Buy 16-55mm f/2.8 or primes lenses with X-H1?
Started Aug 30, 2019 | Questions
Kenneth Almquist Regular Member • Posts: 164
I currently use a Nikon D7200, but with the price of the X-H1 dropping to $999 I've decided to try out a mirrorless system.  My initial thought was to buy the 35mm f/2 lens, with the intention of buying the 50mm f/2 lens if I liked the camera.  (I don't do much shooting at wide angles.)  However, if I buy it with the camera, I can get the 16-55mm f/2.8 lens for $699 (rather than the regular price of $1199).  Any thoughts on which way I should go?
 Kenneth Almquist's gear list:Kenneth Almquist's gear list
Nikon D7200 Fujifilm X-H1 Nikon AF-S DX Nikkor 35mm F1.8G Nikon AF-S DX Nikkor 18-300mm F3.5-6.3G ED VR Fujifilm 16-55mm F2.8R LM WR +2 more
Fujifilm 16-55mm F2.8R LM WR Fujifilm XF 35mm F2 R WR Fujifilm X-H1 Nikon D7200
dual12 Senior Member • Posts: 1,276
Re: Buy 16-55mm f/2.8 or primes lenses with X-H1?
Those primes are tiny. That zoom is not. The 18-55 is considerably smaller than the 16-55. If size matters, you shouldn't buy the 16-55...unless you plan to immediately resell it.
 dual12's gear list:dual12's gear list
Fujifilm X-E1 Fujifilm X-E3 Fujifilm X-H1 Fujifilm X-T3 Fujifilm GFX 50R +10 more
DarnGoodPhotos Forum Pro • Posts: 11,881
Get the zoom. If you don't like it you can resell it for at least that price.
FYI, you can fid a nice used 35f2 for around $250.
www.darngoodphotos.com
 DarnGoodPhotos's gear list:DarnGoodPhotos's gear list
Fujifilm X100V Fujifilm X-T5 Fujifilm XF 18mm F2 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8 +3 more
KarenImages Forum Member • Posts: 59
I have the 16-55mm and I'm so glad I got it.  I don't like switching lenses around!
I came from a Nikon, and this thing is light to me.
maxxxx Senior Member • Posts: 1,179
At that price you probably can sell the 16-55 without loss or even small profit if you don't like it. It's a heavy but good lens.
 maxxxx's gear list:maxxxx's gear list
Sony a7 IV Sony 16-35mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* Tamron AF 28-200mm F/3.8-5.6 XR Di Aspherical (IF) Macro Sony FE 200-600 F5.6-6.3 Tamron 70-180mm F2.8 Di III VXD +1 more
McNoodle Forum Member • Posts: 86
I just got the 16-55mm yesterday. Incredible lens. I already have the 16, 23, 35 and 80mm I now find myself wondering if I should sell the 23 and 35. They are very small and light which the 16-55 is not. I'll likely keep them, but the thought is there FWIW.
 McNoodle's gear list:McNoodle's gear list
Fujifilm X-Pro3 Fujifilm X-T5 XF 90mm Fujifilm XF 16mm F2.8 Fujifilm XF 16-80mm F4 +4 more
Giovanni_1968
Giovanni_1968 Veteran Member • Posts: 3,916
I am very much into getting the X-H1 with the 16-55 (if still available by Sept 15th or so) but wondering how does the 16-55 performs bokeh wise should I use it for casual semi-candid portraits with busy backgrounds
Giovanni - 70% GAS affected
http://www.flickr.com/photos/giovanniaprea/
Nikon D800 - Nikon D2Xs - Fuji X-Pro1 - Fuji S5Pro - Nikon F - Nikon F3
J.A. Michell Gyrodec - Audio Research SP-9 - Aeron AP-890 - JBL4311B
JN70CN - 14.14.30E 40.32.40N
 Giovanni_1968's gear list:Giovanni_1968's gear list
Fujifilm FinePix S5 Pro Nikon D2Xs Nikon D800 Nikon Z6 II Nikon AF-S Micro-Nikkor 60mm F2.8G ED +20 more
OP Kenneth Almquist Regular Member • Posts: 164
Good point.  I'll probably stick to using the Nikon for travel because Fuji doesn't have an equivalent to Nikon's 18-300mm, so size isn't too critical.
Erik Baumgartner Senior Member • Posts: 6,893
”OK”, but the primes generally win here. Under the right conditions the 16-55 bokeh can be just fine, especially if the subject is close and the background is at a distance, but the bokeh can often be a bit “nervous” with a busy background at the wrong distance. The 16-55 is a killer lens, and excels at almost everything, but if you primarily want an ideal semi-candid portrait lens, you probably want the 35 f/1.4, 56 f/1.2, or 90 f/2 depending on your preferred working distance. The 50-140 f/2.8 zoom can be also quite good for this.
Sony RX100 Fujifilm X100V Fujifilm X-T2 Fujifilm X-T20 Fujifilm XF 35mm F1.4 R +5 more
photolando Veteran Member • Posts: 3,423
I got the 18-55 as a kit with my H1.  It was a good lens but the 16-55 is so much better.  Yes, a bit heavier but that's the price you pay for constant 2.8 throughout the zoom.  It is a bit sharper if you really look.
The H1 is body stabilized so you don't need the OIS.  The 16-55 does not have it.  If you plan to get say a T3, which I own as well, then you may want to take that into consideration.
For the price, the H1, grip and 16-55 combo is a great deal!  I paid $1,000 more for that setup a year and half ago.
Mike
 photolando's gear list:photolando's gear list
Fujifilm X-H1 Fujifilm X-T3 Fujifilm XF 10-24mm F4 R OIS Fujifilm XF 56mm F1.2 R Fujifilm XF 50-140mm F2.8 +3 more
Thanks for all the replies.  I think I'll go ahead and order the X-H1 with the 16-55mm zoom.  It seems like the price on the lens is too good to pass up.
Lens_Goat
Lens_Goat Contributing Member • Posts: 811
With the current bundle deal I would opt for the 16-55 no questions asked. If you change your mind later on, you can throw the 16-55 on eBay and recoup what you paid for it (and then some).
 Lens_Goat's gear list:Lens_Goat's gear list
Fujifilm X-T3 Fujifilm GFX 50S II Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 50-140mm F2.8 Fujifilm 16-55mm F2.8R LM WR +2 more
lewiedude2
lewiedude2 Senior Member • Posts: 2,662
The below were test shots to show bokeh with rather close subject matter. The exif will tell you what the FL was, I can’t recall. But, I think the bokeh is quite nice and the lens is incredible
 lewiedude2's gear list:lewiedude2's gear list
Fujifilm X-T2 Fujifilm 16-55mm F2.8R LM WR
CaptainNoddy Forum Member • Posts: 68
The XF16-55 is a great lens and X-H1 is the best camera to accompany with this lens due to IBIS and the similarity in size.
And you can't be wrong if you get it at $699..... Even if you eventually don't like it and you can sell it second hand without loss at similar price range....
However, such combo is very very big in in terms of Fuji mirrorless camera which you cannot benefit from switching from DSLR. If you like primes such as the F2 primes, I suggest you should get an X-T3 or X-T30. The speed and portability may just surprise you
 CaptainNoddy's gear list:CaptainNoddy's gear list
Fujifilm X-E3 Fujifilm X-T3 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +3 more
I shoot a bunch of stuff at night (sample below), so IBIS is important to me.  I'm less interested in reducing size/weight than in just seeing what mirrorless technology can do.
Emile15 Senior Member • Posts: 1,769
I love (almost) all my Fuji lenses, but as far as I am concerned the only answer to your question is to get the 16-55. It is a fantastic lens, especially on the XH1 (+ibis).
 Emile15's gear list:Emile15's gear list
Fujifilm X100T Fujifilm X-T4 Canon EOS R5 Canon EOS R7 Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +12 more
Mebyon K
Mebyon K Contributing Member • Posts: 842
I already owned the 16-55 f2.8 which i used with my X-T1, after buying my X-H1 last August I wrote, on other forums, that after using the X-H1 with the 16-55 f2.8 I considered it to be a marriage made in heaven. A year later I am even more firmly convinced that it's true.
Mebyon K
 Mebyon K's gear list:Mebyon K's gear list
baobob
baobob Forum Pro • Posts: 18,248
16-55mm with the camera !
Sony RX100 Panasonic ZS200 Fujifilm X-H2S Fujifilm X-H2 Fujifilm XF 35mm F1.4 R +16 more
caesarb Contributing Member • Posts: 606
Hi.
The 16-55 has an amazing potential. Please kindly consider it. You are getting a bag of very good primes with this lens.
I got 16-55 on a Fuji sale some time ago. Once I took sample shots with it, I have understood why so many people here had called it a "bag of primes." I really got four prime lenses in one. I have paired it with X-T2, and this is my go to kit now.
Please kindly check out the link below – for comparison between 16-55 and various primes, with full-size JPGs included. Comparing those sample images made me buy the 16-55. My own images taken with 16-55 have further confirmed the superb optical qualities of the lens.
https://www.prophotonut.com/2015/04/30/zoom-or-prime-lenses-for-portraits-with-fuji-x/
Also, just wanted to mention this... one can "test" various Fujinon lenses here:
http://fujifilmxmount.com/comparison/en/test-our-lenses/
Thank you and kindest regards.
e4rauzer New Member • Posts: 10
I have most of the Fuji primes but have foundthe 16-55 on my XH1 most of the time since I got it..especially for travelling when I dont want to keep switching out lenses. I was worried about the size of the combo when I was still thinking of pulling the trigger but I have no issues with it now at all. I've travelled to South America and around Asia with it and was never really concerned about its size. For my style of shooting, the IBIS and ergonomics simply make up for any size disadvantage (this coming from a XT10/XT30 user!).  Love this lens for the IQ and versatility.
