G5X II: Is rattling from the lens cover normal?
Started Oct 2, 2019 | Questions
MaxPowers37 Regular Member • Posts: 102
When I move the camera and especially if I shake it I hear a loud rattle that I figured out was coming from the lens cover. For comparison I took my Sony RX100 III and shook it and could barely hear anything.
If the camera is defective I'd like to know right away so I can return it
Canon PowerShot G5 X Sony RX100 III
requa
requa Contributing Member • Posts: 860
Re: G5X II: Is rattling from the lens cover normal?
I hear a sound when I shake mine, but I'm not convinced it's the lens cover. If I hold a finger across the blades, I still hear the same sound. If I turn the camera on, I hear a slightly modified sound. Perhaps it's the spring-loaded blades of the aperture or something similar. I hope it's not a problem waiting to happen.
 requa's gear list:requa's gear list
Olympus Stylus Tough TG-870 Canon G5 X II
OP MaxPowers37 Regular Member • Posts: 102
With mine if I hold my the blades of the cover still I don't hear any rattle. Maybe I should I take a video and post it.
Danjos New Member • Posts: 24
I've got that rattle too and it stops when holding the blades. The blades seem thicker than others of a similar type so perhaps this is the reason? Bit annoying but I'm assuming it's fine. Having said that, it doesn't fill me with confidence about the build quality!
 Danjos's gear list:Danjos's gear list
Canon G5 X II Sony a7R III Canon EF 300mm f/4.0L IS USM Sony FE 85mm F1.8 Samyang AF 35mm F2.8 FE +6 more
MooSafari
MooSafari New Member • Posts: 16
Mine rattles too... but it doesn't seem to affect the operation of the camera. Just took it on a trip and it was working perfectly fine. Saw from other forums that this seems to be somewhat of a norm for Canon compacts? Didn't have this problem when I had the Rx100... it's a bit annoying but I assume it's the way the camera is built.
 MooSafari's gear list:MooSafari's gear list
Canon G5 X II Fujifilm X-T2 GoPro Hero6 Black
It's definitely annoying, but I'm glad it's not a defect. I really like the IQ and other aspects of the ergonomics, but it's annoying to hear that rattle every time I pick up the camera or when the shutter closes.
Agapeman Regular Member • Posts: 107
I don't know if the G5X II is the same as G3X when it comes to the Image Stabilization system, but when the G3X is turned off, the IS system creates a rattling when you shake the camera a bit. But the rattling goes away when the camera is turned on. With the G3X this is perfectly normal. Perhaps the G5X II is the same. If not, I have no idea if it is normal or not.
 Agapeman's gear list:Agapeman's gear list
Canon PowerShot G12 Canon G3 X Canon EOS 550D Canon EF 50mm F1.8 II Canon EF-S 18-55mm f/3.5-5.6 IS II +1 more
maflynn Senior Member • Posts: 2,134
My blades rattle as well (nt)
My blades rattle as well.
timo Veteran Member • Posts: 5,924
In some Pentax bodies and Sigma lenses (and maybe other products I don’t know about) the stabilised components can move around when the camera isn’t powered up. In those cases, it’s perfectly normal. Could this be the case with your camera? Sounds like it.
Tim
'If I were you, I wouldn't start from here ... '
http://timauger.smugmug.com
http://timauger.blogspot.sg/
 timo's gear list:timo's gear list
Fujifilm X30 Pentax K-5 Pentax K-30 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX8
Gary S Veteran Member • Posts: 6,240
Mine is the same
Sounds about the same as yours. My Sony AX53 camcorder has the same kind of lens cover. Almost exactly. It had a similar rattle from it if you shook it.
After I dropped the Sony in the sand the lens opened and stayed that way. Apparently a grain of sand wedged in between those blades and I couldn't shake it loose. Bought a 55mm lens cover and it's been fine with that. Been using it that way for a year and a half. Moral of the story, don't drop it in the sand. lol
 Gary S's gear list:Gary S's gear list
Canon EOS 7D Mark II Canon EF 200mm f/2.8L II USM Canon EF 300mm f/2.8L IS USM Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 100-400mm F4.5-5.6L IS II
Lion-O
Lion-O Forum Member • Posts: 95
Glad I found this thread!  I just for a G5xii, and the lens cover rattles, too.  My Sony RX100 doesn't do this, but my Panasonic compact does (slightly).  Did anyone ever run into any problems due to this, or is it no biggie.  It does annoy me that a $900 camera rattles, but I guess as long as it takes nice shots, that's what matters.
ChiJeff5 Regular Member • Posts: 371
Just joining in to say mine rattles too.  They probably just have slightly weaker springs keeping the lens cover leafs closed.  Or same springs and heavier leafs. Leaves?
 ChiJeff5's gear list:ChiJeff5's gear list
Sony Mavica FD-91 Olympus XZ-2 iHS Sony RX10 IV Olympus TG-6 Canon G5 X II +1 more
