Odd that it's not on my K1 II since it is a top end camera.
 puttin's gear list:puttin's gear list
Nikon Coolpix A Canon G9 X II Nikon D3 Sony Alpha NEX-7 Sony a7 II +25 more
Pentax K-1 II
Oiche Senior Member • Posts: 2,045
Re: Dust alert system on K5IIs
Not a necessary feature as all you have to do is point the camera at a frame wide bright surface, for example, the sky overcast or blue and select f16 or the like to show up anything stuck so the sensor.
 Oiche's gear list:Oiche's gear list
Pentax K-70 Pentax smc DA* 60-250mm F4.0 ED (IF) SDM Pentax smc DA 40mm F2.8 Limited Samyang 14mm F2.8 ED AS IF UMC HD Pentax DA 15mm F4 ED AL Limited +1 more
puttin
OP puttin Veteran Member • Posts: 7,958
That's what I normally do but thought the dust alert was a handy  feature. I had a K3 but don't recall if it had that.
I personally see no need for it as your eyes soon tell you. There is no way I'd not notice dust on the sensor and I had to clean it regularly as I changed prime lenses too often in the field.
Maybe you don't post process where you really see dust, dirt or pollen. I use nothing but RAW and PP every image on a 24" photography monitor but I can see dirt when looking at the LCD on the camera.
andrew britten Senior Member • Posts: 1,495
The K3 does have it, but can give spurious results. I believe this what made them stop featuring it.
From personal experience it is a reasonable guide, but lacks accuracy from cleaning to cleaning.
AB
 andrew britten's gear list:andrew britten's gear list
Pentax K10D Pentax K-7 Pentax K-x Pentax K-5 Pentax K-01 +2 more
