Thoughts on 1st lens with a G9
Started Sep 14, 2019 | Discussions
JDC1958 Senior Member • Posts: 1,265
I am thinking of downsizing from my D500 to a G9. I can put off birding for now until the spring, 100-400, but I want a good all around zoom. The choices are many and there are just as many price choices. I am leaning towards the Panasonic 14 - 140 simply because I think its weight and range make for a good all purpose lens. But would like feedback from those with experience with the system.
One more thing I want to do with this first lens is to be able to shoot video. I have really never used video but since this is a big feature, I do want to learn. So being good with video and parfocal is something I would like.
My range is under 1000.00 for this lens. Thanks in advance and I am looking forward to any advice.
Common sense is common knowledge; not everyone's common knowledge is the same. Explanation: A farmer runs circle around the city dweller on his farm. The city dweller likewise runs circles around the farmer in a downtown environment. Neither are idiots, their common knowledge ( sense ) is just different.
 JDC1958's gear list:JDC1958's gear list
Panasonic Lumix DC-ZS80 Panasonic G95 Panasonic Leica 100-400mm F4.0-6.3 ASPH Panasonic Leica 12-60mm F2.8-4.0 ASPH
Nikon D500 Panasonic Lumix DC-G9 Panasonic Lumix G 14mm F2.5 II ASPH
grcolts Veteran Member • Posts: 3,914
Re: Thoughts on 1st lens with a G9
I bought the G9 with the 12-60/2.8 lens and have been very happy with the results. Also, consider the Panasonic 100-300 II for a longer telephoto. I purchased that lens over the 100-400 and have been very happy with it.
brentbrent Veteran Member • Posts: 5,767
I had the 14-140 f/3.5-5.6 Mk I (there is now a weather-resistant MK II version out) and liked it a lot. I sold it for the Olympus 12-100 f/4, which is an amazing lens, though bigger and heavier. New it exceeds your budget a bit. I bought a very nice used one, with a couple of high quality filters, for $900. It works great on my G9. You might want to consider it. But you won't go wrong with the 14-140, either.  Or the PL 12-60 f/2.8-4 if that range is sufficient for you.
Brent
 brentbrent's gear list:brentbrent's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX8 Panasonic Lumix DC-G9 Olympus E-M1 III +26 more
jwinberg11 Regular Member • Posts: 176
I have the second version of that lens, have used it on many trips, and LOVE it!  It is an excellent all-purpose lens.
<<I am leaning towards the Panasonic 14 - 140 simply because I think its weight and range make for a good all purpose lens.>>
 jwinberg11's gear list:jwinberg11's gear list
Olympus E-M1 II Panasonic GH5 Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Olympus M.Zuiko Digital 45mm F1.8 Panasonic Leica 12-60mm F2.8-4.0 ASPH
Oboyle
Oboyle Regular Member • Posts: 209
If you're serious about video then you'll want to consider a constant aperture if you plan on zooming while making clips. Aperture changes can make the footage look a little jarring. My recommendation is the Olympus 12-40 2.8 and or the panasonic 35-100ii 2.8. Both will give you a weather sealed combo with the G9 as a bonus. The 12-40 has a manual focus clutch with hard stops that works a treat for video if you plan to learn manual focus techniques while filming.
 Oboyle's gear list:Oboyle's gear list
Olympus E-M5 II Panasonic Lumix DC-G9 Panasonic Leica D Summilux Asph 25mm F1.4 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital 17mm F1.8 +2 more
cambirdee Forum Member • Posts: 50
Both kit 12-60 lenses are quite decent. The Leica one is often discounted, while the regular Panasonic is just very cheap (as part of the kit) anyway.
 cambirdee's gear list:cambirdee's gear list
Olympus OM-D E-M10 II Panasonic Lumix DC-G9 Panasonic Leica 100-400mm F4.0-6.3 ASPH
OP JDC1958 Senior Member • Posts: 1,265
All good recommendations. If I spend most of the 1000.00 lens budget, I am leaning towards the 35-100 2.8. I shot close to a year with my first full frame lens which was a 2.8 100mm macro, so I know how to compose with a limited view when need be.
I like more reach for critters and flowers though. I have a few weeks to decide, thanks for the input.
spschneer Forum Member • Posts: 51
I just recently migrated from a D7200 to a G9. It came with a Panasonic 25mm, f1.7 "normal lens".
I too like all sorts of subjects so I've added the following lenses to hit all ranges. 1st lens add was the Panasonic 14-140 f3.5 (mod 1, not weather sealed) that stays on my G9 body, for an walk-around lens when on trips/travel/grab shots.
Next addition was a Olympus 9-18 Wide Angle for architecture, interiors, and other WA stuff. I couldn't justify the Panasonic-Leica 8-18 ($$$) and didn't want the challenges of the Panasonic 7-14 with its front element filter killer.
The "final" addition is a Panasonic 100-300 for birding, wildlife and distant objects that I can't get closer to.
All of these were purchased pre-owned from Keh Cameras (great folks) and I'm very happy with their performance and condition. They also handled my D7200 and its lens collection.
S.
 spschneer's gear list:spschneer's gear list
Panasonic Lumix DC-G9 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S Panasonic Lumix G 25mm F1.7 ASPH Panasonic 100-300mm F4-5.6 II +1 more
Sranang Boi Senior Member • Posts: 2,860
More reach at a wide aperture starts to cost money. But you could be in luck with the Panasonic Leica 50-200mm f2.8-f4.0. It's normally over your £1000 budget, but can  be found at below that if you keep your eyes out for it.
But for day to day shooting the 14-140mm f3.5 is ideal.
 Sranang Boi's gear list:Sranang Boi's gear list
Panasonic Lumix DC-FZ1000 II Panasonic Lumix DMC-GX8 Panasonic G90 Panasonic Leica DG Summilux 15mm F1.7 ASPH Panasonic Leica 12-60mm F2.8-4.0 ASPH +1 more
evetsf Senior Member • Posts: 1,707
One thing to keep in mind if you are considering "cross pollination" (Olympus lenses for the G9) is that Olympus & Panasonic zoom rings turn in opposite directions. Olympus turns in the Canon direction, Panasonic follows the Nikon path.
If having zooms that turn in opposite directions bothers you it's best to go 100% with one maker.
Steve
 evetsf's gear list:evetsf's gear list
Panasonic Lumix DC-G9 Panasonic Lumix DC-GX9 Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G 20mm F1.7 ASPH Panasonic 12-60mm F3.5-5.6 OIS +3 more
LeanderOne
LeanderOne Regular Member • Posts: 267
Steve
I never knew that, and - as a potential G9/G95 user who currently occasionally uses my other half's Nikon DSLR -  it is good to know.  Thanks Steve.
 LeanderOne's gear list:LeanderOne's gear list
Panasonic Lumix DMC-FZ300 Panasonic FZ2500 Olympus TG-5 Panasonic Lumix DC-G9 Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS +1 more
Steve
Thanks for the info. I will stick with OEM to start out with. I want the G9 and will make sure I get Panasonic lenses to take full advantage of the stabilization.
kalisti
kalisti Senior Member • Posts: 1,181
sticking to panasonic lens with the G9 will also mean you have DFD working for you!
 kalisti's gear list:kalisti's gear list
Panasonic Lumix DMC-GX85 Panasonic Lumix DC-G9 Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS Panasonic Lumix G 14mm F2.5 II ASPH Panasonic Leica 12-60mm F2.8-4.0 ASPH +3 more
ToxicTabasco
ToxicTabasco Senior Member • Posts: 2,549
Good question.
I'm sure you're aware that Panasonic lenses have lens profiles built into the lens, and lens firmware is updated via camera body.  Thus, it's somewhat different than DSLR.
Anyway when I made the switch to the G9 from DSLR, I also got the fastest zooms that would be ideal for 4K video and photo. The 12-35 and the 35-100 both f/2.8 version II, also have the AF motors that would be needed for the long telephoto shots. These will get you into low light shooting like indoors at night. But for the low light video you'll need primes like f/1.7 or faster for the best low light 4K video.
Good luck on your quest.
 ToxicTabasco's gear list:ToxicTabasco's gear list
Nikon D5500 Nikon D7200 Panasonic Lumix DMC-GX85 Panasonic Lumix DC-G9
