DIY nodal slide anybody?
Started Oct 2, 2019 | Discussions
Giovanni_1968
Giovanni_1968 Veteran Member • Posts: 3,905
Just wondering if anybody ever did a nodal slide for panorama photography. I am tempted to try some stitching but don't want to start all the way in by buying an expensive nodal slide, thought to look up for DIY projects for a simple slide just to align the camera-lens on the nodal point as to avoid parallax, I have a friend who is very patient and who owns a lathe (I think this is the name of the machine in English), anybody ever made an attempt at such a thing?
Grazie
Giovanni - 70% GAS affected
http://www.flickr.com/photos/giovanniaprea/
Nikon D800 - Nikon D2Xs - Fuji X-Pro1 - Fuji S5Pro - Nikon F - Nikon F3
J.A. Michell Gyrodec - Audio Research SP-9 - Aeron AP-890 - JBL4311B
JN70CN - 14.14.30E 40.32.40N
 Giovanni_1968's gear list:Giovanni_1968's gear list
Fujifilm FinePix S5 Pro Nikon D2Xs Nikon D800 Nikon Z6 II Nikon AF-S Micro-Nikkor 60mm F2.8G ED +20 more
petrochemist Veteran Member • Posts: 3,619
Re: DIY nodal slide anybody?
Grazie
I've shot panoramas but have never needed a nodal slide. Microsoft ICE has always stitched the shot just fine, even when the shots were handheld from a moving boat.
 petrochemist's gear list:petrochemist's gear list
Pentax K100D Sigma SD14 Pentax K-7 Panasonic Lumix DMC-GF2 Pentax Q +19 more
Sailor Blue
Sailor Blue Forum Pro • Posts: 15,536
5
You can buy this one from China with free shipping for less than the cost of making one.
200mm Quick Release Rail Nodal Slide Plate Clamp for DSLR Macro Photography New | eBay
Add a Nikon compatible L Bracket so you can shoot in either landscape or portrait orientation.
eBay - MPU105 Quick Release L Plate Bracket For Nikon D7200 D5300 D810a D500 D750 80D
Here is a reference that give the nodal point of many lenses.
Nodal Point-Entrance Pupil Database - PanoTools.org Wiki
You can use the camera hand held for panoramas but using a tripod with a nodal rail makes it easier for the software to achieve a match between the images.
It is better to overlap too much than too little.  I have my camera set to display the Golden Rule lines in the viewfinder.  The lines make it easy to overlap each image by 1/3 of the previous one, which is more than enough to make aligning the images in post easy.
Another good use for the nodal rail is holding the camera with a long lens steady.  If you simply mount the camera on a tripod the heavy weight extended some distance from the tripod head makes it hard for the tripod head to hold the camera without creep.  Use the nodal head to move the camera and lens center of gravity over the tripod head and you will eliminate creep after you lock the tripod head.
Living and loving it in Pattaya, Thailand. Canon 5DS R & 7D - See the gear list for the rest.
 Sailor Blue's gear list:Sailor Blue's gear list
Fujifilm FinePix Real 3D W3 Canon EOS 7D Canon EOS 5DS R Tamron SP AF 90mm F/2.8 Di Macro Tokina AT-X 16-28mm f/2.8 Pro FX +9 more
Entropy512 Veteran Member • Posts: 6,016
Rather than get a dedicated nodal head ($$$$) - this is basically what I did.
You've already covered the L-bracket and nodal slide - the one thing remaining is https://www.amazon.com/Neewer-Professional-Panoramic-Arca-Swiss-Standard/dp/B01I57SS5S/
That combined with the equipment you suggest is FAR cheaper than most dedicated nodal head setups, with the only real advantage being that the dedicated heads have detents to ensure consistent angle changes between shots.
Context is key. If I have quoted someone else's post when replying, please do not reply to something I say without reading text that I have quoted, and understanding the reason the quote function exists.
 Entropy512's gear list:Entropy512's gear list
Sony a6000 Pentax K-5 Pentax K-01 Sony a6300 Canon EF 85mm F1.8 USM +5 more
Bernard Delley Senior Member • Posts: 2,041
Re: DIY nodal slide
I actually made one, several years ago.
But, do not forget that the entire setup includes a tripod, leveling pano head (here Arca P0) with clamp (I DIY mounted an RRS clamp on P0)  , my DIY nodal slide with nodal positions marked  (with RRS clamp on the slide),  L-bracket . This is for single row pano.
Since I had no nodal slide at the time, and it was out of stock locally. I did  mill one from aluminum in my home workshop in time for my photo trip.
But, as others pointed out, the nodal slide is the least costly part of the pano setup.
Often on travel/hiking, I do not have the pano setup with me mostly for weight and bulk reasons. So I do free hand pano. The built in level on the recent Nikon DSLR helps. But, close up foreground should not be present in free hand panoing.
 Bernard Delley's gear list:Bernard Delley's gear list
Olympus TG-6 Nikon D7200 Nikon D500 Nikon D850 Nikon Z7 II +17 more
Giovanni_1968
OP Giovanni_1968 Veteran Member • Posts: 3,905
Re: DIY nodal slide
I understand the slide being the least expensive part of a pano setup, I already have an L-Plate onto my camera, sometime I will also get either a better ball head than my Benro and a levelling base or the Acratech one which can do both, probably to buy a Chinese one (nodal slide) to start with is the quickest and cheapest, I just want to start and avoid parallax and to take landscapes with different focal lengths than my 20mm as to have more res and field of view.
Thanks for your input
levelled pano
These days, I did not find cheaper option than the Arca Swiss P0 ,to which I added a fitting clamp from RRS, at B&H
Basically you want a pano clamp on top of a ball for levelling like this at amazon.de
A nicely level-shot pano makes stiching much simpler. Sight was nice yesterday, Alps panorama example with 110mm FL pano shot from top of Zurich. PS CS-6 automate ... (AF-P 70-300mm f/4.5-5.6)
gordonpritchard Veteran Member • Posts: 5,102
For less than $1
And it works perfectly.
This was used with my old camera - I haven’t got a shot using it with my current camera.
"View their gallery before accepting their comments."
My photos: http://www.gordonpritchard.blogspot.com/
 gordonpritchard's gear list:gordonpritchard's gear list
Sigma 10-20mm F4-5.6 EX DC HSM Nikon Coolpix P950 Sony SLT-A57 Sony a77 II Sony 500mm F8 Reflex +1 more
Re: For less than $1
I don't see any SLIDE in that set-up. It may give rotation about the nodal point of that lens but wouldn't if the lens was changed.
As for working perfectly, my handheld Panoramas stitched by MS ICE have generally worked perfectly - even when taken from a moving ship...
FHDev Junior Member • Posts: 38
I concur that the stitching software is very good with handheld shots. Near foreground objects are the true test, and that comes into play with wide angle lenses. With longer focal lengths and presumably more distant objects, pivoting precisely about the *entrance pupil* is not so critical.
I built my own multi-row pano head especially for a Lumix GM-1 and the wonderful Samyang 7.5 FE. Total rig weight is less than 1800 grams. https://www.dpreview.com/forums/post/59651266
Even if you think you won't use multi-row, the Movo GH-700 is a very robust and versatile piece of gear and a good value. That's where I would start before making something of my own, and I'm a DIY guy.
ThrillaMozilla Veteran Member • Posts: 7,674
$10 will get you a very good nodal slide. That's all you need for a one-row panorama. An L bracket for $10 or $15 might be helpful for verticals in certain situations. And $5 or so for a small level will be helpful. Use it on the center column of the tripod.
Ah, gee.  It seems everyone has already given perfectly good answers already.  The only thing I have to add is the small carpenter's level.
 ThrillaMozilla's gear list:ThrillaMozilla's gear list
Canon EOS Rebel SL1 Canon EOS M6 II Canon EF 400mm f/5.6L USM
Too flimsy, I suspect, for anything but a mirrorless camera with electronic shutter.
I’ve used it with a dslr (Sony a77ii) with no problem. I just didn’t have a pic with that set up to post.
HeavyTeva Forum Member • Posts: 63
I made a camera-specific multi-row panohead for a few cameras: Canon G5, Panasonic LX100 and Olympus EM-5.
Photos for the LX100 version can be found here: https://pbase.com/atucker/lx100_panohead     Drawings for the same in pdf format can be found here: LX100 Pano
If you find it useful, feel free to copy, use, improve, etc. I may make one for my X100V, although the pocketPano Compact looks interesting. They will have an X100V specific model out in a couple months.
As others have commented, you do not need this unless you have items in the foreground prone to causing parallax errors when stitching, OR shooting low light panos, OR you plan to create/stitch multiple exposure panos.
