Visual comparisons of a7RIII, a7RIV shadow noise
Started Sep 19, 2019 | Discussions
JimKasson
JimKasson Forum Pro • Posts: 29,974
19
I've posted quantitative comparisons of the a7RIII and the a7RIV shadow noise performance here. I saw a small advantage for the a7RIV at a few ISO settings, and a small disadvantage at others. In no case did I find the differences at all striking.
Now I've done a visual test, taking the same serial numbered cameras I used for the quantitative test, and ensuring that the test conditions, including lighting, exposure, and camera temperature, were identical. I resampled the images to the same field of view, at a finer pitch than that of either camera so that neither would have an advantage.
Here are the images with Lightroom's default sharpening and noise reduction:
https://blog.kasson.com/a7riv/sony-a7riii-a7riv-visual-shadow-noise/
Here they are with both sharpening and noise reduction turned off:
I draw the same conclusions from these visuals as I did from the graphs I posted earlier: the a7RIV has only small advantage in shadow noise at a few ISO settings, a disadvantage at some, and the differences are not consequential to normal photography.
Overall, I find the a7RIV comes up short compared to its predecessor, but not short enough that that should discourage an a7RIII owner who wants the capabilities and features of the newer camera.
Jim
 JimKasson's gear list:JimKasson's gear list
Nikon D5 Sony a7 III Nikon Z7 Sony a7R IV Fujifilm GFX 100 +2 more
SigZero
SigZero Regular Member • Posts: 485
Re: Visual comparisons of a7RIII, a7RIV shadow noise
Adobe just published the final version of R4’s profile. I wonder if it helps with strange color cast at ISO3200.
I was also wondering if it would be beneficial to make comparison using optimal exposure strategies for both bodies considering different dual gain points in both,
Br, Paweł
My photo-blog: http://pawel.online
 SigZero's gear list:SigZero's gear list
Sony FE 85mm F1.8 Sony FE 24-105mm F4 Sony FE 100-400mm F4.5-5.6 Sony a7R IV Apple iPhone 11 Pro
JimKasson
OP JimKasson Forum Pro • Posts: 29,974
I'll check.
The images I posted were at ISOs where both cameras were at low conversion gain, ISO's one was at low and one was at high, and ISOs both were at high. I think that's enough to prove the point. The curves I published earlies included all ISOs in 1/3 stop steps.
Jim
SigZero
JimKasson wrote:
I'll check.
Jim
Yep, sure. All is ok.
Although its not the case - I'm made myself into thinking that those are ISO100 shots pushed to equivalent ISOs.  Wrong.
I'd really appreciate Your work.
Br, Pawel.
bobabend
bobabend Senior Member • Posts: 1,326
Jim
Thanks Jim. I came to the same conclusions in a much less scientific manner and appreciate your confirmation. Again, I think Sony did a good job of maintaining similar performance with smaller pixels . . . not a trivial accomplishment.
I enjoy constructive discussions & respond to civil, & respectful posts.
Stephen Starkman
Stephen Starkman Junior Member • Posts: 38
Jim,
Any idea why we're seeing so many random red dots in the rIV images (both series with and without NR/Sharpen on)?
I've had a peer report red dots too - but I don't have enough details from him.
I have an rIV as well....
BTW, thanks again for your work!
Stephen
Jim
 Stephen Starkman's gear list:Stephen Starkman's gear list
Nikon D850 Olympus E-M1 II Sony a7R III Apple iPhone X
JimKasson
SigZero wrote:
JimKasson wrote:
I'll check.
Jim
You’ve got it now. All were pushed five stops.
You are quite welcome.
Br, Pawel.
JimKasson
Stephen Starkman wrote:
Jim,
I noticed that as well, but I don’t have a good explanation. It may be a combination of higher pixel level noise and a different CFA filter set.
It’s a pleasure.
Stephen
Jim
Astrophotographer 10 Forum Pro • Posts: 13,798
5
Thanks for doing that Jim.
I would not call those differences minor. I find them quite a large degradation. I suppose at normal viewing size it would not seem so bad.
Another aspect that would be worth checking is a long exposure - say 30 seconds ISO3200. That's a common setting for nightscapes. I find the A7rii and iii give red/blue colour speckle noise in the shadow areas of a 30 second or less nightscape image. Not the sky areas usually its the foreground that is usually quite dark.
I see a lot more green noise in the higher ISO shots. Interesting, that may be the star eater at work. If you are seeing more red dots then perhaps they have "tweaked" the star eater filter to hit blue more and leave red alone.
Overall this camera seems a disappointment for nightscapes and a step back from the iii which was a reasonable step up from the ii. Perhaps the A7r has been the best of them all. I think we are seeing a technological wall where Sony seemed to be able to add some new feature to the earlier sensors and there's not much left to extract. Like some of those old inline 6 cylinder engines that were refined and refined until there was nowhere left to go.
A7siii may bring a big improvement here. Some new approach like that in SAR about different exposure times for different pixels within a block with a different colour matrix.A HDR type mode.
Greg.
 Astrophotographer 10's gear list:Astrophotographer 10's gear list
Sony a7R III Canon EOS Ra +1 more
Stephen Starkman
Hi Jim,
I had some A7rIV files laying around (haha) taken in the daytime outdoors. I opened them up in LR (with the new final profile), pushed them +5 and zoomed in 2:1. Looked at ISO 400 and 500.
No red dots. All around, better performance than I expected after reading your results (maybe I missed something).
However,
Your exposures were considerably longer at 2sec - mine at 1/100 or 1/60th. I think this may be a clue.
Without push:
With push:
and a 1:1 crop (image viewed at 2:1 in LRClassic):
Jim,
It’s a pleasure.
Stephen
Jim
JimKasson
Are these five stops underexposed? Doesn’t look like it.
Hi Jim,
My ISO 400 shots were at 1/100.
However,
Without push:
With push:
Jim,
It’s a pleasure.
Stephen
Jim
Stephen Starkman
Jim,
Nope, you're right. They were properly exposed. Got my thinking wordsback.
I was thinking push without the "recovery". Thanks for pointing that out.
Still perturbed by the red dots.....
Stephen
Hi Jim,
However,
Without push:
With push:
Jim,
It’s a pleasure.
Stephen
Jim
I don't know if this is related to the BSI nature of the sensor (the A7r did not do this red/blue speckle/dots in shadows, the A7rii,iii and possibly the iv do). I only see a few red spots. Do a 30 second ISO3200 night shot and you may see way more in the dark areas of the image.
But the Photoshop dust and scratches filter set to 1 cleans it up instantly.
Now that excess green is another thing. I think that is the one to worry about.
This sort of thread is probably the reason Sony will not enable their star eater filtering to be turned off as internet traffic will blow it up as a big defect - all this colour noise.
Greg.
JimKasson
I don't mind being able to filter out noise. I just want to do it in post. And I want to control when I do it, not the camera calling the shots.
allnew Junior Member • Posts: 35
Jim
After reading this and posts on other forums I have a hard time finding justifications for my A7R IV. Like everybody here I am trying to find benefits in image quality department and they are just "academic", as the camera delivered primarily in a convenience department: easier focus on eyes, ergonomics, etc. But the core of the new camera the  better IQ is not here, if not to be diplomatic. I came from A9/A7 III  and don't have an experience  with high density sensors as experienced users  here and so just have a naive question if I should return the camera as I still have one week window? Please advise.
JimKasson
Jim
I can't just tell you what the camera will and won't do. I can't tell you what kind of camera will suit the kind of photography you want to do without knowing a heck of a lot about what kind of photography you want to do.
LarryRC Contributing Member • Posts: 714
Jim
I’m keeping mine.  I can easily find more detail at higher iso with the iv over the iii.  At say 6400 the added detail is more obvious than at lower iso.
 LarryRC's gear list:LarryRC's gear list
Sony a7R IV Tamron 28-75mm F2.8 III Sony FE 12-24mm F4 Sony FE 100-400mm F4.5-5.6 Sony FE 600mm F4
Entropy512 Veteran Member • Posts: 4,837
For the most part, this strategy is really only potentially beneficial for video, or any other scenario where it's simply not feasible to divide a single exposure into two half-time exposures.
Context is key. If I have quoted someone else's post when replying, please do not reply to something I say without reading text that I have quoted, and understanding the reason the quote function exists.
 Entropy512's gear list:Entropy512's gear list
Sony a6000 Pentax K-5 Pentax K-01 Sony a6300 Canon EF 85mm F1.8 USM +5 more
JimKasson
I meant to say: "I can just tell you what the camera will and won't do."
Sorry.
bob13bob Contributing Member • Posts: 954
Jim
From my own experience. If you feel like that already, I would return it.  People on budgets should wait at least every other gen before upgrading too.
my equipment: a7iii. NATIVE: sony 50 1.8. samyang 35 2.8. ADAPTED: sigma mc11 adapter. canon 85mm 1.8. sigma (canon) 12-24 4-5.6. canon 70-300mm f/4-5.6 is ii.
