Best tele zoom lens for E-PL6?
Started Sep 20, 2019 | Discussions
OutsideTheMatrix
OP OutsideTheMatrix Veteran Member • Posts: 9,876
Re: new lens?
burritosandbeer wrote:
OutsideTheMatrix wrote:
Wow, you're right- a good lens plus a better body would cost significantly less. Does the shutter on this camera not last as long as the one on other mirrorless bodies? Or did you mean shutter shock when you said the shutter is its major weakness?
I was trying to maximize what's possible with this body, but I suppose the 40-150 I already have is the heaviest that should reasonably be used with it? I'll look into the lens and camera you recommended, though I was also considering the E-M1 or E-M10.
Or do you think one of the 300 or 400 mm lenses would also work fine?
I totally get trying to do the most with the least. I really do.
When I am saying the shutter is the weak point I mean for shutter shock, I have no idea the expected life of a shutter on an E-PL6 except to say I am sure it has SOME limitation. I know people have killed EM1-Mk1 shutters, so I suspect its in that ball park or less.
I shoot with a 150MM Lumix lens and I do see some shutter shock on that as well. I would say that if you want to do much extreme telephoto the least shutter shock possible is the best. My G7 has an electronic shutter, and hence zero shock, the G85 and newer have the electro-magnetic shutter that can keep a mechanical with negligible shock.
As far as the features of the olympus cameras I'm no authority, I generally look at panasonic myself as usually place a I have a priority on video.
I'm trying to figure out what my next body should be, there are so many choices, and I keep going back and forth between different ones.  My big fear is buyer's remorse.
In the councils of government, we must guard against the acquisition of unwarranted influence, whether sought or unsought, by the military industrial complex. The potential for the disastrous rise of misplaced power exists and will persist. We must never let the weight of this combination endanger our liberties or democratic processes. We should take nothing for granted. Only an alert and knowledgeable citizenry can compel the proper meshing of the huge industrial and military machinery of defense with our peaceful methods and goals, so that security and liberty may prosper together.
-Dwight D. Eisenhower, 1961
 OutsideTheMatrix's gear list:OutsideTheMatrix's gear list
Nikon Coolpix P900 Olympus PEN E-PL6 Olympus OM-D E-M10 II Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II +9 more
burritosandbeer Regular Member • Posts: 314
Re: new lens?
For what its worth,  everything out there is so good, I really wouldn't worry about buyers remorse.
My G7 (3-4 generations old) out classes my EPL6, and I'm sure the newer options out class it in a similar manner. If anything there's an excess of excellent options out there, I doubt you can really go wrong.
 burritosandbeer's gear list:burritosandbeer's gear list
Olympus PEN E-PL6 Panasonic Lumix DMC-G7 Panasonic G95 Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G X Vario PZ 14-42mm F3.5-5.6 ASPH OIS +7 more
OutsideTheMatrix
Re: new lens?
Are Panny 4/3 cameras generally better than Oly's?
Re: new lens?
I make no such claims on whats better.  I think its all personal preference.
I like my panasonics, but the new EM5-III is pretty tempting.
Not sure what my next upgrade is, either a Panasonic G85 or the Olympus EM5-III
Nothing else has much interest for me
