Sunny 16 Doesn’t seem to work with my T6
Started Sep 17, 2019 | Discussions
gedansky Regular Member • Posts: 285
I understand this can be considered an archaic concept, but it is helping me to understand Manual shooting better.
I have my aperture set f/16 in bright sunlight, and my ISO at 200 and shutter speed at 1/200 and my meter shows my camera as WAY under exposed. the articles on sunny 16 says that this is also a way to find out whether or not your camera meter is accurate. Well apparently mine is not even close.
Before trying this, I would either be in Aperture mode and let the camera handle shutter speed, or manual and just adjust my shutter speed until my light meter leveled off. But plugging in the formulas from sunny 16 should work as well.
I really hope I’m just missing something. I did go through my camera to see if I had any kind of overcompensated settings but I don’t.
Any takers?
Thanks!
Canon EOS Rebel T6 (EOS 1300D)
Lemming51
Lemming51 Forum Pro • Posts: 15,278
Re: Sunny 16 Doesn’t seem to work with my T6
wrt the meter scale reading when you manually set sunny 16 it depends on
  • what metering mode is being used (Evaluative, Centerweighted, Partial, Spot)
  • whether the metered subject is in the direct sun (sunny 16 should be about right) or shaded, e.g. brim of a hat shading the face, in which case sunny 16 may underexpose that face.
  • also depends on the subject's color tone. The meters are calibrated to a midtone gray. If the subject is darker, then the meter will think "sunny 16" is underexposing, but it may not be. If lighter then the meter will think your settings are overexposing.
So ... did the shot using Sunny 16 give you the right exposure even though the meter said no?
Unapologetic Canon Apologist
 Lemming51's gear list:Lemming51's gear list
Canon EOS 40D Canon EF 50mm F1.8 II Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm f/2.8L USM Canon EF-S 55-250mm f/4-5.6 IS STM +5 more
Ray UK Contributing Member • Posts: 977
The sunny 16 rule is an approximation and cannot be relied upon to test a light meter. There are too many variables involved, sunlight varies throughout the day and seasons it also depends on where you are in the world, then you have the added complication of finding a subject that will reflect the right amount of light.
It can work with an average subject (whatever that is) on the right day and will probably give you an exposure that is +/- 1 stop of correct but then you may need to process the shot accordingly, if you are just going to shoot jpeg and let the camera work it out for you then there is an even greater chance that it will go wrong.
RedFox88 Forum Pro • Posts: 30,738
no need for f/16 on an aps-c camera. It’ll reduce sharpness more than providing more depth if field because aps-c has 1 1/3 stops more DOF due to using shorter focal lengths
There’s no need for that old rule because you can see your recorded result immediately and reshoot if needed unlike waiting for processed film prints to see how you did
Yep, just use your camera’s metering system, it’s far more advanced than sunny 16
AnthonyL Veteran Member • Posts: 3,686
Just thought I'd try this as it was my "go to" starting point 50yrs back with manual film cameras.
I'm one stop underexposed, but I'm in the UK and it is the autumnal equinox so firstly even though the skies are clear there is nearly always haze and it is about 10am GMT so the sun is not at its highest.  Adjustments may be needed for the fact I'm in the Northern Hemisphere and maybe pollution from global warming adds half a stop!
I bet if I was in the desert at midday on a clear day it would work.
What does give me Sunny 16 is metering to the sky away from the sun.
 AnthonyL's gear list:AnthonyL's gear list
Canon EOS 700D Canon EF-S 10-22mm F3.5-4.5 USM Canon EF-S 55-250mm f/4-5.6 IS Canon EF 40mm f/2.8 STM Canon EF-S 18-55mm f/3.5-5.6 IS STM +5 more
Re: Sunny 16 with my 700D
Here are my two images, one at Sunny 16 and the other opened up one stop.  From my perspective I think somewhere in between would be right but I don't have the best of monitors.
Jack Jian Regular Member • Posts: 309
Any takers?
Thanks!
When shooting M mode, feel free to ignore the camera meter. The camera meter will meter only the central AF region so, depending on what you are pointing at, it'll change (inaccurate, when taken the overall scene).
Sunny 16 rule (taken literal) is applicable only for subjects in a very sunny scene with hard shadows.
Here are some values that I use when I started off, after a bit of researching from Internet:
Applying the same Sunny 16 technique, the values below works great in getting the approximate exposure. Judge the intensity of the light by looking at the shadows.
f22 - Very bright / Sun on Snow / White Sand
f16 - Sunny - deep and distinct shadow.
f11 - Sunny with some clouds
f8 - Cloudy but with soft blurry shadows/golden hours
f5.6 - dark vampire cloudy
f4 - shadows
f2.8 - late evening
So, shooting normally, if you are in Sunny 16 situation, simply change the other values to get the best IQ, for eg. instead of shooting at f16, ISO 100, 1/125, shoot at f5.6, ISO100, 1/1000.
Another example: You are in f8 scene but you want to take a portrait with nice bokeh, at f2. Then, the conversion based on f8 rule will be: f2, ISO 100, 1/2000 (shutter compensates the f stop).
Since light intensity is variable, keep practicing and with more experience, it'll become natural to just look at the light and knowing what to dial in the appropriate values of ISO, shutter & Aperture to get the desired look.
Retzius
Retzius Contributing Member • Posts: 901
Your lens has a t-stop that is about half a stop slower than the measured f-stop. Sunny 16 doesn't take that into account.
 Retzius's gear list:Retzius's gear list
Ricoh GR III Canon EOS R5 Canon EF 100-400mm F4.5-5.6L IS II Canon RF 24-105mm F4L IS USM Canon RF 50mm F1.8 STM
Well now you've told me that I can take it into account (for that lens of course) - but seriously, if a rule of thumb is accurate to within half a stop I think most would be happy with that, wouldn't they?
