Industar-69 on my NX5 - pancake anyone?
Started Oct 3, 2019 | Discussions
kypfer Contributing Member • Posts: 985
5
I found this little lens on eBay for "not a lot", looking a little scruffy, but the optics are fine, the focus and aperture free and smooth and suitably modified it works almost like it was designed for the camera
Brief initial comparisons show it's on a par with my Orion-15 when both set at f/8, but it has the advantage of having an extra 3 stops of aperture and protruding from the camera for about a third of the distance!
The removal of the focussing stops and internal "lip" to allow infinity focussing are well documented, but a feature I didn't find mentioned elsewhere was the fact that the focus is a multi-start helix, not a single start screw, and by choosing the appropriate start point I can get both the focussing scale and the aperture index to line up correctly. Being a bit "old school" I find accurate focussing and depth of field scales to be very useful if shooting "off the hip".
Quick update : a rear lens-cap from a Contax/Yashica 2x converter acts as a perfectly-fitting push-on lens cap for the I-69 when mounted on my camera
The sample image shows the characteristic flaring with bright light that the I-69 is noted for, but the shadow detail is quite good!
A subsequent rummage in my toy-box has revealed a Hoya 22.5mm screw-in lens hood that looks perfect for the job, maybe it'll help tame that flaring a bit
 kypfer's gear list:kypfer's gear list
Pentax *ist D Pentax *ist DS Pentax *ist DL2 Pentax K200D Samsung NX5 +7 more
Samsung NX5
