Color bleeding - a problem of lens or camera?
Started Sep 18, 2019 | Questions
nyfz50 New Member • Posts: 9
Trying to use Panasonic 100~300mm to shoot sunset (camera: Panasonic G9), however you can see that the sun flare "bleed" into the shadow of the nearby building. I never had this issue for my Nikon system. Attached two shot, one from Pany and one from Nikon D7100 with Tamron 18~400mm lens.
Is it a problem with the lens (not enough coating) or a problem with the camera (shallow dynamic range)?
Thanks!
Panasonic G9, with 100~300mm lens
Nikon D7100 + Tamron 18~400mm lens
 nyfz50's gear list:nyfz50's gear list
Nikon D7100 Nikon D750 Olympus E-M5 II Panasonic Lumix DC-G9
Nikon D7100 Panasonic Lumix DC-G9 Panasonic Lumix G Vario 100-300mm F4-5.6 OIS Tamron 18-400mm F3.5-6.3
Martian Flatcat
Martian Flatcat Regular Member • Posts: 457
Re: Color bleeding - a problem of lens or camera?
Just to confirm, you don't have a filter on the lens? I would suspect a filter first.
--Flatcat
 Martian Flatcat's gear list:Martian Flatcat's gear list
Olympus OM-D E-M10 II Olympus M.Zuiko Digital ED 60mm F2.8 Macro Panasonic 20mm F1.7 II Olympus 12-40mm F2.8 Pro Panasonic Lumix G 14mm F2.5 ASPH +7 more
Adrian Harris
Adrian Harris Veteran Member • Posts: 7,708
7
Could be many things but doubt its a dynamic range issue as m43 sensors are normally excellent.
The shots look very different, the g9 one is over exposed compared to the Nikon shot, over exposure can cause this. The lens is not a pro level one, so may have optical issues . different atmospheric conditions could also be the guilty party.
 Adrian Harris's gear list:Adrian Harris's gear list
Sony RX100 Panasonic Lumix DMC-G1 Sony SLT-A77 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX8 +1 more
alcelc
alcelc Forum Pro • Posts: 19,003
f/22?
11
According to the EXIF, they were:
#1 from G9: f/22, 1/2000", ISO200, -3ev
#2 from D7100: f/10, 1/6400", ISO400, -1ev
I think generally f/22 is not advisable to use on M43 (negative effect of diffraction would start to kick in from f/8~9 onward...). If could be equivalent to f/44 of FF (if my calculation, that I am not good at all, is not far off) whereas f/10 of APSC is f/14 eq to FF only...
Might try to use a larger aperture, say f/8, 1/8000", ISO100 etc to see the result?
Albert
Adielle
Adielle Senior Member • Posts: 1,754
It's a problem with the camera's lousy JPEG engine / raw data to JPEG conversion
Same problem as with GX8, just less pronounced. This problem disappears completely when using a raw image editor like PhotoLab or Lightroom to process the image.
rurikw
rurikw Veteran Member • Posts: 3,788
5
Thanks!
To me the photos look quite different. In the first one the sun appears higher in the sky and brighter so there's  more contrast than the second one where the sun is softened by clouds. IMHO you'd need to shoot the same scene with both to compare.
 rurikw's gear list:rurikw's gear list
Nikon Coolpix 5000 Sony Cyber-shot DSC-R1 Sigma DP1 Merrill Sigma DP2 Merrill Sigma DP3 Merrill +37 more
TomFid Veteran Member • Posts: 4,000
I agree. The first shot is just totally blown out. A filter, diffraction and high atmosphere could also be to blame, but I don't think it's the lens. I have sharp, flare-free shots of the sun with the 100-300 MkI that look a lot like the Nikon shot.
nevada5
nevada5 Forum Pro • Posts: 15,569
Neither. User error.
7
The shot is blown out - over-exposed.  That's not the fault of the camera or the lens.
And f/22?  Wassup wit dat?
I'll try to be nicer if you'll try to be smarter.
It's fun being me -- Denny Crane.
(unknown member) Forum Pro • Posts: 19,317
Veiling glare
Don
Olympus EM5mk2 ,EM1mk2
http://www.dpreview.com/galleries/9412035244
past toys. k100d, k10d,k7,fz5,fz150,500uz,canon G9, Olympus xz1 em5mk1
OP nyfz50 New Member • Posts: 9
No I always remove any filter when shooting sun.
The exposure was already -3EV and the sky was already very dark. Can't go down further
I will try a normal aperture next time. f22 could be what caused it. The thing is that the shutter was already 1/2000 and there were really not too much option left.
I do noticed that for the Nikon shot the sky was a little cloudy but the Panasonic shot it was very clear. that could also makes difference.
Thanks!
Re: f/22?
Good point. Never thought of aperture that could cause it. However the shutter was already 1/2000 and ISO was 200. Will try different aperture next time.
Re: It's a problem with the camera's lousy JPEG engine / raw data to JPEG conversion
hmm... what action do you take in lightroom, suppress hightlight? Thanks.
Adielle
Nothing, it's just rendered correctly. Panasonic's JPEG conversion has a really serious problem with highlights around the sun turning into an ugly haze. With GX8 there's even ridiculous shades of green.
Good point. I never noticed this kind of issues with my Olympus camera. Let me try. Thanks!
Adrian Harris
Thanks!
Aaaarrgghhh, f22 is also part of the problem. M43 sized sensors are seriously into diffraction territory at f22.  Use a high quality ND filter to keep aperture below f11.
Henry Falkner
Henry Falkner Forum Pro • Posts: 15,901
When I get a picture like the first one, it means I have not cleaned the lens for a long time - regardless of which camera or which lens.
Henry
Henry Falkner - E-M10 Mark II, SH-1, SH-50, SP-570UZ
http://www.pbase.com/hfalkner
 Henry Falkner's gear list:Henry Falkner's gear list
Olympus SP-570 UZ Olympus SH-50 Olympus Stylus SH-1 Olympus OM-D E-M10 II Olympus OM-D E-M10 IV +1 more
(unknown member) Senior Member • Posts: 1,671
As others have said diffraction is likely the main problem. I try and use no smaller than f8. I don’t bother with an ND filter normally, I just use electronic shutter to give access to faster shutter speeds instead.
Didn't realize that the electronic shutter goes 2 stop further than that of the mechanical shutter. That will be sufficient to bring down aperture number to f8. Thanks.
Henry
I had it cleaned before use it. But the image did looks very "dirty". Maybe I need to use cleaning agent instead of just wiping it.
