still trying to perfect the running pics
johnny28129 New Member • Posts: 17
Im losing focus on my subject can anybody help. I have it on flexible spot focus. any advice would be great. I am at the age where I need reading glasses, maybe I need to wear them while taking pics too. I am showing two of the pics. One in focus and one not. Thanks in advance again for the help.
A-Marc
A-Marc Regular Member • Posts: 141
Re: still trying to perfect the running pics
afc or afs ?
Ron Poelman
Ron Poelman Veteran Member • Posts: 7,602
Bloke, your cam is awash in tech
specifically to handle these choices.
Buy the book , read up and get your money's worth out of the cam.
In the meantime, give the cam a chance, it's a lot smarter than you think.
Get closer, physically, (and zoom), get a lot more of your subject in the frame.
Forget Spot, try Center or Zone and fiddle the size of the area.
If you must use spot, use the large one.
Maybe fire a burst as well.
Ron.
Volunteer, what could possibly go wrong ?
 Ron Poelman's gear list:Ron Poelman's gear list
Sony Cyber-shot DSC-H2 Sony Cyber-shot DSC-R1 Sony SLT-A57 NEX5R Sony a7R +25 more
(unknown member) Senior Member • Posts: 1,233
Looks like the focus in the first photo is on the spectators (Penn State / Wingate or ? Dad, next to the Catawba woman). Did you try Lock-on AF?
BTW, there are a number of threads on A77ii autofocus in A-mount forum which you may want to check out, like this:
https://www.dpreview.com/forums/post/54625361
Also, a number of videos online...
TGM1234 Contributing Member • Posts: 507
I took these this weekend: https://www.tommarronphotography.com/Sports/Zionsville-Sports/Cross-Country/
A few points:
1) As others have said you focus is off one first one. Use APC.
2) My setting were 1/1000, ISO auto, as low an f-stop as you can get, center expansion AF.
3) If possible (not sure of your lens) make sure you zoom in tighter.
4) When shooting cross country you should need make sure you do two things - a) declutter the background which can often be done by shooing down the path they are running thereby eliminating the distracting people; b) since you cant change they light you need to work into it and have it at your back. Here you are shooting the shadow side. Ideally shoot into a darker, uncluttered background.
5) With a runner like this you should be able to pick him out of the background with your AF (e.g. no competing runners) with no issue so I would suggest using as wide as possible of a center focus point if you are having a hard time tracking. This should be an easy one regardless of camera so it is likely human error and can be fixed with technique (not trying to be mean here just trying to help narrow down the issue to help you - please don’t take offense).
I wear reading glasses these days as well : )
Best,
Tom
 TGM1234's gear list:TGM1234's gear list
Sony a9 Sony a7R III Canon EF 300mm f/2.8L IS II USM Sony FE 55mm F1.8 Sony FE 90mm F2.8 macro +10 more
nebulla Senior Member • Posts: 1,474
Very nice pictures, TMG . The colors are so vibrant. Thanks for showing.
 nebulla's gear list:nebulla's gear list
Sony a7 III Canon EF 50mm F1.8 II Canon EF 85mm f/1.8 USM Canon EF 400mm f/5.6L USM Tamron SP AF 90mm F/2.8 Di Macro +4 more
Thank you! As you know they sun and resulting shadows get all of the credit.
