High Power/High CRI Led's from eBay?
Started Sep 24, 2019 | Discussions
Sir Macadamia Regular Member • Posts: 147
Carll
Carll Forum Member • Posts: 74
Re: High Power/High CRI Led's from eBay?
Sir Macadamia wrote:
Anyone ever try thees for photo/video work? flicker? CRI? power? colour stability over time?
https://www.ebay.ie/itm/High-CRI-RA-95-300W-Citizen-COB-LED-Daylight-5600K-47-8-56-5V-5750mA-35000lm/173174733783?hash=item285204bbd7:g:NR0AAOSw2bFcJNea
You'r real problem will be heat dissipation, if it is not enough you will gradually fry any LED.
I use a bank of 10W COB LED strips on a dimmer with loads of heat sink and they have been very reliable.
Carl.
Trying hard to take a good photo
 Carll's gear list:Carll's gear list
Panasonic Lumix DC-GX9 Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S Panasonic 20mm F1.7 II Panasonic Lumix G Macro 30mm F2.8
ProfHankD
ProfHankD Veteran Member • Posts: 9,147
Should be fine; it's just an array of densely-packed LEDs.
The truly scary thing is how much power you can now get out of a single LED. My two-year-old laser cutter uses a 2.5W LED laser, and I have another in my lab that's 6W, but now there are 50W LED lasers: https://www.rpmclasers.com/output-power/50w-lasers/
Canon PowerShot SX530 Olympus TG-860 Sony a7R II Canon EOS 5D Mark IV Sony a6500 +32 more
BobORama
BobORama Senior Member • Posts: 2,842
That is insane.  Also somewhat scary.
 BobORama's gear list:BobORama's gear list
Pentax K-5 Pentax K-1 Sigma 10mm F2.8 EX DC HSM Diagonal Fisheye Pentax smc DA 18-55mm F3.5-5.6 AL WR Samyang 14mm F2.8 ED AS IF UMC +9 more
Video-vs-photo Regular Member • Posts: 199
They look pretty good for the price. You can test this supplier with low power models and if they come good you can order the big boy.
