NX1 Vs NX500 for wifi
Started Aug 31, 2019 | Discussions
markyboy81 Veteran Member • Posts: 4,778
I've been using the Samsung camera app to transfer photos and videos to my note 9 and I've found that whilst it usually works well, the NX1 transfers much faster than the nx500. I'm confused as to why this is, as both cameras have identical SD cards inserted. I know the NX1 supports 5ghz WiFi and the NX500 doesn't but I can't imagine this makes a huge difference?
It basically means that it's not worth transferring videos to the nx500 as it's too slow.
 markyboy81's gear list:markyboy81's gear list
Sony ZV-1 Samsung NX1000 Samsung NX3000 Samsung NX1 Samsung NX500 +9 more
Samsung Galaxy Note9 Samsung NX1 Samsung NX5 Samsung NX500
Re: NX1 Vs NX500 for wifi
NX500 is capped at ~3-4MB/s at best (54Mbps will do that to you) while NX1 is apparently (I don't have it to test it) almost three times faster.
OP markyboy81 Veteran Member • Posts: 4,778
Thanks, I can definitely confirm that NX1 is lightening fast transferring over WiFi. (When I can connect that is 😂)
