M50 = 18-150 C A and Barreling question
Started 11 months ago | Discussions
jonno35 Contributing Member • Posts: 689
Hi my local store has this combo on offer but what bothers me is on a lens review site, the lens showed pretty grim distortion and C A , my question is does the in camera correction get rid of both. I used to use Nikons and their inbuilt  correction worked very well..
 jonno35's gear list:jonno35's gear list
Panasonic FZ1000 Panasonic Lumix DC-G9 Panasonic Leica 12-60mm F2.8-4.0 ASPH Panasonic 14-140mm F3.5-5.6 II +3 more
Canon EOS M50 (EOS Kiss M)
Dareshooter Veteran Member • Posts: 4,475
Re: M50 = 18-150 C A and Barreling question
I can't see any reason why the in camera corrections wouldn't work. If you are shooting Raw and using a third party converter the in camera corrections won't be applied and you'll have take care of that within the program you use.However Canons DPP will apply the corrections so no worries there.
dave_bass5
dave_bass5 Veteran Member • Posts: 7,285
It works to an extent, but the lens can be quite soft at the long end. Its usable but dont expect miracles at this prince point/size.
The camera deserves better glass, but it a handy lens to have if small, light and good lighting is the order of the day.
 dave_bass5's gear list:dave_bass5's gear list
Canon EF 24-70mm F2.8L II USM Canon EF 35mm F2 IS USM Canon PowerShot S110 Canon EOS 5D Mark IV Canon EOS M50 +10 more
OP jonno35 Contributing Member • Posts: 689
Thanks for the info, I really want a walk around lens and saw a comparison youtube vid that showed the 18-150 being a bit sharper than the 18-135.So looks like I'm beaten on that one.It seems lenses are Canons weak point.
GinaRothfels Regular Member • Posts: 199
I've read that too, but I have both lenses and the 18-135 that came with my 80D is definitely sharper. I haven't been using it on the M50 though because of the size.
gium Senior Member • Posts: 1,525
jonno35 wrote:
...It seems lenses are Canons weak point.
An 8.3x APS-C zoom lens at that size and that price will always come with compromises. In that regard every lens manufacturer will have it as a weak point.
Canon is actually regarded as a great lens producer. If you look at it objectively, the 18-150 is actually quite good for what it is: a relatively very compact lens with good image quality and a good reputation. But due to its 8.3x zoom and size and price there will always be a compromise. The compromise for this lens isn't actually all that big. If you don't want to compromise at all, well then good luck in your venture of looking for a similar lens with that IQ at that price and size point.
 gium's gear list:gium's gear list
Canon EOS 5D Mark IV Canon EOS RP Canon EF 15mm f/2.8 Fisheye Canon EF 85mm F1.2L II USM Canon EF 24-85mm f/3.5-4.5 USM +8 more
dave_bass5
Ive got both and really, the 18-135 Nano USM wins hands down, especially at the long end. I only ever use the 18-150 for holidays, and even then only if size is really an issue.
I guess it depends what you prioritize. Smaller and lighter, or slightly better looking images.
