Gitzo 1541 vs 2541 for Z6 and 70-200 f2.8 or 300 f4 FL
Started Sep 25, 2019 | Questions
Tony Lau Regular Member • Posts: 398
I wondering btw the two from local used tripod sale, while I feel the 1541 should be fine for most of normal situation except the tele lenses, while the 2541 is heavier /more expensive, especially for hiking, but is more stable.
I normally used 70-200 f4 for tele to shoot landscape, but would like to be proof by lens up to 300 f4 for wildlife.
Any advice fro your experience ?
Tony
Z6+24-70 f4 S+SB700
 Tony Lau's gear list:Tony Lau's gear list
Sony RX100 IV Nikon Z6 Nikon Z 24-70mm F4 Nikon Z 14-30mm F4 +8 more
Nikon Z6
leicaman Veteran Member • Posts: 3,836
Re: Gitzo 1541 vs 2541 for Z6 and 70-200 f2.8 or 300 f4 FL
For a 300mm I would without question go with a 3 series....
 leicaman's gear list:leicaman's gear list
Nikon D810 Nikon Z7 +1 more
jtosbo00
jtosbo00 Forum Member • Posts: 77
I have the Gitzo 1555T (Traveler series 1) and my D850 w/ 200mm f2 lens sits fine so I think the mountaineer version is plenty since it has a hook to allow it be weighed down if needed.
Fujifilm X Trans and Nikon Z
 jtosbo00's gear list:jtosbo00's gear list
Fujifilm X-T3 Nikon D850 Nikon Z7
Leonard Shepherd
Leonard Shepherd Forum Pro • Posts: 20,308
For anything remotely long lens, including a 300 (maybe with a 1.4x) if you Google long lens technique the advice is generally anything less than a Series 3 is not up to the job.
I agree.
EDIT.
If you want to take a landscape while hiking if you can get the composition sitting down with an elbow on each bent knee while cradling the lens you can often get better stability than with many lower priced tripods.
Leonard Shepherd
In lots of ways good photography is much more about how equipment is used rather than the equipment being used.
Nikon D810 Nikon D500 Nikon D850 Nikon Z7 Nikon AF-S Nikkor 14-24mm f/2.8G ED +28 more
