First draft of external ML battery power -
Started Oct 7, 2019 | Discussions
Max Iso
OP Max Iso Veteran Member • Posts: 8,652
Re: who moved this thread ?
Nathaniel Stephan wrote:
Max Iso wrote:
i think it's simpler to just use the dummy battery and get a power bank with DC out, and not worry about my USB port getting ripped out.
Don't buy a sealed battery bank. They all have cheap 18650 cells in them. When they're tested, the capacity will not be close to what the battery bank is advertised as.
As soon as one of the cells goes bad, the entire battery bank will no longer work.
Instead, get a battery bank that allows you to use your own 18650 cells. Used cells are easy to harvest from laptop batteries or power tool battery packs. The price will come out to about $1/cell.
Harvesting used cells is popular with people that make their own power walls and e-bikes.
Then get a battery analyzer, like the LiitoKala Lii-500. With a battery analyzer, you'll be able to find out the exact capacity of every cell you have. This will also help you find the bad cells if you harvest used cells.
Funny you mention those bc i had seen the packs last week to house them. 3.7v right? The housing fitted two which worked out to a perfect 7.4v. The only problem was they were only up to 5kmAh if i remember, about the same capacity as 3 OEM camera batteries for my G9.
So banks are not accurate? Can they legally do that? Isn't it possible they just have 2 in series and then two sets of that in parallel for double capacity? Or 3 sets for triple? I have a pair of 16750mAh RavPower banks and they charge a phone at least 3 times and have charge left, that puts them well over 10k right?
"Some by force and some by choice
In time you all shall leave me
I do not fear to be alone
Solitary, I will atone...." -
 Max Iso's gear list:Max Iso's gear list
Nikon D300 Olympus E-M1 II Canon EOS M50 Canon EF 100mm f/2.0 USM Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +8 more
(unknown member) Forum Pro • Posts: 19,317
my stand arrived yesterday heres my studio set up because i have a smaller zoom so i can move in quickly for head shots
Olympus EM5mk2 ,EM1mk2
http://www.dpreview.com/galleries/9412035244
past toys. k100d, k10d,k7,fz5,fz150,500uz,canon G9, Olympus xz1 em5mk1
Nathaniel Stephan New Member • Posts: 2
Li-Ion batteries generally have a 3.7v nominal voltage. Most 18650 batteries have a maximum capacity of 2,200mAh to 2,2600mAh.
The largest capacity batteries are going to top out around 2,900mAh. They'll be made by Panasonic, LG, or Samsung.
If the enclosure can only hold 2 18650 cells, it is impossible to have a capacity of 5kmAh.
To get to a nominal 7.4v, the cells need to be in series. Every additional cell in series will increase the voltage, but not the capacity.
As an example, say you have 2 18650 cells with 2,500 mAh capacities. If you put them in series to get to 7.4v, you'll only have 2,500 mAh. To increase that, you'll need to add cells in parallel.
Who is in charge of checking to make sure advertised capacities are correct?
I tested a bunch on Sony NP-FW50 batteries, and it was laughable what some third party "manufacturers" tried to get away with. They were at 2/3 to 1/2 the capacity advertised.
After cutting the plastic housing off, the cells inside were labeled at what I would have expected to see based on the testing.
Yes, you could have a 2S3P (2 in series, 3 in parallel), 4S10P (4 is series, 10 in parallel), or other configuration.
Reading a primer or watching intro videos on DIY power walls or e-Bikes will be quite helpful to you. Learning the basics is easy. By doing that you'll have an easier time getting a solution that's good for you, as well as being reliable.
The 2 RavPower batteries I tested were close enough to their advertised capacity that I would be fine buying their batteries in the future.
16750mAh / 2250mAh = 7.44
16750mAh / 2500mAh = 6.7
If your power bank looks like it can hold 6-8 18650 cells, the rating is likely close to accurate.
However, you need to keep in mind the voltage you plan to use. The battery bank is likely rated at 3.7v.
To get to the 5v required for USB charging, a boost converter is used. It isn't perfectly efficient, and you can tell this because it will give off heat.
If you double the voltage requirement to get to a nominal 7.2v, the 16750mAh would be cut down to 8,375mAh, before you take into account the loss from using a boost converter.
Patxitron New Member • Posts: 1
Re: First draft of external ML battery power -
Max Iso wrote:
I already have a pair of 16kmAh power banks and they are fairly solid, similar in weight to one of my flashes with batteries installed. My plan is to go even bigger (maybe a 25kmAh to 50kmAh model) when i decide the final design but that weight isn't something i want on top causing so much imbalance.
The use of "kilo" and "mili" units together hurts my eyes. Even the use of the "mili" for figures of more than one thousand seems wrong to me.
Whats wrong in write 16Ah instead of 16kmAh?
