Canon 400D - Photo Stacking
Started Oct 2, 2019 | Questions
Barchy
Barchy New Member • Posts: 14
Hi All,
I've been watching countless youtube videos regarding different aspects of photography.  One such item was on Photo Stacking.
All the videos I watched the photographers had Live View and touch screen focussing, which isn't available on my Canon 400D.
I love landscape photography and would like to master Photo Stacking, but I'm not sure how I go about it seeing I don't have Live View or touch screen focussing.
Am I able to do this?
Regards
Geoff Barchan
 Barchy's gear list:Barchy's gear list
Canon EOS RP Canon EOS 90D
Canon EOS 400D (EOS Digital Rebel XTi / EOS Kiss Digital X)
Doug Pardee
Doug Pardee Veteran Member • Posts: 9,920
Re: Canon 400D - Photo Stacking
What kind of photo stacking do you want to do? There are a number of reasons you might want to stack photos:
  • High dynamic range (HDR)
  • Noise reduction
  • Focus stacking to increase depth of field
  • Increased resolution (similar to pixel-shift)
There may be more reasons. Those are the ones that come to mind.
Co-founder of the open-source LightZone Project: http://lightzoneproject.org/
 Doug Pardee's gear list:Doug Pardee's gear list
Fujifilm X-T10 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 Olympus Stylus 1030 SW Canon EOS 350D +13 more
Barchy
OP Barchy New Member • Posts: 14
Hi Doug,
Thanks for your response.  The reason is increased depth of field and focus.
Regards
Geoff Barcham
Doug Pardee
For focus stacking, you could simply refocus the lens by hand. Manual focus is a bit of a challenge on a straight DSLR like the XTi/400D, though.
The optimal solution is to get a rail that allows the camera to be moved in and out in small increments. This also avoids any issues with the lens changing focal length when you change the focus distance ("focus breathing", it's called). But a focus stacking rail will cost more than upgrading your camera.
In the end, there's a reason that focus stacking wasn't a "thing" back when your camera was made, and you're running into that reason.
Barchy
Hi Doug,
Mate, thanks for your response.  I thought that was the answer but thought I'd throw it out there to see if anyone had an answer.
Have been looking at the new Canon 90D, just have to convince the wife.
Once again thanks for your reply.
Regards
Geoff Barcham
