Pen F users - some quick questions...
Started Oct 5, 2019 | Discussions
Ben Herrmann
Ben Herrmann Forum Pro • Posts: 21,163
Hey gang...
I've always been a Pen user - love the format - so lately I've been getting stressed a bit when I found out that Olympus would no longer be making this line. So last week I purchased the Pen F at B&H. I already have the E-P5 and E-PL7.
My questions are these - and I know they are simple and right in front of my eyes, but I can't seem to find the information:
1. I want to shoot in RAW only, but the only choices I have in the menu structure are either JPG or RAW & JPG. What am I missing here - no setting for RAW only?
2. I was messing around with the settings this morning and I had the IS enabled in the menu. I'm using the Panny 12-60 on my Pen F. After adjust settings to my liking (or so I thought), all of a sudden the ability for me to turn on the IS is now blanked out?  I have the lens-based IS turned off since the 5 Axs version in the Pen F is better.  What other setting(s) that I may have adjusted affects the ability to access IS settings?
Thanking you in advance...
Ben
Best of luck and health to you all!
Bernd ("Ben") Werner Herrmann
Fuquay Varina, North Carolina USA
 Ben Herrmann's gear list:Ben Herrmann's gear list
Canon EOS M Fujifilm X-E2S Fujifilm X-T2 Fujifilm X-T20 Canon EOS M6 +4 more
Olympus E-PL7 Olympus PEN E-P5 Olympus PEN-F
Ben Herrmann
OP Ben Herrmann Forum Pro • Posts: 21,163
I had to do a camera reset...
...to enable all of those functions - so never mind, I figured it out.
Day Hiker Forum Pro • Posts: 10,829
Enjoy that camera, Ben
Ben Herrmann wrote:
Hey gang...
Enjoy that Pen F, Ben. It's a darling.
Get the Olympus OEM grip.
Forget CAF. Really. Don't even bother.
Watch out for focus accuracy with the Olympus f/1.2 Pro primes wide open (my experience). I bought an OM-D E-M1.2 specifically to better-utilize my 25mm f/1.2 Pro wide open. The number of keepers I get now has skyrocketed.
I generally reserve my Pen F for my small primes now: 12mm f/2, 25mm f/1.4, 45mm f/1.8 and then the Oly 12-40mm f/2.8. I plan to pick up a Lumix 20mm f/1.7 soon.
Jim Pilcher
Summit County, Colorado, USA
Don’t trust anyone under 9100 feet
Ben Herrmann
Thanks...
When I read the factoid about Olympus discontinuing the Pen series, I was really let down, and I hadn't planned on getting the Pen F (after all, I still had the E-P5 and E-PL7).  But the more I read about the Pen F, the more I realized that it was an investment also.
Heck, I just sold off a bunch of cameras and refreshed my Fuji X series line of cameras.  I wasn't planning on getting the Pen F at all - but as they say, "stuff happens."
(unknown member) Forum Pro • Posts: 47,805
Re: Pen F users - some quick questions...
Ben Herrmann wrote:
Hey gang...
There is a RAW only - but not in the dial JPEG modes. There you can shoot RAW but you will get a JPEG.
To me this is an unnecessary increase in complexity Olympus is doing because it breaks consistency.
Set the camera to no special profile JPEG mode to shoot RAW. You can convert the RAWS in camera to the film simulation JPEGS if you want once you done it that way.
I think the issue is that you have the camera set to "let the lens do the OIS when available." Then in that case it's he lens switch for OIS if it has one, or the Lens OIS the twill kick in.
Ben
Olympus could do well to do a major UI cleanup. This just shows part of tithe unnecessary complexity.
Enjoy the PenF if you like its ergonomics and speed. It has some of the very best JPEGS and good RAW files I have seen in all m43rds.
Raist3d/Ricardo (Photographer, software dev.)- I photograph black cats in coal mines at night...
“The further a society drifts from truth the more it will hate those who speak it.” - George Orwell
Re: Thanks...
I think what Olympus closed down on is the Pen_F.  But I did read a comment that suggests the Pen line itself could be at danger.  But wouldn't surprise me they put another one later (not PenF).
The PenF has to be the camera that I have both loved and hates the most in equal parts. I think a lot of the parts I don't like you are fine with, so you will like it quite a bit.  Just like James said, do not bother with continuous AF. Pretend it's not there.
MEDISN
MEDISN Senior Member • Posts: 1,789
Re: Enjoy that camera, Ben
James Pilcher wrote:
Ben Herrmann wrote:
Hey gang...
Why?  Here’s a 30-shot sequence zoomed 1:1.  Two of the 30 are slightly out of focus.  C-AF is not something I normally use the PEN-F for but it works when I need it.  It’s a slow burst rate though, probably my only complaint.
Jim Pilcher
(unknown member) Veteran Member • Posts: 7,274
Ben Herrmann wrote:
Hey gang...
Olympus has not abandoned PEN line. We just do not know is the E-P and PEN-F discontinued.
No raw only (it is a raw without capitalization as it is not acronym) if you have a art knob in other than normal. So you need always get JPEG when using those modes.
You might need to go settings and disable lens I.S priority. As even when you disable that OIS, it doesn't allow to handle IBIS setting.
IIRC it is Menu > Custom Menu > C. release/IS > Lens I.S priority. And set it Off.
Ben
Ben Herrmann wrote:
Hey gang...
Because it works pretty horrible. Maybe doing a very slow moving approaching subject helps.  Tracking works if you have someone in a group move a bit.  But other than that, C-AF on the PenF is a complete joke.  The EM5 MKii even does it a bit better.
Multiple users and multiple reviewers show this.  But maybe for slow moving subjects like these that do not move around much it works (very narrow working envelope).  Another way I have seen it work is getting a car going say from left to right and panning with it.  But that's not exactly that challenging either.
Jim Pilcher
MEDISN
Raist3d wrote:
Ben Herrmann wrote:
Hey gang...
Define horrible?  Examples we can see?  Is there a threshold for subject speed and direction that dictates acceptable CAF performance?
The subject actually does move around the frame as I’m following her.  As I said previously, the video is cropped to her face 1:1 as though it were centered there but I’m not responsive enough to keep the face centered while shooting.
Ah, forgot who I was talking to.  Of course you read this somewhere on the internet so this is what you echo.  When someone posts actual experience that contradicts your narrative you do your best to cast doubt.  So predictable.
Jim Pilcher
acfo Senior Member • Posts: 1,500
Same experience here: CAF works perfectly. However one should read the manual as the camera allows one to shoot oneself in the foot (e.g. release priority instead of focus priority or sequential burst H instead of L).
 acfo's gear list:acfo's gear list
Olympus PEN-F Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 Olympus M.Zuiko Digital ED 75mm F1.8 +7 more
twenty200
twenty200 Contributing Member • Posts: 748
Re: Thanks...
Olympus hasn't discontinued the Pen series.
They just decided not to make another Pen F.
http://twenty200.com ...this is the world, the way I see it.
 twenty200's gear list:twenty200's gear list
Olympus E-M1 Olympus PEN-F Panasonic Lumix G Vario 35-100mm F4.0-5.6 ASPH Mega OIS Olympus 12-45mm F4 Pro Panasonic Lumix G Fisheye 8mm F3.5 +6 more
MEDISN wrote:
Raist3d wrote:
Ben Herrmann wrote:
Hey gang...
Not posting examples. I traditionally post a lot of examples of things in the past and I get burned with and endless discussion between people who don't believe it, or think I just started to use Olympus cameras or photography or something else.
Now, this may very well not be you, but it's kind of an overall standard policy I am following these days. My last shots can be seen in a recent-this week EPL9 thread. The EPL9 does focusing better than the PenF, and the EPL9 is equally horrible at C-AF.
Probably but that will work for each individual differently.  For you it seems to work ok. Generally speaking, C-AF should catch some reasonable amount of action- but again, if it works for you, what I am saying doesn't apply to you.
Not really. The frame seems rather constant in terms of position and sizable area.
Then I don't know.
Ah yes, let's go to the personal attack attempt. I thought for a moment you were being reasonable.  But never mind I have had the PenF for like two years now, and all I can say is that my experience using C-AF with it validates what a lot of reviews are also saying.
Of course the experience of one avid fan is more objective than someone who is reviewing a camera on a website. Pretty standard logic in this forum
But if you are really curious, you can see I have lots of experience with Olympus Cameras if you bother to look.  Anyhow, I am glad it works for you. Just warning the OP that it's not that good. Of course, other people have said the same thing, like James here.  I guess he most be someone without experience too right?
Jim Pilcher
For the record, I have set my PenF to focus priority.
MEDISN
Raist3d wrote:
MEDISN wrote:
Raist3d wrote:
Ben Herrmann wrote:
Hey gang...
Save the excuses.  I for one welcome your examples.  If they illustrate your point, why not?
Can you show examples from cameras you've used that are not "horrible"?  Just to provide some context.  I would love to see what excellent looks like in your hands.
I use C-AF for portraits too - what is reasonable amount of action?  Who defines this?
lol how would you know this.  I have centered each frame to the face.  The face could be anwywhere in the frame.  The video only shows 8MP out of 20MP.
Then I don't know.
But contradicts what this user is actually showing frame-by-frame.  Why are you so concerned with what some reviewer said?  Does the reviewer shoot with your hands or do you?
I provided evidence to the contrary.  Something you can't seem to do.  acfo chimed in and said his works perfectly.  Not sure why you're having trouble if you have two years experience with camera as you claim.
A lot of experience?  Great!  Show me.  The most recent photos on your website are dated 2017.  Do those illustrate the CAF ability (or inability of the PEN-F)?  You have no photos in your gallery here, no challenge photos in the last 10 years, only a whole lot of posts.  Is there somewhere else you host your photos?
Don't know what James is capable of and what he tries to shoot.  He didn't qualify his statement with expectations or describe when and how the PEN-F disappoints him.
MEDISN wrote:
Raist3d wrote:
MEDISN wrote:
Raist3d wrote:
Ben Herrmann wrote:
Hey gang...
Sorry but I am not feeling like moving an inch to my body for your request when there's ample evidence around. And I clearly have and used a PenF as evidenced by multiple shots I have posted with it.
And it's not excuses. I have gone well beyond the ask to bring something only to 90% of the time being told that I don't know what I am doing, or why I am being so bad, or whatever. Sorry, I learned that lesson years ago.
See above.
You can certainly use S-AF for portraits. You gotta ask, why James also agrees?
You are right, how on Earth would I know you were not really showing the complete example. You got me!
Then I don't know.
Oh, I am only bringing reviewers as an objective "not someone over the net" source. I certainly care about what I can do.
Doesn't seem like it, not with the movement you are showing. But then you may have captured super high resolution shots from a 4k video for all I know shot with something else. I mean, you keep telling me that the example you were showing doesn't show the full capture per se so I am at a loss here
It's interesting James also mentioned this as a problem. But of course, you seem to like me more
As I said above, I have posted multiple photographs with Olympus cameras.
Did you bother to just use d-preview's "threads started" and look for the ones with photos? Usually they are preceded by camera used. I mentioned I have posted here, or did you miss that? Didn't I reply to you my most recent shots are from this last week on EPL9?   Or did you just filter that out?
Read above. Also- no, I don't tend to use CAF on the PenF because it doesn't work well.
He did say forget about C-AF. Which is what I also said that you are in this very thread talking about no? Why am I so special then?
cba_melbourne
cba_melbourne Veteran Member • Posts: 5,850
Re: Thanks...
Apparently the Pen-F in silver livery is not available from Olympus anymore. They must have run out of stock (black is still available). I would not be surprised, if the silver model now experiences a price rise in the coming months.
Maybe Olympus did put some away for later, as Panasonic did with the GM cameras. Once GM's were sold out, there were suddenly small batches re-appearing years later, in some selected countries only, often bundled with the fine 15mm lens...
 cba_melbourne's gear list:cba_melbourne's gear list
Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Olympus E-M5 II Olympus PEN-F Olympus E-M5 III +16 more
Re: Thanks...
It is on the German Olympus website.
I do BIFs with the Pen-F in C-AF mode (examples here https://www.dpreview.com/forums/post/62619969 ) .
After I realized that I need to set the camera to focus priority and that C-AF only works in sequential burst L mode (on all Olympus cameras), C-AF simply works. If I have an out of focus shot it's because I did not point the camera in the right direction.
In fact C-AF is working so well that I was puzzled why the Pen-Fs C-AF is said to be sub par. There is no technical reason why the Pen F should be noticeably better or worse than any other Olympus body with the same generation imaging engine and cdaf sensor. Comparing the Pen-Fs C-AF with my daughters EM10 Mark II, I see no difference.
Here is the CameraStoreTV review which started the "Pen-F CAF sucks" rumor:
Pre-production Pen-F with a Oly 300mm f4:
https://www.youtube.com/watch?v=WqmMrp-pVp4
Follow up with a production Pen-F where they say the Pen-F did a good job in "zone focussing" C-AF mode and the "lock on" C-AF mode with tracking gave the most reliable hit rate. They had problems with the pen-f in C-AF mode with single button presses hunting on a subject which was not or only slowly moving (quite obviously with Rls Priority S set ON, meaning taking an out of focus shot was possible):
https://www.youtube.com/watch?v=sdPhwpmo5O8
So as far as I can tell, the reviewers did not set up the camera properly and there's nothing wrong with the Pen-Fs C-AF. Olympus may need to think about improving their manual though.
I would have to see how the birds were moving in those samples. I notice you can track mainly when the objects are moving more or less in the same focal plane like panning.
I definitively have set my PenF in focus priority and have tried both speeds.
There is. The 20 MP sensor has more data to parse through than an EM5 Mii for example. This difference can affect the performance. If you check out imaging resource low light AF for the GX9 which uses pretty much the same sensor, you see its ability to focus in lower light is less than the 16 MP sensor. The straightforward conclusion is that it has more noise in the dark because of the sensor density (and the fact it's not a BSI to counter that).
I saw their review a while back including follow up. What they said and concluded is that even with the upgrade the camera still had trouble. To be fair though- they were testing with a telephoto lens which is harsher on all cameras, though in the YouTube comments they mention that they noticed this with other lenses.
It seems rather strange that reviewers all of a sudden lost their ability to use Olympus cameras having not much problems with other models except to note that the UI is overcomplicated.
I can say the Fuji X-E3 I had clearly out classes the PenF, so did the XT20, the EM5 MKII at this game. The EPL9 does outclass the PenF in general speed, focusing in lower light, and doing all much faster, but still has issues with C-AF.
I'll give a quick try tomorrow to the L setting just to examine further if I notice a difference between that and the H, but I believe I had already tried this. But you got me a notch curious.
Thanks for writing your point of view without restoring to attempts to personal attacks and reading, much appreciated.
