K-1 mII, TT350p, wireless manual mode with another TT350p
Started Oct 4, 2019 | Discussions
JCDoss
JCDoss Veteran Member • Posts: 3,227
Hi guys. I sent this support email to Godox yesterday, and while I wait on a reply, I thought maybe you guys could have a go at the problem I'm having. See below...
I have two TT350P units and two Pentax K-1 mII cameras.
I am attempting to get the two flashes to communicate in wireless mode for off-camera flash.
I have updated both flash units to the most recent firmware (1.2) and have them set up as shown in the photo I've included.
I have tested both flash units in MASTER mode, and in SLAVE mode, and the following is true.
1. The master can trigger the slave using the TEST button in MANUAL mode.
2. The master will trigger the slave from the K-1 mII hot shoe in TTL mode and in MULTI mode.
3. The master will NOT trigger the slave when used on the camera's hot-shoe in MANUAL mode. Since I require manual flash, it is important to have this function working.
Thank you for any help you can provide!
JCDoss
 JCDoss's gear list:JCDoss's gear list
Pentax K-1 II
Pentax K-1 II
Massao Senior Member • Posts: 2,580
Re: K-1 mII, TT350p, wireless manual mode with another TT350p
I have only one Godox flash so haven't played with their set-up, but it could be that you need Godox transmitters like X2T or X-Pro for full functionality?
If you don't require TTL, than you can buy the dumb optical receivers and use almost ANY flash as slave. Note: It won't do HSS, and the master flash needs to be visible to slave unit.
If you don't need TTL and HSS then another option is to to buy the FlashQ transmitter and receivers. They have plenty of benefits: 1) smallest and lightest; 2) can be used on any camera system you have; 3) any flash can be used (for example, I use the ones that recycle faster...doesn't matter which manufacturer or system--you can use one Nikon flash and one Samsung flash with your Pentax camera :-D); 4) set-up is radio-controlled, so you don't need to worry about the master flash being visible to slave; 5) you won't have a flash On-Camera.
Hope it helps.
Kind regards,
Massao
First camera: Canon FTB; First autofocus SLR camera: Pentax; First Nikon: F601 (N6006); First digital camera: Sony DSC-W5; First DSLR: Nikon D70; First mirrorless ICL camera: Samsung nx11
 Massao's gear list:Massao's gear list
Sony Alpha NEX-3 Pentax K-r Samsung NX300 Samsung NX1100 A3000 +40 more
Adam007 Contributing Member • Posts: 805
I have the fuji version of the TT350. I use with my k-1 in Manual, and sync-limited. I have a variety of other Godox units.
Putting a Godox TT600 on the K-1 hotshoe successfully triggers the TT350.  The 350 was set to S1, and the hotshoe-mounted TT600 set to "M", though I'm not sure that was even necessary.  Perhaps you can play around the admittedly confusing settings and have another go at it.  Obviously, you can't control the slave flash in this fashion, just fire it.
Adam
 Adam007's gear list:Adam007's gear list
Fujifilm X100F Pentax K-1 Pentax K-3 Mark III Pentax smc DA* 300mm F4.0 ED (IF) SDM Pentax smc FA 31mm F1.8 AL Limited +7 more
MightyMike Forum Pro • Posts: 41,691
Did you by any chance have the shutter speed above 1/200th sec, i think above that the camera refuses to fire a manual flash or a flash in manual mode.
Mike from Canada
http://www.michaelfastphotography.com/galleries/VP-BDI_3a.jpg
http://www.airliners.net/user/SpeEedy/profile/photos?sortBy=photoFavoriteCount
JCDoss
OP JCDoss Veteran Member • Posts: 3,227
Thanks for your comments.  The TT350P has the wireless function of the Godox transmitters built in, and should be communicating with the slave unit. In fact it *IS* communicating with the slave unit in every single mode except the one I want it for... Manual flash.  TTL works, and so does MULTI mode.  Just not M.  Even the test button sets off the slave.
The TT350 also can be controlled in 'dumb mode,' as you put it, which may be useful as a last resort.
JCDoss
Pentax K-1 II
JCDoss
Thanks for your reply!  If you are using the TT350 in S1, then it was set as to 'dumb mode,' as the previous poster put it, and was acting as an optical slave.  I think I still have this function, although I haven't tested it yet, but wireless manual definitely is not working.
Thanks!
JCDoss
Pentax K-1 II
JCDoss
Thanks for your response, MM.  Good suggestion, however I'm pretty sure I kept the shutter at 1/125 for the test.  Maybe I should put it even slower just in case.
JCDoss
Pentax K-1 II
1/125 should be just fine
Mike from Canada
JCDoss wrote:
Thanks for your comments. The TT350P has the wireless function of the Godox transmitters built in..
Ok. I thought their flashes can act as radio-controlled receivers OR optical slave/master units. Actually, now I wonder what is the purpose of X2T when their flashes can radio-controll other flashes?
Try to place the other flash in a different room, and confirm whether it is being controlled via radio?
Lastly, try to reset everything (both flashes) and see if the problem persists?
Kind regards,
Massao
Just read more on Godox system and you are correct: TT350 has transceiver function. As for my question, several Godox flashes (V850II, V860II, TT600) do not support P-TTL directly, so you need their own trigger on camera to “translate” the TTL message from the camera to their flashes. Neat! And man their recycling times are amazing on VI, V850II, and V850—just 1.5 seconds---time to dump my Pentax 360/540 flashes that take 6 seconds..
Kind regards,
Massao
Based on the description given here , TT350 can radio-control some other flashes/strobes but NOT another TT350.
Kind regards,
Massao
KPM2 Senior Member • Posts: 2,076
Hello JCDoss
I don't have this flashes, but Massao posted a link to the manual.
Point 8 in the manual: You use the group A, but can it be that you must use on the master flash the mode button until you set the slave to on ? In the group A,B and C you can set on the master the slaves to on/off. Now point 8 describe  the multi flash use, but maybe your point 7 use have also such an on off setting for your slave via the master
Best regards. KPM2
JCDoss
Thanks for posting this, Massao.
JCDoss
Pentax K-1 II
JCDoss
KPM2 wrote:
Hello JCDoss
Best regards. KPM2
Hi, KPM2.  Sorry for the delay, I don't check this forum very often.
I did see that Massao posted the manual, and I already had a copy that I reviewed before posting.
I'm not sure I understood your comments.
Point 8 is for MULTI flash, or strobe, and it actually works fine in that mode.
Point 7 is for Manual wireless flash, and following those instructions I can't get it to work.
I am still waiting on a reply from Godox.
I did finally try optical mode (slave flash triggered by main on-camera flash, not radio signal), and that works just fine.  So I suppose the problem is solved, but I'd rather have a fully functioning set of flashes.
The TT350 is a fantastic flash even without wireless.  Recycle times are very fast, the unit is versatile and provides good power for indoor and close-up work, and is pocketable.  I highly recommend the flash, esp at the price point, even though I'm having trouble with mine.
JCDoss
Pentax K-1 II
Hello JCDoss
JCDoss wrote:
KPM2 wrote:
Hello JCDoss
Best regards. KPM2
I thought that, when you are in the wireless mode but the flashs in it's manual mode, you can still set via the groups the settings on your slave flash at the main flash, like for example that you can set on the main flash the slave flash to off or on, like the manual described it....but only at point 8 for the MULTI flash use.
Maybe it is a software bug, because using the test button seems to work as you wrote.
best regards  KPM2
JCDoss
best regards KPM2
Thanks again!  Yes I think I understand this time and you are right.  I can control the flash output on the slave from the master flash.  It all works perfectly except for one thing:  neither flash will go off when set to Manual.  Multi, TTL, and the test button, and control features all work as advertised otherwise.  It could be a bug, or it could be something about the K-1 mII.  I don't think the TT350 is labeled to work on a mark II, so maybe Pentax changed something?
Thanks again for your help!
JCDoss
Pentax K-1 II
Hello again JCDoss
best regards KPM2
I think you get for sure an answer from the manufacture. In the meantime, you can try out this:
I use Metz flash and had a problem with one of my elder flash and my K1. I called the Metz service and got this answer:
the K1 use different protocols for it's FF or crop mode. So, in my case, my flash could work in the crop mode of my K1.
Maybe try out to use your K1 MII in the crop mode and look, if the wireless manual mode of your flashes works than.
best regards. KPM2
JCDoss wrote:
KPM2 wrote:
Hello JCDoss
Best regards. KPM2
Maybe update the firmware on flashes, if its never done. Link
Kind regards,
Massao
