Re: How accurate are new 2019 MBP displays?
Started Sep 10, 2019 | Discussions
gaston la touche Regular Member • Posts: 250
Macs not Maps sorry.
Is it worth calibrating a MBP?
MindInRewind Senior Member • Posts: 1,229
Accurate enough out of the box. they're crisp, clear, bright (maybe too bright), colorful and a pleasure to look at. You will see your images in a whole new light! I remember getting my first retina MBP - I revisited thousands of images that I had not seen in a number of years. They display really does bring your images to life.
However, as others have said in your previous thread, its best to calibrate any/every display you intend to use.
~MIR
Abbott Schindler Senior Member • Posts: 2,753
i just got a 2019. Display looked fine out of the box, and better after calibrating. It came in at about 90% of aRGB color space, vs 100% of sRGB in my older MBPs. If you're planning on using it for photo editing, you should definitely plan to calibrate it.
