Lens selection for Alaska
Started Aug 28, 2019 | Questions
Sadiq Majid New Member • Posts: 22
This topic is becoming a frequent one, but I have to ask my own so please excuse me. I have booked an Alaska cruise with time spent mostly on the ship and some shore excursions. I intend to travel really light and just take along my X-T3 with 16-55 for general photography and 27 as a backup, leaving behind the Zeiss Touit 12 and the Fujis 35 1.4, 56 1.2, 90 2.0 and 18-135. This is my first time in Alaska so I am unsure if I am doing right.
 Sadiq Majid's gear list:Sadiq Majid's gear list
Fujifilm X-T1 Fujifilm X-H1 Fujifilm X-T3 Canon EF 55-200mm f/4.5-5.6 II USM Fujifilm XF 35mm F1.4 R +6 more
Fujifilm X-T3
SpeedyNeo
SpeedyNeo Senior Member • Posts: 1,055
Re: Lens selection for Alaska
I understand you may not have it, but I'm imagining a 55-200 would be a nice combo with the 16-55 for times when a tele is needed during the cruise.
Fujifilm X-T3 | Fujifilm X-E3 | XF16mmF1.4 | XF35mmF1.4 | XF18-55mmF2.8-4 | Fujifilm FinePix XP140
 SpeedyNeo's gear list:SpeedyNeo's gear list
Fujifilm XP130 Fujifilm X100V Fujifilm X-T3 Fujifilm XF 35mm F1.4 R Fujifilm XF 16mm F1.4 R WR +1 more
Les Lammers
Les Lammers Veteran Member • Posts: 4,247
I'd bring the 18-135...just because.
 Les Lammers's gear list:Les Lammers's gear list
Ricoh GR Digital III Ricoh GR IIIx Fujifilm X-E1 Fujifilm X-H1 Fujifilm XF 18mm F2 R +6 more
markusw Senior Member • Posts: 1,705
Well, I love prime lenses, esp. when there is enough time (which is on such a tour, IMO). I would be fine with the 35, the 56 or 90, and something wide. But the Touit is very wide, so I would add the 14 or the 16. So, that means, 16/35/90 or 14/23/56 would be my kit.
decaf14 Regular Member • Posts: 234
I would bring the 35mm instead the the 27mm for some bokehlicious shots. It's still pretty small and has 2 more stops than the 27mm.
As others have said, you may appreciate the 55-200 as well for telephoto landscapes.
 decaf14's gear list:decaf14's gear list
Fujifilm X-T10 Fujifilm X-T3 Fujifilm XF 35mm F1.4 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8 +2 more
jrk
jrk Veteran Member • Posts: 3,401
Given you lens selection I would go with:  Zeiss 12, 16-55, and the 18-135.
We all have wings
Some of us don't know why
-INXS-
 jrk's gear list:jrk's gear list
Fujifilm FinePix X100 Fujifilm X100F Fujifilm X-T3 Voigtlander 35mm F1.4 Nokton Fujifilm XF 60mm F2.4 R Macro +14 more
Jerry-astro
MOD Jerry-astro Forum Pro • Posts: 19,920
If it were me, I'd bring along my 16-55 and Zeiss Touit 12 for wide landscapes.  If you're not into wildlife, that should get the job done.  However, you may well miss some opportunities to catch some closer in wildlife, in which case you might wish you had something a bit longer with you (the 18-135 might help, but it's realistically still pretty short for most wildlife).  If that's not a concern, then I'd stick with the two I recommended.  BTW, I own and frequently use both lenses, so I do have a fair amount of experience with them.
Jerry-Astro
Fujifilm X Forum Co-Mod
 Jerry-astro's gear list:Jerry-astro's gear list
Fujifilm 16-55mm F2.8R LM WR Fujifilm X-H2S Fujifilm XF 8-16mm F2.8 XF 150-600mm Canon Pixma Pro-100 +1 more
sixfootzero
sixfootzero Contributing Member • Posts: 674
I went on an Alaskan cruise in July 2018 (Vancouver to Seward) and took all my lenses.  I figured I could leave the big camera bag on the ship, and take my small bag on excursions or on walks around the ship, using lenses that were selected to match anticipated activities.  My widest lens is the Fuji 27mm, any my longest is a Minolta 300mm.
The Alaskan coast is famously rainy.  Oddly, we had record-breaking dry/hot weather, and didn't see a drop of rain until getting off the ship in Seward.  (Ketchikan has a giant rain gauge sculpture with a salmon mounted 150 inches high to indicate the average annual rainfall.  It's wet!)  I don't have a single moisture resistant lens, and lucked out.  You have several, and I recommend you take them.
Wildlife shooting can vary a lot.  The 300mm was handy for some things, but your 18-135 would have covered most of it.  I don't have many zooms, so whale shots were done using 50mm, 100mm and 200mm primes, with occasional frantic swaps.   A zoom would have been much more handy.  And there can be unexpected opportunities; while on a small wood bridge at a national park, a black bear walked below, and I got close up shots using the 27mm.
If you're doing an inland passage cruise, the shoreline can be pretty close to the ship in spots, and your 12mm would be helpful where the wide end of your zoom lens isn't wide enough.
Have fun!
 sixfootzero's gear list:sixfootzero's gear list
Samsung NX100 Fujifilm X-E1 Fujifilm X-H1 Samsung NX 30mm F2 Pancake Samsung NX 20-50mm F3.5-5.6 ED +4 more
OP Sadiq Majid New Member • Posts: 22
Thank you all for excellent advice and benefit of your experience. Really appreciated.
cjb
cjb Contributing Member • Posts: 575
I'd take
  • X-H1
  • 16-55 f/2.8
  • 100-400 f/4.5-5.6
Why?
  • The 16-55 for almost everything
  • The 100-400 for wildlife and shore scenes and reach when the ship can't get close enough. Fill the frame.
  • The X-H1 for lower light situations where IBIS will make a difference. (evening, indoors, northern lights, etc.)
 cjb's gear list:cjb's gear list
Fujifilm X100V Canon EOS-1Ds Mark III Canon EOS-1D Mark IV Canon EOS-1D X Canon EOS 5DS R +43 more
JimMoyer
JimMoyer Regular Member • Posts: 144
You don't say exactly how you will be traveling -- driving on your own, on a cruise, traveling with a guided group, etc.  Since you don't have a long lens in your inventory, I infer that you are not going to emphasize wildlife.
I just did two weeks in Alaska, and used the 16-55 quite a bit, but primarily shot with the 100-400.  I was, however, on a wildlife trip.  But if you are on a boat, the moose, bear, and birds you see on the shore or on an island will need long glass if you want the critters to fill your frame.  The 16-55 is a terrific all-around travel lens, although significantly bigger and heavier than a prime.
You might consider renting some long glass for the trip; then you don't have to buy.
Finally, remember it can be very wet in Alaska.  I don't recommend going out with anything except weather resistant lenses and camera bodies when I'm in an environment with rainy or windy weather.
Alaska is great; enjoy your trip
Jim Moyer
"Not all who wander are lost."
 JimMoyer's gear list:JimMoyer's gear list
Ricoh GR III Nikon Z7 Nikon Z6 II Voigtlander 35mm F1.4 Nokton Nikon Nikkor Z 24-120mm F4 S +1 more
cjb
He indicated he was taking a cruise. But all your points are worthy of consideration.
Small cruise ships will get close to shore. Large cruise ships stay out further, but have excursion craft to get into some of tight areas which can include wildlife.
FreeheelRN New Member • Posts: 2
i know this is an old thread, but my two cents for future readers. If you're trying to cover a few different focal lengths for trips, I think you need to know what you have in your pocket already. My iPhone 12 pro has an amazing camera that works great for that 20-50mm range. The HDR is better than any camera I have used (Nikon full frame and Fuji XT-3) The experience of shooting with my mirrorless and DSLR cameras is worth a mention. The short-comings of the phone are in zoom and low light. I really LOVE my Samyang (Rokinon) 12mm f/2 lens for astro and landscape. It just has a pleasing look. I also have the Fuji 10-24 f/4 lens that I use for landscapes. I flooded my 18-55 lens a few years back and haven't really missed it. The other lens I own is the 55-200 zoom for longer landscapes and some wildlife. I wish I could justify the 100-400, but right now I can't. I may get it for our Alaska cruise this summer. I'm trying to shed weight so I'm not bringing any of my Nikon gear even though we already have a full frame DSLR and a couple 80-200 f/2.8 or 300 f2.8 lenses. They just weigh too much.I guess the point is, don't overlook what's already in your pocket.
