Static white noise with any external mic. (200d)
Started Sep 1, 2019 | Discussions
Cross313 New Member • Posts: 2
Hi!
Whenever an external mic is plugged in, the recording has a strong white noise.
If i reduce the rec. level the noise stays strong and only the actual recording is reduced.
The same thing happens with the mic's dB lever and the high pass lever (rode svm).
I tried with an other mic (rode rycote) and it is the same.
I also testes these mics on my pc and the sound quality was excellent.
Do you guys have any tips?
 Cross313's gear list:Cross313's gear list
Canon EOS Rebel SL2 Sigma 18-35mm F1.8 DC HSM Art Canon EF 50mm F1.8 STM Canon 18-55 F4-5.6 IS STM
pillotu New Member • Posts: 1
Re: Static white noise with any external mic. (200d)
I had this problem 15 min ago. We use two cameras Rebel SL3 with rigs in tripod for TP.
We found out the static noise was due wires and the metallic structure itself, holding the whole thing.
I hope you could fix the problem considering this post it is 7 months old.
