John K wrote:
mawyatt2002 wrote:
This is for those few folks "in the know" that may want to delve into this micron and sub-micron level at a more reasonable cost, thus the title "Extreme Macro", certainly not for shooting bees in the garden!
Oh I don't know. I think being able to take shots like this hand held, without cropping in post, is pretty extreme...
As mentioned "Stacking" & "Extreme" here implying high magnifications with DoF of 3 microns (or less) and even involving micron and sub-micron levels of stacking, not single shot images (handheld or not) at very high effective apertures where serious diffraction limits IQ.
As you already know stacking is a very valuable method of getting around the DoF and aperture trade off, this is why many new cameras have a focus stacking routines built in. We're talking about images where the entire subject is "in focus", not just the front.
Anyway, it's kinda fun designing these on a budget utilizing surplus stuff instead of just purchasing the necessary equipment as would be done before I retired. Advanced chip designers are highly valued and very expensive, so time needs to be utilized designing chips, not fixtures
That's what I mean -getting into it for the gear. I get it, I really do. Being a network engineer and designing some of my own circuits, I realize how much fun it is to hack something together. But I'm just more concerned with what I can produce with the kit and the techniques. Publishers aren't interested in how I take my photos unless those images are good enough to get their attention.
This stuff is quite far from "hack something together", utilizing much more advanced circuits than what's normally even available commercially. In fact a colleague has suggested I patent one of these circuit/concepts, I didn't get 30 US Patents granted for generally doing stuff that's considered "prior art" and "hacking something together!!
I don't publish my images, most are not for general public viewing for obvious reasons. A few can be viewed at some major US technology companies and USG agencies. We've used these images in our presentations and proposals, a colleague has a 55 inch OLED display (soon an 80) that he's using to show these...they certainly look good on that display!!
BTW, deconvolution post processing is something you should look into, might help with the DoF and Diffraction induced image degradation trade-off due to small apertures. You need to know some specifics (Point Spread Function) about your lens and sensor though.
Thanks, I'll look into it! Topaz Labs recently released some new plugins and among them was Sharpen AI. It does a pretty good job of cleaning up my images. I suck at post processing, and it's something that I've started to invest some time in. Although I think I could make this next shot even better this is my latest attempt at a 5x shot @ F11. Single frame hand held and not cropped in post.
Impressive shot, but 5X @ F11 is an effective aperture of F66!! That's probably much too far into diffraction to be corrected in post with the available tools, my feeling is ~F25 is more realistic to expect post for help. Try looking at this image on a 55 inch screen or bigger (like 80 inch), you will see the effects of diffraction. BTW the semiconductor folks have been doing similar techniques for over 30 years (beating diffraction), and the stuff they are doing now is just beyond comprehension, even for folks in the know. It's like, "you can't do that!!", but they do
I get what you're diving into, but it would be great if you also work on your lighting and composition at the same time as all that fancy photo stacking gear. Might be able to produce some really fascinating images that are well lit, and well composed, that get published...
I got the lighting figured out long ago when attempting to image chips with thousands of tiny (40um) spherical mirrors called solder balls, they reflect anything and everything and required absolute uniform lighting which was achieved with quadruple diffusion levels. Also have the "composition" in hand as I normally don't image chips "flat" but at an angle to give a 3D perspective which requires significant depth, these are often used in presentations and proposals and must "look nice" as well as being technically correct and precise.
Getting to sub-micron levels (not talking about it, or "hacking" something together thinking you are at these levels, like using ridiculous levels of rail motor micro-stepping and gearing and thinking you can get a few nanometers actual resolution with many moving mechanical interfaces) when focus stacking is not trivial. Things like, temperature gradients, AC, sounds, walking nearby, airplanes, traffic, doors, fans, pumps, camera mirror/shutter and so on, all play to ruin your stacks at higher magnifications. But when you get it right the effort proves worthwhile to those that understand an appreciate what they are viewing. Kind of like your bee images, to the lay person that's just another bug image, but to someone more involved, that's a great bee image!
Should mention, one of the very reasons for undertaking the effort for these alternate stacking techniques (Piezo and VCM) is for massive Stack and Stitch efforts. Often these sessions involve taking 6,000 or more images at high magnifications and resolution (Mitutoyo objective lenses). Time between shots becomes a major issue, if say you allow 15 seconds between shots that's 25 hours for a 6000 image session! Much effort has been placed upon reducing this time factor with a goal (already achieved) of less that 2 seconds per shot, which equates to a more reasonable 3.3 hours for the 6000 image session. To do this you must eliminate all sources of vibration including camera and focus rail & motor induced. The camera area has been solved with fully electronic curtain shutters (both front and rear), the rail movement & motor is a work in progress and with the latest Trinamic based controllers adapted for macro use have achieved sub 2 second intervals. Now the bar has been raised to ~ one second intervals and the Piezo and VCM are being investigating for use.
Here's a brief video showing a custom stepper motor controller I've developed awhile back to show the effects of rail induced movement vibration reduction. This involves precisely controlling the velocity, acceleration and position profiles and the stepper motor current waveform and timing. The video shows an effective magnification of 800X on a Wemacro Vertical Stand sitting on a kitchen table (not the most stable environment, but will certainly show the effects of any vibration), so any movement/vibration effects are easily detected.
For some reason this won't copy from Google, so try from the PM link
https://drive.google.com/file/d/19wE-B-dMesEXNtEZ552h_VnpWOjA0n0B/view?usp=sharing
http://www.photomacrography.net/forum/viewtopic.php?t=39396&start=30
Anyway, this has been a long undertaking to get to this level of precision and resolution, and still achieve reasonable times between shots.
Best,
Research is like a treasure hunt, you don't know where to look or what you'll find!
~Mike
