purple hair and skin?
brandon77 Forum Member • Posts: 51
I have been shooting and have had photos coming out with purple like fringing across skin and hair. There is obviously some camera/lense issue here, though I am trying to find out how i can get rid of this, as i haven't had any luck. The yellow in the hair is also caused by this, but not as big an issue
Any advice would really be appreciated
Schrodingers_cat Senior Member • Posts: 2,806
Might want to post the raw file
Put it on Dropbox or something so people can take a look at the original.
Babine Veteran Member • Posts: 7,335
Re: purple hair and skin?
Using your post and after firstly using ACR for contrast, vibrance, etc., I see a blue cast as shown on the Info palette in PS. Using curves to balance the RGB values, I get this ...
As to causation, I'll leave that to the experts.
Cheers.
Gary
http://forums.dpreview.com/Galleries/8298604696/photos
http://www.pbase.com/pictek
I think that senility is going to be a fairly smooth transition for me.
Bobthearch
Bobthearch Veteran Member • Posts: 8,625
You want assistance in diagnosing a problem, but you post a 4mp sample that's been run through Lightroom and has all of the exif information wiped.
Why not show us the full resolution original?
Personal non-commercial websites with no ads or tracking:
Local photography: http://ratonphotos.com/
Travel and photography: http://placesandpics.com/
Special-interest photos: http://ghosttowns.placesandpics.com/
 Bobthearch's gear list:Bobthearch's gear list
Nikon D7100 Nikon AF-S DX Nikkor 35mm F1.8G Nikon AF-S DX Micro-Nikkor 85mm f/3.5G ED VR Tokina AT-X Pro 11-16mm f/2.8 DX II Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G VR II +2 more
Cariboo Contributing Member • Posts: 583
Looks "normal" on my eyeball calibrated laptop (not device calibrated). I don't really see "purple" but a tiny shade of blue in the hair nor yellow in the hair, other than maybe a touch from what looks like sun reflected highlights.
Is your monitor calibrated? What color spaces are you working & viewing in?
What was around the subject? Looks like it was taken in the shade, so that could explain adding blue tones as shade has a cooler color temperature, but was there also a nearby wall or ???? that was purplish, to reflect some of that tone? Ambient tones & colors will certainly impact subjects.
Also, was this a raw file or an out of the camera jpeg? What was the white balance used by either the camera or in your processing software? Try a different white balance as a starting point.
Was this image over or underexposed originally? What does the histogram look like?
OP brandon77 Forum Member • Posts: 51
This photo is the original
Yes it was taken in shade, but there was no purple or blue around the area. I just posted the photo, and the face and to me haor looks more purple as whe i tried lowering saturation the purple went from the face a litte bit.
Unfortunately, i had it in jpeg, so i dont have as much info
It was a underexposed as through i was shooting raw. The histogram screenshot is attached.
Bobthearch
I don't think so.  It's even smaller than the one you posted before and still missing all of the exif information.
What sort of camera are you using?
Bobthearch
The white balance setting is normally recorded in the file's exif information, the reason it would be helpful to see the original file.
Is this the exif information?
Bobthearch
Part of it.  The full exif information includes every setting in the camera at the time you took the photo - focus mode, white balance, saturation, and a hundred other things that might help diagnose a problem.
Curious as to why you are so opposed to just posting the original photo?
brandon77 wrote:
Of this is it
Bobthearch wrote:
Original photo
Bobthearch
Four weeks ago you were getting a giant purple flare in some photos on account of using a filter. You were advised to remove the filter, which hopefully you did.
https://www.dpreview.com/forums/thread/4420227#forum-post-63031097
And here it was recommended to you a month ago, "1) always post full-size unedited photos for eval."
https://www.dpreview.com/forums/thread/4417402#forum-post-62984391
But you're still posting miniature versions of photos, processed in Lightroom, with the exif information wiped.
What gives?
Bobthearch
brandon77 wrote:
Bobthearch wrote:
Original photo
Now I think you're trolling.
What 2.7 megapixel camera do you own?
sabrina81
sabrina81 Senior Member • Posts: 5,673
It doesn't look like he has much skin color to begin with. I can't guess what caused the bluish  washed-out tones. It might help if you posted information about your camera, image quality setting (raw, jpeg), color space, plus the usual exif data.
Original photo still looks what I'd kind of expect for low light or image made in shade & or around non neutral ambient colors or light. You just need to learn to process it better, IF, the original exposure was correct, ie: not over or under exposed, which could limit how much you push colors & densities around.
I also am not sure what "manual white balance" means in the EXIF? It would be helpful to know what that "manual white balance" color temperature was & why it was set? I'd change that WB setting immediately to Auto, which will take in to consideration white balance for shade, sun, etc. & give you a better starting point for RAW or Jpeg. Manual white balance baked into a Jpeg could be just as much of an error as over or under exposure. Another safety reason to shoot raw files.
The image looks "light" to me, but otherwise, I'd think it wouldn't take much to fix it. Try Auto Levels or just fine tune the skin tones with specific selections. Sorry I haven't used LR for a long time, so am not sure of all the tools, vs. what is in Capture One & or how I'd work in Photoshop.
Bobthearch
We could have seen this for ourselves four hours ago if you'd of only posted the original jpeg from the camera to begin with.
Why you keep yanking us around with these 2-3mp miniature resized and cropped photos from your 24mp camera?
So done with this...
Lan Senior Member • Posts: 1,230
Are you looking at a different version of this picture to the one you've posted? I ask because I can't see the issues you're complaining about in this version? The only areas I can see any fringing on is the metal poles in the background, which show fairly standard levels of LoCA:
Loaded into ACR, and shifted the WB slightly warmer and slightly greener. Reduced texture to even out the texture on his face. Applied a light ColorDodge to the eyes, and whitened the teeth slightly. Painted a little bit over any discoloured skin. Increased Vibrance somewhat.
Keit ll Veteran Member • Posts: 4,525
Altered mainly using Portrait Pro which seemed the easiest way of correcting odd colour cast. Probably a shade too warm but left it that way to show that significant changes arfe possible.
