New iPadOS makes iPad Pro a Sony image-processing beast for travel
Started Oct 7, 2019 | Discussions
SigZero
SigZero Regular Member • Posts: 492
Re: New iPadOS makes iPad Pro a Sony image-processing beast for travel
W3PYF wrote:
SigZero wrote:
W3PYF wrote:
I am shooting an A7III.
Remember - there is iOS 13.1.2 for the iPad, released on 9/24, and iPadOS 13.1.2 released the same day. Are you SURE you have the iPadOS version?
You may be right - the issue may be Apple can’t read your ARW files.
And yes, Apple has enhanced the editing tools in the latest iOS - for both iPhone and iPad. The combination of the latest iOS and the iPhone 11 Pro Max is really wonderful. For the first time, I have a lot of confidence in using an iPhone as a serious camera.
The update from iOS 12.x to iPad OS 13.x on iPad is automatic and goes through exactly the same process as older updates.
Currently iPad OS 13.x cannot read A7RIV RAW files - the same with Mac OS Catlina. No support yet.
There is another limitation - current version of Lightroom Mobile for iPad cannot import files directly from attached storage or camera. Have to move them via iPad's storage.
Br, Pawel.
"There is another limitation - current version of Lightroom Mobile for iPad cannot import files directly from attached storage or camera. Have to move them via iPad's storage."
Not true at all with iPadOS. iPadOS loads them directly into Lightroom Mobile from an attached hard drive. All you do is click on the ARW (or JPG) file on your hard drive that you see in the Files app that you want to load into Lightroom Mobile, click the upward arrow-box at upper right of the screen, and select LR Mobile. It then offers you the choice "next time you open Lightroom" or "open Lightroom now."
I swear you guys have a different iPadOS than I do.
But this is limited to 10 files at once.
The option to insert into LRM directly all files from a card is to copy to local storage and then open in Lightroom. It's Adobe time to fix LRM so that it can use file import natively (currently in LRM file menu there is no external storage)
Br, Pawel.
My photo-blog: http://pawel.online
 SigZero's gear list:SigZero's gear list
Sony FE 85mm F1.8 Sony FE 100-400mm F4.5-5.6 Sony FE 24-105mm F4 Sony a7R IV Apple iPhone 11 Pro
macautio Contributing Member • Posts: 596
Hello
Can i use iPad Pro 2 (lightning connect)
markku
 macautio's gear list:macautio's gear list
Sony a9 II Sony a7S III Sony 1.4x Teleconverter Sony FE 90mm F2.8 macro Sony FE 85mm F1.4 GM +6 more
LarryRC Contributing Member • Posts: 726
Br, Pawel.
i have the same iOS as the OP.  There is only one iOS 13+ for the iPad and it is now called iPad os.
and yes I can also load directly into Lightroom mobile from an attached hard drive or from photos on the iPad.  I also love the new slide over and multitasking.  While multitasking isn’t new it is much better able to select which background app to slide it for example.  Enjoy
 LarryRC's gear list:LarryRC's gear list
Sony a7R IV Sony FE 100-400mm F4.5-5.6 Sony FE 12-24mm F4 Tamron 28-75mm F2.8 III Sony FE 600mm F4
W3PYF
OP W3PYF Contributing Member • Posts: 907
macautio wrote:
Hello
Yes!
 W3PYF's gear list:W3PYF's gear list
Olympus C-2100 UZ Sony a6000 Sony a7 II Sony a7 III Leica Summicron-M 50mm f/2 +15 more
Laslo Varadi
Laslo Varadi Veteran Member • Posts: 5,560
Re: a9 to Ipad
Thanks Larry, i will try it.
 Laslo Varadi's gear list:Laslo Varadi's gear list
Sony a7R IV Sony a9 II Sony 1.4x Teleconverter Sony FE 28mm F2 Sony FE 70-200mm F2.8 GM OSS +3 more
DigiSage
DigiSage Regular Member • Posts: 131
sunny16day wrote:
When I bought my phone, apple phones didn't offer USB 3.1. They've had ports which theoretically support those speeds but when you test them, they operated at USB 2 speeds. I'm not sure if this is still the case (it was last year) but I imagine it is.
This hasn’t been true for years, especially not for USB-C enabled iPad Pros.
 DigiSage's gear list:DigiSage's gear list
Sony a7R III Sony FE 35mm F2.8 Sony FE 24-70mm F2.8 GM Sony FE 85mm F1.4 GM Sony FE 100-400mm F4.5-5.6 +4 more
I’m not sure I understand these comments, however, I don’t get anywhere near USB-C speeds when connecting an A7r iii or iv directly between the camera and iPadPro 11 (latest version) with iOS 12 or 13 (latest version) with a usb c cable. Nor when using a usb-c sdxc card reader plugged into the iPad. In either case I am getting approximately usb 2 speeds. This is with Sony tough 300 mb/s cards giving me around 60 mb/s read speeds. The same card plugged into a Mac transfers much faster. I’m not sure what the bottleneck is.
Having said that I agree with the OP that the iPadPro is a beast and is handling large files well once they are on the iPad.  While I can’t edit raw A7r iv files yet the unopened jpgs are around 60 mb unopened and are editable basically in real time in photos and lr.
Thank you
I must try it
markku
PWPhotography Forum Pro • Posts: 10,775
Thanks for info.
I am still deciding the choice between my iPad Pro 2018 and 13" MBP/r.  So far I had only carried latter.  MBP/r although heavier but directly read and backup SD cards and has full Mac OS X power to process photos in trips in full version of Lr.  Or at least allow me to sort some photos in the FastRAWViewer before returning home for further processing.  But I can see iPad advantage in much lighter weight when I already carrying overweighted camera gear
 PWPhotography's gear list:PWPhotography's gear list
Canon EOS-1D Mark III Sony a9 Sony a7R III Sony a7R IV Canon EF 15mm f/2.8 Fisheye +18 more
jmophotos Regular Member • Posts: 253
Re: New iPadOS - 2016 9.7" iPad Pro
Is anyone doing this with the 2016 9.7" iPad Pro ?
Thanks.
 jmophotos's gear list:jmophotos's gear list
Sony a7 III Sony FE 35mm F2.8 Sony FE 85mm F1.8
