Using the MC-14 Teleconverter on the Olympus 60mm macro lens
Started Sep 19, 2019 | Discussions
RandallDunphy
RandallDunphy Junior Member • Posts: 38
Re: Using the MC-14 Teleconverter on the Olympus 60mm macro lens
Interesting! I took my EM5 then 1.4x TC, then m4/3s to Nikon adapter then 60mm Nikon macro. Works like a champ!
 RandallDunphy's gear list:RandallDunphy's gear list
Olympus Zuiko Digital 1.4x Teleconverter EC-14 Olympus E-500 Olympus E-5 Nikon D750 Nikon D500 +39 more
lester11
lester11 Contributing Member • Posts: 596
Great work, thanks! Just a couple of comments on extension tubes, and the Fotga and similar in particular.  I ran some Fotga tubes for a while.
I found the aluminium felt a little gritty when mating with the stainless steel of the lens, and so recommend the slightest smidge of a light machine oil onto the tube mating surface before use.  (Use a cotton bud to pick up a small part of the smear left by a drop of oil on a surface like glass or porcelain, and then wipe the touched bud around the tube.  That's a smidge!)   Wipe the lens mating surface afterwards.
Then, don't leave the tube attached to the lens for any length of time, there is a considerable galvanic gap between stainless and aluminium and any dampness will accelerate corrosion.
Finally, Fotga is at the less expensive end of the market, and the tubes show some inconsistency in length.  Using a micrometer screw gauge (repeatability plus/minus 0.01 mm), I measured at the four quadrant points around the circumference:
16 mm: actual 15.88, 15.91, 15.97, 15.92 mm
10 mm: actual 10.00, 10.04, 10.12, 10.10 mm
The variation is around plus/minus 0.05 mm, so 0.1 mm.  It makes the assembled lens plus tube work a little like a tilt-shift (smile), and kicks the 60 mm macro lens off to one side or other by around 0.6 mm -- which is a significant tilt, I guess, for macro depth of field.
Lester
 lester11's gear list:lester11's gear list
OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus 12-40mm F2.8 Pro Olympus 12-100mm F4.0 Olympus 25mm F1.2 +7 more
RandallDunphy
Interesting to use it as a tilt lens
EspE1 Senior Member • Posts: 1,448
Thanks for that bit of advice. I use my MC-14 solely for macro purposes, so I've stored it in a set with the tubes attached. Pretty dry, though, so no apparent damage so far, but for the future they will be stored separately.
Interesting, thanks for sharing this. -- And that's why I do hope that OMDS's stated increased emphasis on macro could result in the offering of a set of high quality tubes.
 EspE1's gear list:EspE1's gear list
Olympus E-1 Olympus E-5 Olympus E-M1 Olympus E-M1 III Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD +22 more
Skeeterbytes Forum Pro • Posts: 23,144
Oly sold the EX25 tube for the 4/3 E-system so perhaps will do so again. It's an odd absence in such a comprehensive system, but perhaps they don't wish to compete against the 3rd party makers.
Rick
OMDiver New Member • Posts: 15
I have the opposite problem.  I tried two sets of fotga last year and couldn't get more than a black screen.  Hoping it was a bad run, I tried again this week and got the same result: black screen with any combination of the 10/16 and my em1ii/60mm.
I switched everything over to the penF and it all works.  Incorporated the mc14... still ok.  Then back to the em1ii and stoked to still see an image.  When I removed the teleconverter though , black to black.
Neither fotga will engage the lens release on the em1ii, but both lock to the F (and the 10 to the mc14).  Is anyone else having latching issues or am I just 0 for 3 with fotga?  I assume this is needed for the camera to turn on the sensor.
 OMDiver's gear list:OMDiver's gear list
Olympus E-620 Olympus E-M5 II Olympus E-M1 II Olympus Zuiko Digital ED 12-60mm 1:2.8-4.0 SWD Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD +1 more
lester11
I've "invested" in a Fotga 10mm and 16mm metal pair, thinking they might be more accurately machined than their plastic versions.  Not so.  At first, the MC-20 would not "click" into place on the 10 mm tube, and neither would my M1X.  I could get a display with the 10 mm on the 60 macro, but MF only and no shutter duration, though the f number showed happily.
I have a small engineering mill, so was able to increase the length of the slot on the Fotga which takes the locking pin of the MC-20 and the M1X.  Well, while I was there I increased the depth and breadth as well, but it was the length which was the decider.  Milling around 0.4 mm off the inside of the slot allowed the pin to click into place both with the MC-20 and the M1X.  Similarly milled the slot on the Fotga 16 mm, so the pins also clicked into place there.
The MC-20 mounted fine on the 10 mm tube, but not enough clearance to add the 60 macro.  The 16 mm would not accept the MC-20, the interior plastic interfering with the MC-20's front lens projection.  I also have a small engineering lathe, so bored out the interior of the 16 mm tube a little with a boring bar, only 0.3 mm, and that did it, the MC-20 dropped into place.
All working perfectly.  Sadly, if your Fotga's aren't working, they have insufficient clearance where it matters for the locking pin of the mating item.
Lester
lester11
That was for the plastic versions of the Fotga tubes. Recently acquired the metal (aluminium) versions. Metal is easier to get spot-on than plastic, of course.
Metal 16 mm: actual 16.10, 16.12, 16.16, 16.24 mm - avg 16.155, tolerance +0.085 -0.055
Metal 10 mm: actual 10.18, 10.03, 10.11, 10.09 mm - avg 10.1, tolerance +/-0.08
Previously, the plastic 16 mm tolerance was +0.05 -0.04 and the 10 mm was +0.055 -0.065.
Good grief, the plastic tubes were better!
Lester
steveg_777 Regular Member • Posts: 123
You can use the MCxx on any lense that doesn't block the protruding part of the TC.... I use my mc20 on some adapted lenses and also my telescope.
Ben446 Junior Member • Posts: 35
Not that anyone was asking but just FYI, the DMW-TC14 (Panasonic 1.4 TC) does fit with the Pixo 10mm tube on the Olympus 60mm macro but on a GH5 at least, the focus bracketing function does not work. Nor does any aperture control with standard settings. In camera, the aperture reads as 0.
 Ben446's gear list:Ben446's gear list
Leica Q2 Panasonic Lumix DC-GH6 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Sigma 18-35mm F1.8 DC HSM Art Leica Nocticron 42.5mm +5 more
Beetles
Beetles Forum Member • Posts: 61
look_a_cool_bug wrote:
Has anyone had issues with losing the electronics pass through when placing an extension tube between the teleconverter and the lens?
I’ve tested 3 different 10mm extension tubes (2 fotga and 1 pixco), all of which had no problem with electronics pass through when mounted to the camera body. 2 teleconverters. 2 camera bodies, one has not had the firmware updated since 2019 and the other has up to date firmware. 2 lenses (the 60mm macro and a pro lens so that I could test with only a single extension tube).
With all combinations, I always lose autofocus and aperture adjustment when the extension tube is in place after the teleconverter (but not when placing an extension tube on the camera body before the teleconverter, in the case of a pro lens).
It’s baffling when I know other people have autofocus with this setup and I have tested with so many different hardware/firmware combinations. The only thing I can imagine is that maybe the camera reads the the teleconverter’s lens identity data and doesn’t recognize a pro lens attached, the body discards the electronics pass through to avoid breaking an improperly identified pro lens by sending bad autofocus commands - but if this were the issue, I would expect the older camera firmware to be more likely to work.
Hi, did you ever resolve this? I had the same issues with two mc20’s and three sets of pix of/fotga tubes, works optically but no aperture control or AF. This was with current (3.4 camera and 1.2 lens) firmware. Can one downgrade firmware?
racketman Veteran Member • Posts: 3,160
Accidentally ordered the JJC tubes and can confirm these too do not couple with the teleconverter. Have returned and await the FOTGA set.
look_a_cool_bug New Member • Posts: 4
Regarding the black screen and latching difficulties, this is probably coming too late to help you but might help someone: I've had that problem with every set of Fotga tubes I've bought. I have to connect them and disconnect them several times and then, magically, they begin working. Cheap gear... oh well.
I never did. Until recently I thought the extra connector on the MC14 was the problem.
But this week, I've started to have... well, the opposite problem: I got a macro rail for Christmas, and have been "pre-setting" the lens to 1:1 and the desired aperture before connecting the teleconverter. Very occasionally, something will click "just right" and the lens will abruptly achieve electronic connection and reset. Once, it even autofocused! For about five seconds. Then it lost the connection again.
So this tells me that contrary to what I've been experiencing, a working electronic connection *is* possible, and it's not a firmware issue. So I'm baffled again!
I've pretty much decided to use the MC14 only with a pre-set aperture (remember to hold aperture preview before disconnecting the lens! I keep forgetting and getting f/2.8, which is quite frustrating when it happens) and hard 1:1 focus, but if I change my mind, the next thing I'll try will be trying to find a way to add extra depth to the connector pins on the extension tubes - a layer of solder, maybe.
jcr4486 Regular Member • Posts: 471
I had those issues, the problem are the adaptor rings, not the MC14 or the lens, they have some bad  connection due to some gap issue, if you try to rotate them in ont of the directions while connected, should solve the problem and get connection again...keep trying... sometimes is hard to find the sweet spot... I will try to exchange to other brnad to avoid this as well, it drives me crazy... (I have two fotga 10mm)
 jcr4486's gear list:jcr4486's gear list
Panasonic Lumix DMC-GX8 Panasonic Lumix DC-G9 Panasonic Leica Summilux DG 25mm F1.4 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko Digital ED 75mm F1.8 +11 more
They started working today.
Nothing was different (except the day). It's fascinating because knowing how difficult these extension tubes can be I disconnected and reconnected them (and wiggled them) hundreds of times before and they never worked. Then today... suddenly, perfect connection.
I suppose the trick really is just to keep trying... but I would never have thought they'd suddenly start working after several months.
Dave in Wales
Dave in Wales Contributing Member • Posts: 900
Info please...........
Will these couple with the 1.4 TC without modification. If not which ET's will?
https://www.amazon.co.uk/gp/product/B076BC33Q9/ref=ox_sc_saved_image_1?smid=A30NVO4VNPCTDI&psc=1
Dave in Wales
Sorted..........https://www.dpreview.com/forums/thread/4556520
lester11
I found the MC-20 mounted fine on the Fotga 10 mm tube, but not the Fotga 16 mm, the interior plastic diameter too small for the MC-20's lens projection.  If you can bore or file out the interior of the 16 mm tube a little, I found removing a thickness of only 0.3 mm does it, the MC-20 drops into place.  I'd guess the same would apply to the MC-14, but I don't have one to test.  With MC-20, 10 mm, and 16 mm mounted, my 60 macro gives around 3x magnification with AF if wanted, width of view at 1:1 on the lens around 5 mm.
Lester
with MC14 on 2x10mm Fotga, no need to trim anything... either on NC or on Fotga...
