60mm f2.4 vs 56mm f1.2 for Portraits
Started Sep 7, 2019 | Photos
markusw Senior Member • Posts: 1,705
6
Maybe it's a bit unfair, but I wanted to understand if the 60mm is good for portraits, standing against the 56mm. So I asked my very best friend Christine to act as a model, and we had a lot of fun and some kind of testing as well
The story's end: The 60 is good, very good. But somehow boring. The 56 has the pop. The cream & keeper machine.
60mm:
It is not a bad lens, obviously. Nice bokeh, sharp images. But now the 56... in the Sony forum, we had a lot of talk about the Zeiss pop. Well, yes, maybe... but here is the Fuji pop!
And, finally, a very personal portrait of Christine (w/ Acros):
Comment & critique:
William Carson
William Carson Veteran Member • Posts: 6,205
Re: 60mm f2.4 vs 56mm f1.2 for Portraits
Yes, I would say the 56mm 1.2 would be the choice for portraits an according to this guy, street photography:
http://www.bing.com/videos/search?q=56mm+f1.2+fuji&view=detail&mid=5C5FB6FB434CED48C60D5C5FB6FB434CED48C60D&FORM=VIRE
Polybazze
Polybazze Contributing Member • Posts: 735
Pretty boring 'street photography' in that video.
IMHO this kind of 'street photography' is much more interesting and doesn't rely on effects like shallow dof:
https://geraldgay.format.com/india#16
Robert A Senior Member • Posts: 2,117
8
The 56mm is ideal If all you care about is blowing out the backgrounds.  But I'm more into environmental work, so the surroundings need to be clear enough to understand.
For me, the best shot is the first one, and it was taken with the 60mm.  There's plenty of snap, and I can see the subject's environment.
Robert A
Fuji XT-2
Fuji X-E2
Epson 3880
 Robert A's gear list:Robert A's gear list
Fujifilm X-E2
Geekapoo
Geekapoo Senior Member • Posts: 2,831
Thanks for the comparison Markus. Much to my surprise, I like the 60 examples you posted much more than the 56. I do own the 60. Not my favorite macro (number was the Oly 60 m43) but do really enjoy using the Fuji 60.
 Geekapoo's gear list:Geekapoo's gear list
Sony RX10 IV Sony a7R IV Fujifilm X-E3 Sony a9 II Fujifilm XF 18-55mm F2.8-4 R LM OIS +15 more
debo Senior Member • Posts: 2,944
+1 and a pic
My 60 was sharper than my 56. The sharpest was my 50. However the rendering is the reason I kept my 56 and got rid of the rest.
smooth
 debo's gear list:debo's gear list
Fujifilm GFX 50R Fujifilm GFX 100S Fujifilm GF 50mm F3.5 Fujifilm GF 63mm F2.8 Fujifilm GF 110mm F2 +4 more
HB1969 Senior Member • Posts: 1,724
Both type of portraits have merit
The beauty of an f/1.2 lens is that you can also use it stopped down. You can't get f/1.2 on an f/2.4 lens.
It all comes down to shooting style. As you say, your preference is for environmental portraits so if you never feel you need wider apertures, there's really no need for the extra expense. Other's may want the flexibility to do both or prefer subject isolation. I think the problem comes when people buy a faster lens and feel that they always have to use it wide open otherwise they've wasted their money.
 HB1969's gear list:HB1969's gear list
Fujifilm X-E1 Fujifilm X-Pro2 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 Canon EF 50mm F1.8 II +12 more
I looked through that gallery and there are examples of both shallow dof (subject isolation) and environmental portraits. One style isn't better than the other. However, I do think that some people use shallow dof as a crutch to deal with difficult backgrounds without really thinking about why and when they should use shallow dof. It can also be a status symbol in others...eg "I can get just a single eyelash in focus because of my fancy expensive fast lens". Of course, these a sweeping generalisations
io_bg
io_bg Senior Member • Posts: 1,548
The 56 is at advantage being two stops faster.
If you stopped down the 56 to f/2.4 or so, would it still have that "pop"?
 io_bg's gear list:io_bg's gear list
Fujifilm X-T30 Samyang 12mm F2.0 NCS CS Fujifilm XF 60mm F2.4 R Macro Fujifilm 16-50mm F3.5-5.6 II Fujifilm 50-230mm II +4 more
Montanawildlives Senior Member • Posts: 1,845
Hmmmm....all this talk of "rendering" and "pop" requires me to ask all you folks to define your terms (which parts of the photograph are you talking about, specifically?).
Otherwise, I'll assume you are just talking about wider aperture and the consequently more blurry background.
I'd honestly like to know if there is something specific you can point to and describe.
Thanks!
 Montanawildlives's gear list:Montanawildlives's gear list
Fujifilm X-T1 Fujifilm X-T3 Nikon D500 Fujifilm 16-50mm F3.5-5.6 II Fujifilm 50-230mm II +7 more
a_c_skinner Forum Pro • Posts: 13,047
They are aspects of the image you find easier to detect once you know what lens was used.
Andrew Skinner
Fujifilm X-T2 Fujifilm X-E3 Fujifilm X-H2 Fujifilm 16-55mm F2.8R LM WR Fujifilm XF 80mm F2.8 Macro +7 more
OfDaniel
OfDaniel Regular Member • Posts: 134
No “pop” at all in any of these samples. Both are fine lenses capable of isolating the subject with great contrast. Just not in these pics....
jjz2 Veteran Member • Posts: 4,396
The background is very busy so yes the 56 will do better with that with a busy close background. This is going to be better for event or wedding shooters facing uncontrolled backgrounds and challenging light. However, if placing your model at certain distances and picked locations or in studio, the gap can easily be mitigated, and the 60 is quite excellent.
I’m usually more focused on location and lighting over shallow dof though. It’s a piece of cake to do shallow dof with a 60 if you do a half body shot and keep the background farther away.
All that being said, I do think the 56 is the better lens but not necessarily for the reasons you’re giving. I think the colors are slightly less contrasty which is generally good for skin tones. It’s also likely sharper stopped down to f2.
The 60 was meant as a hybrid portrait/macro lens so can do both pretty good, but not as specialized as the 56 (esp the apd) or the 80.
 jjz2's gear list:jjz2's gear list
Nikon Z6 Nikon Z5 Nikon Z 35mm F1.8 Nikon Z 24-70mm F4 Nikon Z 85mm F1.8 +1 more
astonehouse
astonehouse Contributing Member • Posts: 518
I actually think the second example on each lens has more 'pop'.. from that perspective seems both these lens can 'pop' and both can look pretty average, probably true of most lenses. Of course 'pop; is completely subjective too.
 astonehouse's gear list:astonehouse's gear list
Fujifilm X-H2 Sony a7 IV Fujifilm XF 33mm F1.4 R LM WR Fujifilm XF 35mm F2 R WR Fujifilm XF 23mm F1.4 R LM WR +4 more
biza43 Forum Pro • Posts: 15,074
Well, if you plan to use apertures higher than f2.4, then the choice is obvious.
www.paulobizarro.com
http://blog.paulobizarro.com/
 biza43's gear list:biza43's gear list
Fujifilm X-T3 Fujifilm X-T4 Fujifilm XF 70-300 F4-5.6 R LM OIS WR Fujifilm XF 16mm F1.4 R WR Fujifilm XF 33mm F1.4 R LM WR +1 more
baobob
baobob Forum Pro • Posts: 18,248
Very interesting comparison showing the big difference between 2.4 and 1.2
Tha said I keep my 60mm that i do love !
Sony RX100 Panasonic ZS200 Fujifilm X-H2S Fujifilm X-H2 Fujifilm XF 10-24mm F4 R OIS +16 more
Gringostarr Regular Member • Posts: 481
Unless you want a totally blown out background at that focal length the 60/2.4 is a very nice lens, especially if you were able to grab it with the most recent discount.
Personally I like much longer focal lengths like the 90/2 or 50-140/2.6 for heavy subject isolation shots where wider angles such as 35 or 60 I would want to incorporate the backgrounds into the shot.
 Gringostarr's gear list:Gringostarr's gear list
Fujifilm X-E4 Fujifilm XF 27mm F2.8 R WR Fujifilm XF 70-300 F4-5.6 R LM OIS WR Fujifilm XF 30mm F2.8 R LM WR Fujifilm XF 16mm F1.4 R WR +1 more
samhain Senior Member • Posts: 1,475
Nothing “pops” like a Sonnar lens. (Though in the right circumstances, others can come close).
That said, both the 60 & 56 are wonderful portrait lenses, and I’ve seen many people who prefer both for portraits.
Personally, I think the 56 has better rendering & smoother micro contrast/transitions.
Cagey75
Cagey75 Senior Member • Posts: 1,347
Thanks!
To me 'Pop' in images refers to an almost 3D-like quality, subjects have depth, great contrast, images don't look flat or lifeless.  You do not need shallow DOF to achieve it with the right lens.
I'm not really seeing that here, no offence to the OP, I guess they meant it more so as shallower DOF - but that doesn't always make images 'pop' - they can still seem quite flat.
If you asked someone not into photography which images they might prefer, chances are they will opt for the ones with more in focus, not the faster aperture ones.  There was a YT video on this a while back, think it was Denae and Andrew did it.  They show a bunch of non photography people various images shot at varying apertures, and most tended to prefer images with more detail in the background, because more of the subjects were in sharp focus.
 Cagey75's gear list:Cagey75's gear list
Fujifilm X-H1 Venus Laowa 65mm F2.8 Macro Fujifilm XC 35mm F2 +1 more
shadowz Contributing Member • Posts: 545
your images at your blog are very engaging.........:)
but this gerald gay images are absolutely stunning.....:)
thank u for sharing....
CONTENT IS KING!
