please grade for 3D effect
Started Sep 18, 2019 | Discussions
uuglypher
uuglypher Regular Member • Posts: 250
Please:
-  record your grading before reading other responses.
- state your age
The results are part of a cooperative research project involving a large number of participants of a wide range of ages, so your candid responses are particularly valued.
Based on research by others this 3D pair presents an aspect of disparity, the contribution to 3D effect by which has been suggested to be related to the age of the viewer.
please grade by the standard system:
a. no 3D effect
b. slight
c. moderate
d. strong 3D effect
Many thanks for your independent responses.
Dave Graham
uuglypher
"100% of the shots you don't take don't go in!"
Wayne Gretzky
BillAngel Regular Member • Posts: 200
Re: please grade for 3D effect
uuglypher wrote:
Please:
- state your age
a. no 3D effect
b. slight
c. moderate
d. strong 3D effect
Dave Graham
I would rate the 3D effect as between slight and moderate. My age is 71.
 BillAngel's gear list:BillAngel's gear list
Nikon D100 Nikon D200 Nikon D300 Nikon D7100 Nikon AF Nikkor 50mm f/1.8D +5 more
Brian F Flint
Brian F Flint Regular Member • Posts: 184
Parallel and Crossview - slight. ( I use a Loreo 3d viewer for viewing the parallel pair )
My age is 70+
 Brian F Flint's gear list:Brian F Flint's gear list
Panasonic Lumix DMC-ZS60 Sony RX10 III Canon MP-E 65mm f/2.5 1-5x Macro
threed123
threed123 Senior Member • Posts: 1,490
Slight. Actually a confusing warped affect rather than 3D.
I'm over 70...
uuglypher
OP uuglypher Regular Member • Posts: 250
Thank you, Brian, for your input.
Dave
uuglypher
Wayne Gretzky
uuglypher
Th@nk you, three, for your input.
Much appreciated
Dave Graham (age 79)
uuglypher
Wayne Gretzky
