M6 Mark II can record 4:2:2 10-bit external?
Started 2 months ago | Questions
confusedbagels New Member • Posts: 2
Found this quote buried in an overview of the M6 Mark II's video capabilities:
With clean output, compatible HDMI recorders can be connected with appropriate HDMI cords. During Clean HDMI out, video is not recorded to an in-camera SD card. With compatible external recorders, Uncompressed 4:2:2, 10-bit files can be recorded via HDMI.
https://www.usa.canon.com/internet/portal/us/home/learn/education/topics/article/2019/august/4k-and-full-hd-video-with-the-eos-m6-mark-ii
Hadn't seen that feature mentioned anywhere else. Was curious if anyone had seen it reported elsewhere.
Canon EOS M6
Lemming51
Lemming51 Forum Pro • Posts: 15,083
Re: M6 Mark II can record 4:2:2 10-bit external?
Oh, yeah, sure. First thing I looked for (said the totally video-ignorant guy pretending to know what the hell any of that means. )
"HDMI recording
Menu-selected user choices for HDMI output with info (images recorded to the SD card); Clean 4K output, or Clean Full HD output. With clean output, compatible HDMI recorders can be connected with appropriate HDMI cords. During Clean HDMI out, video is not recorded to an in-camera SD card. With compatible external recorders, Uncompressed 4:2:2, 10-bit files can be recorded via HDMI."
I see they keep mentioning "Clean" output. That means no nekkid stuff, right?
Unapologetic Canon Apologist
 Lemming51's gear list:Lemming51's gear list
Canon EOS 40D Canon EF 50mm F1.8 II Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm f/2.8L USM Canon EF-S 55-250mm f/4-5.6 IS STM +5 more
Mirfak Senior Member • Posts: 1,476
"HDMI recording
Not sure that 10bit 4:2:2 2.8K upscaled to 4K will make a difference.
KEG
KEG Senior Member • Posts: 2,971
6
"HDMI recording
2.8K how? (6960/2 gives 3.5K video) or the sensor is actually using a frame size of 7680x4320 which would make it multi aspect ratio (unlikely) or the image processing pipeline has been optimized to the degree where the sensor is able to sample 6960 down to 3840 in real time
KEG
 KEG's gear list:KEG's gear list
Panasonic Lumix DMC-G3 Fujifilm X-T1 Canon EOS M3 Canon EOS M6 Canon EOS M50 +14 more
Miguel-C
Miguel-C Senior Member • Posts: 1,048
"HDMI recording
It will if u want ou do colour grading.
"HDMI recording
Not necessarily. I've seen a particular suite of tests done by a Hollywood filmmaker and color grading expert who concluded that you have to do extensive grading before banding and other artifacts appear in 8bit. He mentioned that Sony's S-Log3 should be avoided because the that log profile is too flat for grading in 8bit video. He thought that S-Log2 was fine because the needed grading was mild.
Miguel-C
"HDMI recording
Depends on the camera I guess, the video on my m5 breaks apart really easily with minimal HSL modifications.
P runar Regular Member • Posts: 295
the 4k internal on memory card is 860MB/min... does anybody know the file size of the external uncompressed 4.2.2/10bit ?
 P runar's gear list:P runar's gear list
Canon EF-M 32mm F1.4 Canon EOS M Canon EOS M10 Canon EOS M50 Canon EF-M 18-55mm f/3.5-5.6 IS STM +4 more
"HDMI recording
Fair point.
KEG
Given 30 fps, around 17GB/m
KEG
KEG
Each 8MP frame is around 10MB, each pixel is 10 bits or 1.25 bytes
at 30 fps we have 1800 frames per minute, 1800 x 10 MB = 18 GB
KEG
Thanks KEG ,  it's gonna be big file's,,, i will be using the internal 8bit for the most,
OP confusedbagels New Member • Posts: 2
True. However, most external recorders can record the uncompressed stream at a variety resolutions and bitrates. If your recorder can do some flavors of ProRes here are a few example bitrates.
https://en.wikipedia.org/wiki/Apple_ProRes
gjeric New Member • Posts: 23
Anyone with Atomos and M6mk2 that can confirm if its possible to get 4.2.2 10bit video?
