Olympus TG5/6 + FCON-T01...The best VFM for snorkeling!
Started Sep 15, 2019 | Discussions
Yannis1976
Yannis1976 Veteran Member • Posts: 6,308
Hi,
I finally found time to process my UW photos from this summer and once again I am really happy with the TG5 and the FCON-T01 wide lens adapter. I consider it absolutely essential for the UW shots I take and the combination of size, speed and IQ is really great!
All photos were PP in LR.
 Yannis1976's gear list:Yannis1976's gear list
Fujifilm XF 35mm F1.4 R Fujifilm XF 70-300 F4-5.6 R LM OIS WR
Enders Shadow
Enders Shadow Veteran Member • Posts: 3,604
Re: Olympus TG5/6 + FCON-T01...The best VFM for snorkeling!
Looked like you had some nice conditions. Great pictures.
I agree the TG-X series is ideal for snorkeling. It's hard to justify anything larger for casual underwater photography. As long as you keep ISO low, IQ is good for a small sensor camera.
I don't use the fisheye adapter as much as I used to. With good water visibility, the normal wide end has been working for me. I used think the 25mm lens wouldn't be wide enough, but it usually provides a functional field if view. If the water is a bit murky and I need to shoot extremely tight, the fisheye lens is a must. You do have be careful and burp the lens to clear off any air bubbles. There have been a few times where the19mm view of the FCON-T01 wasn't wide enough. But I seriously doubt I'll be investing in their new circular fisheye adapter.
Phil
 Enders Shadow's gear list:Enders Shadow's gear list
Canon PowerShot G12 Olympus Tough TG-3 Fujifilm X30 Canon EOS 7D Mark II Nikon D500 +19 more
0lyboy Senior Member • Posts: 1,080
Re: Olympus TG5/6 lots of digital noise
By looking the originals I did notice lots of digital noise.
It is possible the camera to have aggressive sharpening algorithm, either way I do not see breathtaking results.
Γεια σου πατριδα.
 0lyboy's gear list:0lyboy's gear list
Olympus D-520 Zoom Olympus C-2100 UZ Olympus E-100 RS +8 more
Stefan Sobol Regular Member • Posts: 307
Is the vignetting in the images OOC or is it a PP effect?
In some images it seems a bit lopsided, maybe because of cropping?
Yannis1976
OP Yannis1976 Veteran Member • Posts: 6,308
Vignetting is of course by me 🙂 so if you don’t like, it’s just my over pp.
Yannis1976
Γεια σου πατριδα.
Γεια σου πατρίδα!!
Noise becomes visible as soon as you start zooming and cropping, but bear in mind that water wasn’t always crystal clear. Also some noise becomes more visible due to my pp which may be a bit dramatic.
DDoram
DDoram Forum Pro • Posts: 10,361
Hi Yannis:
Nice captures; thanks for sharing.
Dale
Yannis1976 wrote:
Hi,
 DDoram's gear list:DDoram's gear list
Sony RX10 IV Pentax K-1 OM-1
