Max Iso
First draft of external ML battery power -
Oct 7, 2019
Discussion has been around for years of course, even before ML was around other cameras needed more power for long duration video. I just want something more than the typical ML battery will offer so a few years ago i started looking. Today i decided to move forward and get a full working setup going.
Attached to my G9 i have a cheap $7 walmart USB pack with 6700mAh, a 5v-9v converter cable, and a G9 dummy battery with DC input. The dummy battery is in the grip and i can keep the internal battery in place for more juice total. This power bank is a cheapo and after voltage conversion offers about 4500mAh, giving just over 6000 total in this setup, but it gives a 2A output which is what matters. It's all mounted on a metal K-Tec shoe plate.
Of course this setup is ugly and messy as i didn't work out a pretty scheme for the wires since i won't be using them long term. In the near future i'll pick up a power bank that has a DC out jack to hook straight to the dummy battery. For now this is a working prototype for me showing others the idea in case they haven't seen it before.
For anybody looking to try, make sure you have between a 7-9 volt and at least 1.5 amp charge. I have used a 1 amp phone wall plug (with the 5-9v converter) just to see what happens, it works for single stills shooting but when i shot burst or video, the camera instantly powered off as the power draw was over 1A (it's something like .8 or .9 amps for single stills.
Feel free to show or share your setup if you use one or have suggestions, here's a few pics as is the first go.
When i eventually choose my permanent power bank, it will likely be much larger capacity (they go up over 50,000mAh) so it might not be attached at the top, i'll have to see when i get there. Even with the Olympus 75, this setup isn't very heavy, it's considerably lighter than my D300 with grip and plastic macro lens.
Looking forward to tinkering and seeing what i can do with this.
"Teach me how to sacrifice
I'm told that I don't know a thing
But maybe with some time alone
We'll both learn what it means
I feel as though I owe you more
Than just these words of gratitude you read
So before it ends, my friend
I'll teach you how to, bleed...." -
