G9 compared to E-M1 continuous focus while zooming
Started Aug 29, 2019 | Discussions
Xbot Regular Member • Posts: 196
I'm coming from a Fuji X-H1 and 50-140 2.8 zoom lens.  When continuously focusing WHILE zooming in burst mode (mechanical shutter, not electronic shutter)--say continuously focusing on a runner coming toward me starting out at the long end of the zoom and then widening as the runner gets closer--my X-H1 does a pretty good job maintaining focus WHILE zooming.
I recently tried a Panasonic G9 with the Olympus 40-150 2.8 doing the same thing, and the camera simply cannot maintain focus at all while zooming (this is actually mentioned in the instruction manual I think).  It's fine otherwise, just not WHILE zooming at the same time.
Is the Olympus E-M1 II any better at this than the G9? I'm wondering if it might be since like the X-H1 it uses PDAF instead of the contrast system of the G9.  Anybody got any experience with this combo?
Fujifilm X-H1 Olympus 40-150mm F2.8 Pro Olympus E-M1 II Panasonic Lumix DC-G9
JosephScha Veteran Member • Posts: 7,249
Re: G9 compared to E-M1 continuous focus while zooming
Well, it's a difficult thing to do while zooming with a lens that changes its focus as you zoom.
Even so I think the EM1 MkII with its new firmware should do better. It has phase detect cells on its sensor, it really might do better.
By the way, I own a G9. But I've never tried your experiment.
js
 JosephScha's gear list:JosephScha's gear list
Panasonic Lumix DC-G9 Panasonic Leica Summilux DG 25mm F1.4 Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S Panasonic Leica DG Summilux 15mm F1.7 ASPH Panasonic Lumix G 42.5mm F1.7 +7 more
OP Xbot Regular Member • Posts: 196
I don’t think the Fuji 50-140 is Parfocal either.  But I could be mistaken.
whumber
whumber Veteran Member • Posts: 4,371
A little bit better, but all the m43 bodies are awful at maintaining C-AF while racking zoom. I know for sure the X-T3 does this quite well and I've heard the latest Sony bodies handle it well but I've only shot the A9/A7III with primes so can't really comment from personal experience. Also, pretty much any DSLR will do this without blinking.
 whumber's gear list:whumber's gear list
Fujifilm X-T1 Olympus OM-D E-M1X Olympus E-M1 III OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro +10 more
(unknown member) Forum Pro • Posts: 19,317
never had a problem zooming with caf on my em12 seems good to me. even video af is great.
Don
Olympus EM5mk2 ,EM1mk2
http://www.dpreview.com/galleries/9412035244
past toys. k100d, k10d,k7,fz5,fz150,500uz,canon G9, Olympus xz1 em5mk1
Thanks.  Are you saying this from experience with m43 bodies?
Don, is this true with longer zooms as well?
whumber
Yes, I currently own the G9, E-M1ii, and E-M1X. None of them can maintain accurate C-AF while racking zoom; at best I see something like a 20% hit rate when racking zoom. Most of my experience in this regard is with the 40-150 PRO, I don't have any meaningful experience with the 100-400 PL or any of the other tele zoom lenses other than the Panasonic 35-100. On the Fuji side, OTH, I spent some time with the X-T3 plus the cheapo 50-230 and it had no issues maintaining good focus while racking zoom.
Androole Senior Member • Posts: 1,455
The PL50-200mm is apparently parfocal (or nearly so), which would presumably help significantly with this process.
 Androole's gear list:Androole's gear list
Olympus Stylus Tough TG-850 iHS Panasonic Lumix DMC-GX7 YI M1 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G Vario HD 14-140mm F4-5.8 OIS +2 more
Brian Wadie
Brian Wadie Forum Pro • Posts: 11,017
I've owned both and agree with the comments that neither is that good but the EM-1mk2 + v3.1 is better
If I need to maintain focus whilst zooming I find constantly half-pressing the shutter button does a pretty good job as the speed of refocus is near instantaneous.
(My best experience of maintaining zoom focus was with my 7Dmk2 + lenses such as the 400 f5.6L and 70-300LIS)
So much to learn, so little time left to do it!
 Brian Wadie's gear list:Brian Wadie's gear list
Olympus E-M1 III OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Olympus 12-45mm F4 Pro +1 more
Bummer. That matches my experience with the G9+40-150 compared to the X-H1+15-140mm. Oh well.
I have focus disconnected from the shutter button, but the same principle should apply.  I guess I'll have to give that a try.
works well with my 14 150 mk1
Don
zoom focus with the 400 5.6 that would be a leejay answer
Don
Brian Wadie
Don
thanks Don, old age and stupidity again, should have read 100-400 f4-5.6 L - how embarrassing
Don
I have a new phone and I'm so tired of it puting words in My sentence after I have hit the go button
Don
Brian Wadie
Don
Don
I can't even claim that Don, I'm prone to forgetting what I writing half way through, it always makes sense when I check before posting (I guess because I knew what I meant to say )
I even have to check in the mirror in the morning to make sure I woke the right person up!
Brian Wadie wrote:
Don
Don
LOL I get bagged all the time on these forums because im hopeless at writing skills, even my daughter complains, but at least i can lift heavy fings actually im not real good at that these days either. my poor old hands are worn out.
Don
Jorginho Forum Pro • Posts: 15,370
My GH4 was bad, never tested on Em1.2 but good point.
I think they should add this in reviews actually. When you have a zoom and bikers come towards you, it is a very handy feature. Here also Fuji not so long ago known for pretty lousy AF has suprassed mFTs it seems. Well done!
 Jorginho's gear list:Jorginho's gear list
Olympus PEN E-PL5 Panasonic Lumix DMC-GH4 Olympus E-M1 II Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G 20mm F1.7 ASPH +8 more
PistonPhotoUK
PistonPhotoUK Regular Member • Posts: 243
I only have the E-M1 mark 1 and 40-150 pro for experience, but I've not had any real issues zooming whilst maintaining CAF+TR, whilst taking a high speed burst.
Out of a burst of around 8 frames and zooming out, 2 frames will be out of focus. This will be with a total of 2 short bursts either side of zooming, whilst panning and holding the shutter half way to keep focusing. The sequence is only 6mm but I was holding focus and zooming out as they approached ahead of the jump.
Not sure if that helps in any way, but I hope it does.
 PistonPhotoUK's gear list:PistonPhotoUK's gear list
Olympus E-M1 Olympus E-M1 II Olympus Zuiko Digital 1.4x Teleconverter EC-14 Olympus M.Zuiko Digital ED 75mm F1.8 Olympus M.Zuiko Digital 17mm F1.8 +3 more
