Re: Panasonic G9 bird/wildlife shooting - how to improve autofocusing technique?
Mzro wrote:
Hey, really would like to get a good advice on subject!
I recently bought G9 with 100-300mm mk2 lens and started to shoot birds in wildlife. I am still learning all capabilities of the camera.
Aside from developing proper bird watching and bird tracking techniques, the most thing I am struggling with is aufocus. Damn, it misses a lot! And even when it seems I have a small bird in focus, after review I often find the focus was slightly off.
I know that 100-300mm lens is just an affordable super-zoom and I shouldn't expect top sharpness and image quality from it. But still want to get the most from the camera and the lens.
1) For the most time I use really small 1-area AFS as I find it the most reliable and quite fast. Should I use custom AFF focus settings instead?
No, stick with AFS but instead of 1-area try using the custom multi diamond. set up your control dial to the bottom item on the menu so that you use it to be able to quickly enlarge and reduce your focus area. I tend to keep the diamond full size for BIFs but =having the option to reduce it quickly to a smaller size is very useful.
2) Is it possible to have a 20x zoom with auto-focus?
I don't understand the question
3) Is it possible to enable focus peaking with auto-focus?
No
4) How I can assign quick focus type switching (like quick switching from custom-multi to 1-area. Should I use C1/C2/C3 dial modes to create custom shooting profiles?
see 1 above. I don't use C!/2 and 3 because I find it takes me longer to think about which setting than it does for me to instinctively change settings.
5) When I should use AFC for moving creatures?
When you've master AFS
6)Should I always use AFC for burst shooting?
You'll be able to decide that for yourself once you have mastered AFS
Any advice or hints regarding to shooting birds and wildlife with G9 are very welcome! Thanks.
A few more. blue sky is OK but complex backgrounds are more difficult. If you are missing focus completely try refocusing closer between you and the subject before focusing on the subject.
When you are using the small box you may focus but on a fast moving target you may move very slightly but enough to take you out of focus. Practice, practice, practice
