T1i question
Started Sep 9, 2019 | Discussions
Iconoscope
Iconoscope Regular Member • Posts: 466
T1i question
I have an old T1i that I really like, but it has a peculiarity: The camera will not power on unless there is an SD card installed.  Is that normal for the T1i?
Also, the SD card release is a bit finicky.
 Iconoscope's gear list:Iconoscope's gear list
Sigma SD9 Sigma SD15 Sigma sd Quattro Sigma fp L
Canon EOS 500D (EOS Rebel T1i / EOS Kiss X3)
strike1 Regular Member • Posts: 115
Re: T1i question
I just tested my T1i and it does turn on when there is no card in the slot. It comes up with a "No card" message.  I cannot say that I find the SD card finicky to get in or out, but this is not a camera that I use regularly now, so it may get more difficult as time goes by.
Beautiful light is a precious thing
Iconoscope
OP Iconoscope Regular Member • Posts: 466
Re: T1i question
Thanks!  I think the previous owner may have damaged the camera card slot, but it does still function.  I may use an SD adapter for a micro sd (TF) and just leave the adapter in the slot.
I like the T1i because it is a low noise champ with a larger photo pixel size than higher density sensors.  Though, Canon seems to have mastered noise reduction better than competitors!
RedFox88 Forum Pro • Posts: 30,738
Re: T1i question
That is a complete myth. Newer aps-c cameras have progress a good deal since your old T1i.
kreygscott
kreygscott Senior Member • Posts: 1,285
Re: T1i question
And yet the packing more megapixels into a sensor no bigger than that of the T1i results in increase noise. So if one were to look at it simply, older models such as the T1i (without the bells and whistles most people crave for and seldom even use) do a much better job when shooting at a higher ISO.
LANDSCAPE, TRAVEL & OUTDOOR PHOTOGRAPHY
My Website
http://kreygscott.com
My Stock Portfolio
http://shutterstock.com/g/kreygscottphotography
My Blog
https://www.kreygscott.com/blog
 kreygscott's gear list:kreygscott's gear list
Canon PowerShot S110 Canon EOS 5D Mark II Canon EOS 7D Canon EF-S 10-22mm F3.5-4.5 USM Canon EF 17-40mm f/4.0L USM +9 more
007peter
007peter Forum Pro • Posts: 12,933
No, not normal, I think there is a SETTING for SD check
I had 3 Canon T1i over the years.  Its a good camera, probably the Lowest Canon DSLR I'm willing to tolerate.  As for the SD card issue, I think there is a SITTING for it.
1. Try CLEAR ALL SETTING under Red Menu
this should remove the SD check.  Anyhoot, I forgot what its call but its a setting feature to prevent absent minded people from shooting without inserting a SD card.
 007peter's gear list:007peter's gear list
Panasonic Lumix DMC-GF6 Panasonic 20mm F1.7 II
