Pictures a bit yellow-ish?
Started Sep 6, 2019 | Discussions
PhotoBich New Member • Posts: 7
Hi guys,
is it just me or are some of my pictures a bit yellow-ish? I got the X-T100. Maybe it has problems in bright sun light? What do you think?
Shot with the 35mm f2, P-Mode, Auto White Balance.
Thank you!
lewiedude2
lewiedude2 Senior Member • Posts: 2,662
Re: Pictures a bit yellow-ish?
That’s bright sunlight your ya. How did the images compare to what your eye saw?
 lewiedude2's gear list:lewiedude2's gear list
Fujifilm X-T2 Fujifilm 16-55mm F2.8R LM WR
Todd Jones Senior Member • Posts: 1,723
I see that sometimes in the same conditions with my X-T2 but it was worse with the Nikons that I came from. I've made a small tweak in the auto WB (1or2 steps can't remember) away from yellow and I like it and I leave it that way. Never liked the yellow grass look, and I love the way grass looks in Classic Chrome.
Todd
I'm His, John 6:44
Erik Baumgartner Senior Member • Posts: 6,893
It’s been my experience that when faced with lots if green foliage, the Fuji AWB consistently skews towards magenta. It looks like you’ve got some of that going on here. Another good reason to shoot RAW.
Sony RX100 Fujifilm X100V Fujifilm X-T2 Fujifilm X-T20 Fujifilm XF 35mm F1.4 R +5 more
Derek49 Contributing Member • Posts: 556
Never seen magenta skies although some of my pics have skies that are a bit more cyan in colour than I like....
 Derek49's gear list:Derek49's gear list
Fujifilm FinePix F40fd Fujifilm FinePix F450 Zoom Panasonic Lumix DMC-TZ5 Sony Cyber-shot DSC-R1 Fujifilm X10 +28 more
I’m not talking about magenta skies, I’m talking about dominantly green scenery with often overexposed ugly reddish foliage and cold, harsh browns.
Doug Pardee
Doug Pardee Veteran Member • Posts: 9,920
Which film simulation?
Which film simulation are you using? Color renditions vary -- that's the main point of the film simulatiions.
As a couple of examples, Astia/Soft will produce yellowish foliage, while Velvia/Vivid will produce strikingly green foliage.
Co-founder of the open-source LightZone Project: http://lightzoneproject.org/
 Doug Pardee's gear list:Doug Pardee's gear list
Fujifilm X-T10 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 Olympus Stylus 1030 SW Canon EOS 350D +13 more
Ed B
Ed B Forum Pro • Posts: 12,575
PhotoBich wrote:
Hi guys,
Thank you!
On my monitor, the third & fourth pictures look good.
The first two shots and the last shot are pretty easy to fix during post-processing.
Steve Bingham
Steve Bingham Forum Pro • Posts: 27,683
Yep.
1- Shooting jpg? Use velvia film setting
2- Shooting raw, subtract a little yellow. Change the "temperature". Use the slider towards blue or away from Yellow.
And yes, your photos are a little soft and yellowish.
Steve Bingham
 Steve Bingham's gear list:Steve Bingham's gear list
Nikon Coolpix 990 Sony RX100 VII Nikon D810 Nikon D7200 Nikon AF Nikkor 85mm f/1.8D +33 more
OP PhotoBich New Member • Posts: 7
Re: Yep.
I am shooting JPEG, thanks for the advice to use Velvia! I will try it 👍
Re: Which film simulation?
On this day I didn't use any film simulations.
LeicaC Regular Member • Posts: 331
You may also wish to check the Color Shift setting to see if it is centered or has shifted. When I purchased a used X-Pro1 I was puzzled about why my images were cooler than expected, and eventually found that the Color Shift had been tweaked toward blue.
Doug Pardee
The camera's JPEG engine always uses a film simulation. If you didn't set one, it'll use whatever was last used.
According to the EXIF:
Picture #1: Astia
Picture #2: EXIF incomplete
Picture #3: EXIF incomplete
Picture #4: EXIF incomplete
Picture #5: Astia
So they probably all were taken with Astia, which will indeed produce yellowish foliage. Most any other film simulation will give less yellow foliage, and Velvia will give extremely green foliage. Personally, I think Velvia's foliage is surreally green, but an awful lot of landscape photographers like it.
The real lesson here is to pay attention to the film simulations if you're a JPEG shooter. They make big differences in the colors of your pictures. You might find this 12-minute video by Dan Bailey interesting:
https://www.youtube.com/watch?v=JfN9lE9YOkE
