Very good cheap hard cases.
billslatteryjr Contributing Member • Posts: 814
Harbor Freight has the Apache 4800 hard case on sale for $44.99.
https://www.harborfreight.com/4800-Weatherproof-Protective-Case-X-Large-64250.html?ccdenc=eyJjb2RlIjoiMTY0NTc2ODAiLCJza3UiOiI2NDI1MCIsImlzIjoiNDQuOTkiLCJwcm9kdWN0X2lk%0D%0AIjoiMTI4NTMifQ%3D%3D%0D%0A&utm_source=1021&utm_medium=email&utm_campaign=3819b_RollingBackPrices&cid=mEmail_s1021_3819b_RollingBackPrices&lid=5,923,911,445
It's just a little smaller than the Pelican 1550, has 2 more clasps and is around $125 cheaper. I have 3 of them and 1 large Pelican for a while now and the build quality looks about the same to me.
 billslatteryjr's gear list:billslatteryjr's gear list
Nikon D5 Nikon D850 Nikon D3500 Nikon AF-S Nikkor 200-400mm f/4G ED-IF VR Nikon AF-S Nikkor 200mm f/2G ED VR II +9 more
Ask Mait Contributing Member • Posts: 767
Re: Very good cheap hard cases.
Hi,
can you tell how light or heavy they are compared to pelican/ nanuk.
I have one of those cheap ones from a local hardware store brand and it is atleast twice as heavy. Other than that who knows if it is as drop safe as the name brands.
But I wanted something inexpensive to keep my gear at home or occasionally takeout to my car so these serve the purpose.
Thank you
John Card Junior Member • Posts: 48
I have been using an Apache (HF) case for about 5 months now and it has been working well, but the foam leaves a little to be desired.  I don't know if Pelican foam is the same or not.  Sometimes the squares break loose when you don't want them to.  I might look into replacing the foam with something better, but the rest of the case is great for the price.  I've purchased two so far and no regrets.
 John Card's gear list:John Card's gear list
Nikon D850 Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Nikkor 28-300mm f/3.5-5.6G ED VR Nikon AF-S Nikkor 50mm f/1.8G +4 more
