Nikon Lens Patents
Started Sep 21, 2019 | Discussions
Dibyendu Majumdar Contributing Member • Posts: 787
Nikon Lens Patents
Hi,
I posted this on the Nikon SLR lens forum but perhaps this is a better place for it.
We are lucky that Nikon appears to have patents for many if not all Nikkor lenses they have manufactured. I have been compiling a list of these patents, and trying to track down patents for some of the earliest and famous Nikon designs.
If anyone here can point me to patents I should add then please let me know. In particular I haven't yet been able to track down the patent for 105mm f2.5 lens.
https://cameragossip.github.io/nikon-lens-patents.html
Thanks and Regards
Dibyendu
OP Dibyendu Majumdar Contributing Member • Posts: 787
Looking for lens design experts to review
Hi,
I am trying to process some of the lens patent data using opensource software such as 'GNU Goptical' and 'rayopt' which is a Python package.
Initial two attempts are here - both using 'rayopt':
First one is example 1 - Wakamiya patent on Nikon's 50mm f1.4 AIS Nikkor.
https://github.com/cameragossip/cameragossip.github.io/blob/master/lensdesigns/Nikkor-Wakamiya-50mmf1.4_Ex1.ipynb
Second one is example 2 - Haruo patent on Nikon's 58mm f1.4 AFS Nikkor
https://github.com/cameragossip/cameragossip.github.io/blob/master/lensdesigns/Nikkor-Haruo-58mmf1.4-JP2013-019993A-Ex2.ipynb
These are both Jupyter notebooks, and when you view them in Github they should be rendered along with the images.
I am looking for feedback - especially in two areas:
a) Am I doing anything wrong?
b) How to interpret what the diagrams are telling us.
I have no relevant technical knowledge but I am trying to understand/learn.
Thank you in advance!
Regards
Dibyendu
BobORama
BobORama Senior Member • Posts: 2,731
Re: Looking for lens design experts to review
Clicking on on the links does not do much of anything.
 BobORama's gear list:BobORama's gear list
Pentax K-5 Pentax K-1 Sigma 10mm F2.8 EX DC HSM Diagonal Fisheye Pentax smc DA 18-55mm F3.5-5.6 AL WR Samyang 14mm F2.8 ED AS IF UMC +9 more
Hard to say what your issue might be. You should be able to view the rendered Jupyter notebook.
Re: Nikon Lens Patents
Bernard Delley Senior Member • Posts: 1,556
Re: Nikon Lens Patents, thanks!
Hi,
no problem here to see your list at cameragossip. Interesting ! despite that it is difficult to appreciate the patent info as a non-expert.
some notes :
the linked patent for AF-S Micro Nikkor 60mm f/2.8 G  is reported to be in error by Google.
the Remarks column sometimes refers to figures like: See figure 26  . But, there seems to be no path to such figures.
there are interesting discussions with elaborate illustrations for some of these lenses at Pierre Toscani / Optique .
there is an interesting discussion of the AF-S 200mm f/2 G VR  by Marco Cavina
if you could find them, some further patents would be interesting to look up:
a) comparing the nearly equivalent lenses AF-S 24-120mm f/4 G (FX) and AF-S 16-80mm f/2.8-4 G DX
b) AF-S 80-400 f/4.5-5.6 G  a 5x zoom using a super ED glass element (like the 200mm f/2 prime)
c) Af-S 70-200mm f/4 G using a HRI glass element
d) comparing the older AF-S VR 70-300mm f/4.5-5.6 G IF-ED using 2 ED glass elements with the newer AF-P 70-300mm f/4.5-5.6 E ED VR achieving better IQ using only one ED glass element.
Hi,
some notes :
Wonderful thank you. Didn't know about this site.
Yes indeed love Marco's site.
Thanks for the suggestions.
Re: oops
some notes :
only the link is in error, nothing is said about  the patent itself !
Thank you once again for the link above, it seems I can add some more designs to my list.
Found patents for some Z Nikkors including 58mm Noct
Hi,
Found patents for following Nikon Z lenses:
16-50mm
24-70mm f/4
50mm f1.8
58mm f0.95 Noct
Please see https://cameragossip.github.io/nikon-lens-patents.html.
Above list also includes some of the previously found patents for 14-30mm, 35mm f1.8 etc.
Looks like we may be getting a 105mm f1.8 micro Nikkor as there is a patent for this:
https://patents.google.com/patent/WO2020039912A1/en
Looks very elaborate design.
The 58mm Noct via rayopt
Enginel Contributing Member • Posts: 803
Not a single one for any of 18-55? Sad
 Enginel's gear list:Enginel's gear list
Pentax Q Sony Alpha NEX-5N Sony E 18-55mm F3.5-5.6 OSS Sony E 50mm F1.8 OSS
I haven't looked for them yet, been focused more on full frame lenses. The new 16-50 looks very different in design from the existing F mount lenses.
Re: Found patents for some Z Nikkors including 58mm Noct
Hi,
16-50mm
24-70mm f/4
50mm f1.8
58mm f0.95 Noct
Additional information in this thread:
https://www.dpreview.com/forums/post/63831128
This might be for 105mm f1.4 Nikkor
Re: This might be for 105mm f1.4 Nikkor
https://patents.google.com/patent/WO2019229817A1/en
An earlier patent too refers to the same design:
https://patents.google.com/patent/WO2019116563A1/en
Probably neither is the primary patent...
bclaff Forum Pro • Posts: 10,945
Because of curvature and which elements are ED only the earlier one is a possible fit.
So I added Example 3 to the optical bench enev though it isn't perfect.
https://www.photonstophotos.net/GeneralTopics/Lenses/OpticalBench/OpticalBench.htm#Data/WO2019-116563_Example03P.txt,AxisO,OffAxis
That whole patent was a nuisance because it'd for several different designers with different styles of presenting the data.
Bill ( Your trusted source for independent sensor data at PhotonsToPhotos )
I guess this isn't the primary patent for the 105mm ? But it is the best match I have found so far. There is an earlier one for 105mm f1.4 but that is clearly a different design.
Nikkor Z 70-200mm f2.8
