What to choose for photography? G95 (90) or G9
Started Aug 30, 2019 | Discussions
st-yorgen New Member • Posts: 5
Panasonic Lumix G95 vs G9 (G90 vs G9). There are many reviews and discussions on the Internet, mainly from theorists. I would like to hear reviews about the quality of the photo G95 (90) including JPEG Sooc from real users. I like the size and presence of a flash in the G95, but the G9 is praised more. It seems that they have the same matrix, but the processor at G9 is more powerful. I plan to use for travel and auto-moto sports in smooth dynamics. Are there those who were able to compare both?
Panasonic Lumix DC-G9
jonno35 Contributing Member • Posts: 884
Re: What to choose for photography? G95 (90) or G9
I too have looked into these two, my conclusion is that as much as I'd like it the weight of the g9  makes it not very suitable for travel as it weighs as much as my old Nikon dslr, plus no flash means carrying a flash which I might not want to depending how mobile I want to be.
 jonno35's gear list:jonno35's gear list
Panasonic FZ1000 Panasonic Lumix DC-G9 Panasonic Leica 12-60mm F2.8-4.0 ASPH Panasonic 14-140mm F3.5-5.6 II +3 more
grcolts Veteran Member • Posts: 3,914
The G9 certainly weighs more but if you shoot with larger lens the camera is rock steady to handhold. Plus, I use the Panasonic 25/1.7 with it a lot and it then becomes much lighter to carry afield.
deserteagle56 Forum Member • Posts: 85
I can't speak to the G95.  But a few months ago when I decided it was time to upgrade from my GH2 I too was concerned about the size and weight of the G9.  After a lot of research I decided to go for it, and now I'm glad I did.  Yes, the G9 is bigger and heavier than the GH2 - but it fits my hands so well that I don't notice the size and weight.  The size, and the layout of all the controls, seems to be custom made for me.  Love this camera, and the OOC jpegs are so nice that I don't have to do nearly as much tweeking as I did with the GH2 shots.
Dick Barbour
Dick Barbour Senior Member • Posts: 1,880
8
I had previously had the G9 and not-so-wisely sold it to go to FF, which I soon learned wasn't right for me. I now have some Fuji gear which I really like, but wanted a MFT camera and the  Pan-Leica 100-400 which is much lighter and with more reach than its Fuji counterpart. Since the G95 had just come out and seemed promising, I got it and the 100-400. The G95 was a disappointment both in build and image quality. The photos even at moderate ISOs didn't look as good as I remembered the G9 to be and I didn't think it was the lens. I returned the G95 and got the G9 again and am very happy with it and the 100-400. Yes, it's a little heavier but is nice to handle especially with a large lens. Its build quality is much better than the G95 and the images are definitely better. Not sure why, but I read somewhere that it's not the same sensor and I can believe it. I can't help with the SOOC jpgs because I only shoot raw. No contest here, go with the G9.
 Dick Barbour's gear list:Dick Barbour's gear list
Panasonic Lumix DMC-ZS50 Sony RX10 IV Sony a6500 Panasonic Lumix DC-G9 Sony E 10-18mm F4 OSS +4 more
cambirdee Forum Member • Posts: 50
6
No, G9 has a better sensor with higher dynamic range. And the difference is significant: https://www.dpreview.com/reviews/image-comparison/fullscreen?attr144_0=olympus_em1x&attr144_1=olympus_em1ii&attr144_2=panasonic_dcg95&attr144_3=panasonic_dcg9&attr146_0=200_5&attr146_1=200_5&attr146_2=200_5&attr146_3=200_5&attr404_0=1&attr404_1=1&attr404_2=1&attr404_3=1&normalization=full&widget=675&x=-0.21490072043577582&y=-0.6281680259580813
Haven't used G90/G95, but considering that it currently retails for almost the same price as G9... Can't see how buying it can be justified (and it's not only sensor that is different: also burst shooting speed, autofocus, etc).
 cambirdee's gear list:cambirdee's gear list
Olympus OM-D E-M10 II Panasonic Lumix DC-G9 Panasonic Leica 100-400mm F4.0-6.3 ASPH
photofan1986
photofan1986 Veteran Member • Posts: 3,841
Go for the g9, no question. At first, I thought the camera might be too big, but after a week of use, I think size is perfect for optimal ergonomics. I also own the G85 which is a great camera, but the g9 is on another level for several key reasons.
And for a very similar price (g95 vs g9), the g9 is a much better deal.
If you really want the g95 size and weight, I'd go with the G85 which is a much better deal.
 photofan1986's gear list:photofan1986's gear list
Fujifilm FinePix F200EXR Panasonic Lumix DMC-GM5 Sony a7R III Olympus E-M5 III Panasonic Lumix G 20mm F1.7 ASPH +15 more
LeanderOne
LeanderOne Regular Member • Posts: 267
G95 or g90 is my dilemma too....
As I already use the hefty 915g FZ2500, the weight of the G9 is not an issue. Also, it's only 122g more than the g95.
However if you would need to start carrying a flash around (as I would) due the absence of a pop-up on the g9 , this means an extra few hundred grams, plus be bulk of the flash and it's batteries, plus maybe a bigger bag to put it all in.
So overall system weight and bulk could be an issue for you, and would be for me.
As for mage quality, there seems little question (as pointed out above) that the g9 has a newer and better sensor, and this shows in the images that I have looked it. That said, after admittedly no hands-on experience, but only extensive pixel peeping, includiing using DPR's comparison tool, my conclusion is that the image quality gap between the g9 vs g95 is quite small.  It also appears to me to be definitely less than that between the G95 and the G85 ( which I also considered), and indeed of that between the G85 and my current FZ2500.
So personally I am inclined toward the G95 at present. Plus I think I might prefer its ergonomics (two separate dials vs the G9 top plate LCD). The G95 also has the new Light Composition feature and can do panoramas, unlike the G9. No doubt the G9 is more rugged, but what I've outlined make it a second choice for me at least.
Good luck with your choice - it is a difficult one for sure.
 LeanderOne's gear list:LeanderOne's gear list
Panasonic Lumix DMC-FZ300 Panasonic FZ2500 Olympus TG-5 Panasonic Lumix DC-G9 Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS +1 more
Milan SK Contributing Member • Posts: 504
You plan to use the camera for travel and auto-moto sports in smooth dynamics.
I would choose G9 for the reason of the number of focus points that are 225 while g95 has only 49 focus points. G9 has therefore better tracking capabilities with a much better processor. I have held both g95 and g9 in my hands and G9 has better ergonomics, better grip and unlike g95 it has a focus joystick at the very right place (though not with diagonal direction...). I can remember when I used on camera flash last time about five years ago.
The choice is yours.
Milan
OP st-yorgen New Member • Posts: 5
Thanks everyone! I really appreciate that you share your experience and opinions. I also think that the G9 is a more capable camera. But given its size and the cost of the lens, the idea suggests itself that perhaps it is worth adding Nikon Z6 to the selection. The sizes are comparable, and taking into account the fact that I'm interested in about 16-300mm. lens sizes are not very annoying. What do you say to that?
Ondra J New Member • Posts: 3
They had bracketing on by mistake and that reduces the bit depth to only 10 bits. They promised to re shoot these raws.
I still think the G95 sensor is worse though.
 Ondra J's gear list:Ondra J's gear list
Panasonic Lumix DMC-GM1 Panasonic G85 Panasonic Leica Summilux DG 25mm F1.4 Panasonic 12-35mm F2.8 II
I want to upgrade from G80 and it's not an easy decision. After carefully assessing high iso raws from Imaging Resource I concluded G9 has better sensor than G95.
liquidsquid Senior Member • Posts: 1,961
Great story! Thanks for sharing as I likely would have done the exact same thing given time.
My pictures...
{Whoops, dead link!}
 liquidsquid's gear list:liquidsquid's gear list
Panasonic Lumix DMC-G1 Panasonic Lumix DMC-GH2 Panasonic Lumix DC-G9
I already had a D750 16-35f4, 28-70f2.8. and 28-300 ... It was good, but the weight and size ... I sold it and bought a kit G85 kit 12-60, PL8-18 f2.8-4, 14-140 f3.5-5.6 + 35- 100f2.8. It became much easier to move around and I got more shots. But the quality didn’t suit me less, especially in conditions different from a sunny day. Some reviews praised the G95. They wrote that his Jpeg was even slightly superior to the G9. But there are very few examples. Therefore, I wanted to hear different opinions. Perhaps all the same, Z6 ...
bradevans
bradevans Senior Member • Posts: 1,029
The G9 is one line higher than the G5/6/7/8/85/90/95 cameras, so it should be expected to do more / do it better
it’s very responsive. I’ve become accustomed to that - I notice when I bring along my G85 (which is no slouch) or my G7(converted to IR) and they seem sluggish. To be fair they also seem light
I’ve gone from G5 to G7 to G85 to G9 each one was a tangible jump from the previous
so it’s more can you live with the price and the size of the G9, because the performance is there
the G95 should beat the G85 but the G85 might be the best value
 bradevans's gear list:bradevans's gear list
Panasonic Lumix DMC-G5 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-G7 Panasonic G85 Panasonic Lumix DC-G9 +14 more
G Rash Senior Member • Posts: 2,890
The lack of a flash wouldn't be so annoying if Panasonic had included the hotshoe contact to power a little flash like the one that came with the GM5 or the ones that come with the Pen F and EM1ii.  My GX8 has that contact, even my GX85 has that contact and both can use the little (and easily pocketable) flash from the GM5 as well as the slightly larger but more capable Oly flash.  I foolishly assumed that since the GX8 and GX85 both had that contact, the G9 would as well.
I like the G9, but for travel, I often just take the GX8 and the little flash and leave the G9 home.
Gary
 G Rash's gear list:G Rash's gear list
Olympus PEN-F Sony a7R III Canon EOS R5 Nikon D610 Panasonic Lumix DMC-GX8 +3 more
BGood11 New Member • Posts: 1
I would point out however that the G85 and G95 are very different cameras as the G95 is significantly upgraded.  If you are deciding between those two, just look at the comparison specs.  For instance the G95 has 20 Megapixels as compared with 16 in the G85 and there are other very important differences as well
FunGuy66
FunGuy66 Regular Member • Posts: 304
Resolution, USB charging and video features aside, I don't see many differences between them. (And the video changes are not all for the better, e.g. more crop in 4K with the G95 vs G85.)
https://www.dpreview.com/products/compare/side-by-side?products=panasonic_dmcg85&products=panasonic_dcg95
IMO the current $300 gap between them is not justified, and nor is the lack of a gap between G95 and G9 (both around $1000, except the G95 comes with the 12-60 kit lens).
So who's the G95 for? As a G85 owner I see no reason to upgrade and from what I've seen the sentiment is common.
A new user can get almost as much camera for 30% less by opting for the G85. One on a tight budget can do reasonably well with a G7 ($450 w/ 14-42) or GX85 ($500 w/12-32 and 45-150 -- I don't even need this at all but I'm still tempted).
A more advanced user likely doesn't need the 12-60 and would be better off with the G9.
So the G95 offers what, for whom? I see a camera for people who would be well served by the G85 but who want a bit of future-proofing or one of the new FHD video modes, or one for potential G9 buyers who find that camera too large and don't need its advanced video features. I'm guessing this doesn't amount to many sales.
Cyvan Regular Member • Posts: 447
I'm sure the OP has already made up his mind and been merrily shooting with it since this was posted 10months ago
 Cyvan's gear list:Cyvan's gear list
Panasonic Lumix DMC-GX8 Panasonic G85 Panasonic Lumix DC-G9 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko Digital ED 75mm F1.8 +7 more
FunGuy66
I don't see anything wrong with reviving a thread like this. The basic question of this vs. that model remains topical as long as the models in question are still current, though pricing changes can shift the terms of discussion some. In this case, it seems prices have barely budged in months.
