EFM 18-150 EF-S 18-135 Pic?
Started Sep 8, 2019 | Discussions
Poulty Forum Member • Posts: 90
Hi all, has anyone got a pic of the two subject lenses mounted on a M series camera for direct comparison of size? I can’t find one anywhere!
 Poulty's gear list:Poulty's gear list
Canon EOS M50 Canon EOS M100 Canon EOS M5 Canon EF-S 18-135mm F3.5-5.6 IS STM Canon 70-300 F4-5.6 IS II +7 more
Dareshooter Veteran Member • Posts: 4,468
Re: EFM 18-150 EF-S 18-135 Pic?
https://camerasize.com/
Try this site,very useful. I don't have a pic at the moment but I can tell you the size and weight difference is substantial. I used to have the 18-135 on my SL1 and even on that it felt front heavy.I wouldn't entertain it on an M while the 18-150 is available.
OP Poulty Forum Member • Posts: 90
Cheers for the info, doesn’t look like it does lenses though.
Andy01 Senior Member • Posts: 3,672
Try this;
http://j.mp/2PU6X8Z
Colin
 Andy01's gear list:Andy01's gear list
Canon EOS M5 Canon 6D Mark II Canon EF-M 11-22mm f/4-5.6 IS STM Canon EF 100-400mm F4.5-5.6L IS II Canon EF-M 18-150mm F3.5-6.3 IS STM +5 more
Thanks, yep, huge difference. Is IQ similar?
I have never tried a 18-135mm, so I can't say. I have read here several times that many think the 18-150mm is a little better.
Colin
The STM version of the 18-135mm I owned was excellent,no experience with the 18-150 though so can't compare.
David M. Anglin
David M. Anglin Senior Member • Posts: 1,694
Look at www.the-digital-picture.com.  The site is primarily Canon and they do a pretty thorough and comparison of camera and lenses.
 David M. Anglin's gear list:David M. Anglin's gear list
Canon EOS M6 II Canon EOS R5 Canon Extender EF 1.4x III Canon EF 100-400mm F4.5-5.6L IS II Canon EF-M 18-150mm F3.5-6.3 IS STM +6 more
dave_bass5
dave_bass5 Veteran Member • Posts: 7,285
I have both lenses, can do some shots of each on my M50 if you still need it. Obviously the 18-135 will be with the adapter on it.
IME the 18-150 cant touch the 18-135 (mine is the USM Nano) for IQ. Well, it can get close at the wide end but not a chance at the long end.  Plus the 18-135 is of course a stop faster.
Each has its uses though, small and light being the one advantage the 18-150 has, but i only ever use my 18-150 for holidays in sunny places (and didnt bother with it this year).
 dave_bass5's gear list:dave_bass5's gear list
Canon EF 24-70mm F2.8L II USM Canon EF 35mm F2 IS USM Canon PowerShot S110 Canon EOS 5D Mark IV Canon EOS M50 +10 more
Thanks for the offer but I got the pic I was after. Good info cheers.
Robert Wertheimer New Member • Posts: 23
This question was also on my mind.  I'm currently using the 18-135 on a 70d and am seriously considering the new M6 with the 18-150 kit lens, but I really don't want to sacrifice quality for size.  If I'm going to do that, I'll go all the way down to the G5x Mkii.
 Robert Wertheimer's gear list:Robert Wertheimer's gear list
Canon PowerShot G7 X Canon EOS 70D Canon EF-S 17-55mm f/2.8 IS USM Sigma 10-20mm F4-5.6 EX DC HSM Canon EF-S 18-135mm F3.5-5.6 IS STM +1 more
I think I’ll be sticking with the 18-135 for the foreseeable future. One point that crossed my mind was that all lenses I want to use filters on are 67mm, so makes sense.
Is it ?
18-135 = f3.5 - f5.6
18-150 = f3.5 - f6.3
That equals 1/3 of a stop faster as far as i know, not 1 stop. Really 1/3 of a stop is pretty insignificant - both are fairly slow.
Colin
dave_bass5
Andy01 wrote:
Is it ?
Colin
Well no, it’s obviously not, it’s a typo. These things happen
dpeete Contributing Member • Posts: 709
Same, the 18-135mm STM is a hoss.
 dpeete's gear list:dpeete's gear list
Canon EOS M Sony a7R III Canon EOS M6 Canon EF-M 22mm f/2 STM Canon EF-M 18-55mm f/3.5-5.6 IS STM +17 more
I did try the Tamron 18-270 and it was rubbish.
KRRacing
KRRacing Junior Member • Posts: 45
I have compared the 18-135 IS USM with adapter on M50 with 18-150. At 18mm, they are virtually identical in sharpness. At 35mm, the 18-135 is slightly sharper. At 50mm, 100mm and the longest end the 18-135 is significantly sharper and the difference gets bigger as the focal length increases. The 18-150 improves a lot when stopped down to f/8 but still no match to the 18-135. Maybe this is also partly due to the copy variation but I am confident that a good copy of 18-135 IS USM will beat a good copy of 18-150. The problems with the 18-135 USM version are the size and weight which is double the 18-150.
 KRRacing's gear list:KRRacing's gear list
Sigma 24-105mm F4 DG OS HSM Canon 6D Mark II Canon EOS M50 Canon EF 100mm F2.8L Macro IS USM Canon EF 40mm f/2.8 STM +7 more
Ad12 Contributing Member • Posts: 539
Hi
found this on DPR forums a bit back. Edited the cameras in for you.
https://camerasize.com/compact/#776.608,776.25.2,ha,t
Camera size has the option. You can add any camera and lens, and adapter too I think.
 Ad12's gear list:Ad12's gear list
Canon EOS Rebel T7i Fujifilm X-T30 Sigma 105mm F2.8 EX DG OS HSM Canon EF-S 55-250mm f/4-5.6 IS STM Tamron 100-400mm F4.5-6.3 +2 more
Cheers for all the info, I think the 18-135 will be a keeper for me, just waiting on the adapter to turn up. I purchased the 15-45 lei and a second hand 22mm, those with the 18-135 and my 70-300 mk2 should keep me out of trouble for a bit.
Coming from the EF-S Mount I now have a couple of lenses to sit in for a while, those being the 50mm 1.8 and the 24mm 2.8, I don’t think these two will be seeing a lot of use.
Ad12 wrote:
Hi
4th post from the top of this thread
Colin
