FUJIFILM XF16-80 versus XF 18-135 REVIEW
Started Sep 6, 2019 | Discussions
Fujijitsu
Fujijitsu Senior Member • Posts: 1,055
Re: Looks like I'll stick with my XF 18-135
Yannis1976 wrote:
Fujijitsu wrote:
Thanks for posting the useful review.
As I already have the18-135 and am very happy with it as a travel lens, I think for me there's little benefit in adding the new lens.
Especially as I value thec135 reach over the 16 width.
I used my 18-135 for a recent trip that included car racing and portraits - don't think thec16-80 would be as versatile?
Well at 80mm the new lens is faster and offers better subject separation for portraits.
True - but the 18-135 at the longer end and f5.6 will run it close enough.
XF 18-135 @ 125mm f5.6
 Fujijitsu's gear list:Fujijitsu's gear list
Olympus TG-5 Fujifilm X-E2
sluggy_warrior Senior Member • Posts: 2,583
Looks pretty decent at 135mm. While I love my 18-135, I always thought of it as 18-90 instead. Beyond 100mm, it's just too inconsistent. Interestingly, my lens has a slight stuck/pause around 110mm, then a harder pause at 123mm. I looked at the shots at those FL and found 135mm to be mostly OK, the bad shots are mostly due to nailing the wrong focus point. But those at 123mm are the most inconsistent, half are really sharp like the other FLs, but half are just too soft, even with halo. Wondering if there's something physically in the lens at that pause causing the barrel to shift out of axis slightly.
Kinda OK at 123mm:
and completely failed at the same 123mm:
Really good at 70mm, almost edge to edge:
still OK at 135mm:
In general, I'm slowly learning its strength and weakness, and really enjoying this 18-135. I don't see myself trading it for the 16-80 (I usually shoot panorama so 16mm is still not anywhere wide enough for me).
Fujijitsu
Interesting, thanks for posting.  I've noticed the increased friction as I zoom to full - but only for the last 125 to 135mm, but not noticed any erratic focus.
Mine seems pretty consistent and sharp enough.
Only issue I've had is lens flare and lost contrast with backlight - it needs the ugly hood!
But this is not enough reason for me to change to the mew 16-80 and lose the extra length.
