Portrait lens for Grandchildren and picky parents
Started Sep 23, 2019 | Questions
OP gshoward671 New Member • Posts: 11
Re: Portrait lens for Grandchildren and picky parents
Very helpful- thank you so much!
EGH
 gshoward671's gear list:gshoward671's gear list
Fujifilm X-T3 Fujifilm XF 35mm F1.4 R Fujifilm 16-55mm F2.8R LM WR XF 90mm Fujifilm XF 23mm F2 R WR
Very helpful and most appreciated!
Thank you-
EGH
Thank you for sharing with me your fabulous work! Your pictures are amazing.
Thank you for the inspiration!
EGH
Agreed!!
EGH
To answer your questions, my plan is to do several environmental pictures of my 17 year old grandson. The vast majority of them will be taken outdoors and will be posed. If I use a flash at all, it will be a fill flash.
I anticipate that the pictures will be in a wooded area, by water, by his car, by his school/church. There may be one or two inside a building.
I also think that the majority of pictures will be several 5X7s with one or two being either 8X10 or a bit larger.
Hope that helps-
EGH
Thank you for sharing your pictures. They are great pictures and very helpful in my decision process.
EGH
El Vuelo del Escorpion
El Vuelo del Escorpion Contributing Member • Posts: 883
EGH
Thanks for your kind words. I'm glad you like them.
Regards from Mallorca island, Spain
 El Vuelo del Escorpion's gear list:El Vuelo del Escorpion's gear list
Panasonic Lumix DMC-LX3 Fujifilm X-E2 Fujifilm X-T2 Fujifilm X-H1 Nikon AF Nikkor 35mm f/2D +13 more
