would the Sony RX100 V be a bad option for underwater ?
Started Oct 8, 2019 | Discussions
pingalep Junior Member • Posts: 45
Re: would the Sony RX100 V be a bad option for underwater ?
can you suggest me the cheapest but safe underwater enclosure for an rx100 v?
also what kind of flash do you suggest? or led lights? is there an underwater enclosure for cobra flashes so i can use the in slave mode?(flashes are controlled by radio godox remote ft16)
thank you!
Barmaglot_07 Contributing Member • Posts: 633
SeaFrogs RX100 Salted Line costs $297 with a basic flat port and gives you access to all the controls, fitting RX100 models III through VII. You can add a macro port with 67mm threads to use wet lenses, or a dome for over/under splits. A vacuum valve + pump kit is another $120. I've been using the equivalent for A6xxx series cameras for over a year now without issues.
Inon S-2000 and Sea & Sea YS-01 are the entry level options; Inon Z-330 and Sea & Sea YS-D2 give you more power for wide-angle shots, but cost (and weigh) a lot more. Housing land strobes is generally more trouble than it's worth - it's clunky, you can't use radio triggering (sea water absorbs RF) so you need fiber optics and they tend to lack power and beam width compared to dedicated underwater units.
LED lights can be used for still photography, but only at very close range (a foot or so), and xenon strobes give much better results. Constant bright lights also tend to scare away mobile critters.
 Barmaglot_07's gear list:Barmaglot_07's gear list
Sony a6300 Canon EF-S 60mm f/2.8 Macro USM Sony E 30mm F3.5 Macro Sony E 18-200mm F3.5-6.3 OSS LE Sony E 10-18mm F4 OSS +5 more
Reefdiver Forum Member • Posts: 56
I had RX100iv in Fantasea housing with Fantasea wet macro lens and dual Sealife sea dragon strobes. You can take great pictures with this moderately priced setup, including  macro. Oh, and Sony gives you free post processing software Capture One.
Biggest problem for me was it was an entry level drug to the much more expensive interchangeable lens cameras!
Aquadrone
Aquadrone Forum Member • Posts: 85
Not, if you have this bad boy with different ports.
https://seafrogs.com.hk/collections/rx1xx-salted-line
 Aquadrone's gear list:Aquadrone's gear list
Sony RX100 III Sony RX100 IV Olympus TG-5 Sony RX100 VI Sony RX100 VA +15 more
