Canon Colors
Started Sep 4, 2019 | Polls
nnowak Veteran Member • Posts: 9,074
Canon Colors
13
Five cameras from five different manufacturers, one of which is an M series camera.  All images are out of camera JPEGs with all image parameters reset to default.  Focal lengths and apertures were set to be roughly equivalent, but white balance, ISO, shutter speed, and exposure were all auto.  Basically, if the camera was new out of the box, this is what you would get with the factory settings.
Which one is your favorite image?
POLL
Image A
4.3% 7  votes
Image B
44.1% 71  votes
Image C
16.1% 26  votes
Image D
30.4% 49  votes
Image E
5.0% 8  votes
  Show results
Alastair Norcross
Alastair Norcross Veteran Member • Posts: 9,874
Re: Canon Colors
What is "default" for a Canon? My M6 has "auto" and "standard" picture styles, among others. I can't remember which one was set "out of the box". In the old days, it would have been the standard one, but now, I suspect that it's auto. Or at least, it's probably auto in some settings and standard in others. But I can't remember what position the mode selector dial was in when I took the camera out of the box, so I don't know which picture style it would have set. As far as I know, on "auto" the picture style the camera uses depends on what kind of scene it thinks it's shooting. So, in your example, auto might have given the landscape style, or it might have given the portrait style.
As the length of a thread approaches 150, the probability that someone will make the obvious "it's not the camera, it's the photographer" remark approaches 1.
Alastair
http://anorcross.smugmug.com
Equipment in profile
 Alastair Norcross's gear list:Alastair Norcross's gear list
Canon G7 X II Canon EOS M6 II Canon EOS R7 Canon EOS R6 Mark II Canon RF 35mm F1.8 IS STM Macro +24 more
OP nnowak Veteran Member • Posts: 9,074
Re: Canon Colors
The default appears to be "auto" picture style for the Canon sample.  I did factory resets and left the cameras to their own devices.
Martin_ New Member • Posts: 24
Re: Canon Colors
D
Martin
 Martin_'s gear list:Martin_'s gear list
Canon EOS 5D Mark IV Canon EF 16-35mm F2.8L II USM Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM Canon EF 24-105mm f/4L IS USM +1 more
OzarkAggie Senior Member • Posts: 2,153
Re: Canon Colors
So when are you going to disclose the cameras?
 OzarkAggie's gear list:OzarkAggie's gear list
Canon PowerShot A590 IS Canon PowerShot G1 Canon PowerShot Pro1 Canon EOS 10D Canon EOS M +11 more
Thomas A Anderson Senior Member • Posts: 1,360
Nonsense.
Simply an attempt to pass off a survey as a scientific proof. This test only works if the monitors are properly calibrated because otherwise each person sees a different image. Professionals have posted videos and articles discussing Canon’s color accuracy or lack thereof (since Canon is simply more pleasing, not more accurate).
For color critical work I always shoot a profile shot using colorchecker. That’s mainly for artwork or products where you can tell a customer “calibrate your monitor and you’ll know exactly what the colors look like.” “Exactly” is an exaggeration, but close enough without huge expense. For everything else the starting point of Canon colors eliminates a lot of rebalancing and messing about.
 Thomas A Anderson's gear list:Thomas A Anderson's gear list
Canon EOS R
Alastair Norcross
Re: Canon Colors
Thanks. So what was the mode dial set to? Was it a green box mode, P, or something else?
Edit: I see you said the apertures were roughly equivalent, but everything else was auto. Does that mean you used Av mode, and auto ISO? If the picture style was "auto", it would be interesting to know whether the camera selected landscape or portrait (or something else) for that shot. I don't suppose there's anyway to tell?
Alastair
Re: Canon Colors
Yes, Av mode.  I checked the EXIF on the original and I don't see any indication of picture style.
Re: Canon Colors
Depends on the pace of the voting, but probably a couple days.
RobertMachin Contributing Member • Posts: 531
Re: Canon Colors
B and D are great...
C looks like smartphone pic...
rest is blah....
 RobertMachin's gear list:RobertMachin's gear list
Sony RX100 III Canon EOS RP Fujifilm X-H2S Canon EF 50mm f/1.2L USM Canon EF 135mm F2L USM +17 more
lumenite Senior Member • Posts: 1,207
Re: Canon Colors
Color test is always fun. Thank you.
The favorite color is different than Canon color, isn't it?
 lumenite's gear list:lumenite's gear list
Canon EOS-1D Canon EOS M Canon EOS M5 Canon EF 28mm f/1.8 USM Canon EF 50mm F1.4 USM +7 more
Photato
Photato Veteran Member • Posts: 3,151
Re: Canon Colors
6
D and B are the best in that order. * For this particular scene.
B's 4:3 native aspect ratio reveals it could come from a high end smartphone or a m4/3 camera.
IMHO D is superior to B because skin tones are not blown out.
Under challenging light conditions the renditions could be totally different among these cameras.
 Photato's gear list:Photato's gear list
Panasonic LX100 Canon EOS M Canon EOS M6 Canon EOS M6 II Canon EOS R10 +22 more
MyM6II Senior Member • Posts: 2,424
Re: Canon Colors
That is not how it works. The Auto picture style does not select one of the other picture styles. It works independently and the color tone will be adjusted automatically to suit the scene. My experience when shooting landscapes is that "Auto" is a little bit more vivid than "Standard" but not as vivid as "Landscape".
 MyM6II's gear list:MyM6II's gear list
Canon EOS M6 II Canon EOS M6 Canon EOS M200 Canon EOS M50 II +1 more
Alastair Norcross
Re: Canon Colors
Thanks for the clarification. I've never used auto. I mostly shoot RAW, so the picture style is irrelevant to most of what I do. I use a tweaked version of fine detail for my JPEG shooting. In this scene, I wonder whether the camera interpreted it as a portrait or a landscape? Also, presumably, auto adjusts the other parameters as well as saturation. Contrast would be the most obvious parameter for adjustment. It's interesting to see how these five shots use different levels of contrast. C looks almost like it has fill flash, whereas B and D both seem to have fairly high contrast.
Alastair
dpeete Contributing Member • Posts: 746
Re: Canon Colors
I like and appreciate the idea, but find it a little creepy to discuss the skin tones of a Disney princess bust.
With that said, how is the light metering impacting this? There seems to be a huge difference in how the scene is captured based on if the shadow on the left is "brought up or not" (A and C are blowing things out). Should all of the cameras be in some sort of "spot mode" or "evaluative mode" so they aren't metering the scene differently? Or maybe that is part of the secret decoder ring: if some of these are camera phones, they might not have the choices for metering?
FWIW: I recognize these exercises are tricky. I also struggle with how to take comparison photos e.g. do you lock down all exposure settings, or do you try to let the camera do its thing? My guess is the likely answer relates to how does one usually shoot? If you are an Av/Tv shooter, try that, and if you are an M shooter, lock it all down.
 dpeete's gear list:dpeete's gear list
Canon EOS M Canon EOS M6 Sony a7R III Canon EF 85mm F1.8 USM Canon EF 40mm f/2.8 STM +17 more
MAC Forum Pro • Posts: 18,487
waste of time
12
the exposure differences suck
the subject mater sucks
a total waste of time from the Fuji owner - who is a top poster in the canon forum - it's a trap...
 MAC's gear list:MAC's gear list
Canon EOS 7D Mark II Canon EOS RP Canon EOS M6 II Canon EOS R8 Canon EF 70-200mm f/2.8L USM +7 more
Re: Canon Colors
I shoot mostly RAW, too. So I have no idea on how the "Auto" works in detail. I have just played a little with it, and found that it looks a little "different" than all the other Picture Styles. It must have some form of intelligence.
About the poll. It can not be B or C because they are 4:3 and M cameras have a default 3:2 aspect ratio. So we have A, D and E. A does not look good. Neither do E. But E is overexposed (or too much highlight) and I think it looks rather good with a little help. There is something familiar about it. I wonder ....
It IS a trap.
6
Thanks for the clarification. I've never used auto. I mostly shoot RAW, so the picture style is irrelevant to most of what I do. I use a tweaked version of fine detail for my JPEG shooting. In this scene, I wonder whether the camera interpreted it as a portrait or a landscape? Also, presumably, auto adjusts the other parameters as well as saturation. Contrast would be the most obvious parameter for adjustment. It's interesting to see how these five shots use different levels of contrast. C looks almost like it has fill flash, whereas B and D (Canon) both seem to have fairly high contrast.
And I suppose the reason for the severed head is to demonstrate skin tones for which Canon is widely lauded. Trouble is it’s plastic. Skin would be required to compare skin tones.
Canon EOS R
juanmaasecas Senior Member • Posts: 1,496
Re: Canon Colors
D and B.
 juanmaasecas's gear list:juanmaasecas's gear list
Canon EOS M50 Canon EOS R5 Canon EF 50mm f/1.2L USM Canon EF-M 22mm f/2 STM Sigma 35mm F1.4 DG HSM Art +4 more
Picture E -100 Highlight in LR
Picture E. What is wrong with it? Fill flash or deliberately manipulated? The only adjustment I did here is -100 highlight in Lightroom. Before and after pics:
Before
After -100 highlight in LR
