Which is optically better at 100mm? Pentax-A 100mm VS Soligor 70-220mm VS Pentax 50-200mm @100mm
Started Aug 28, 2019 | Discussions
Massao Senior Member • Posts: 2,580
Comparison of following three lenses at 100mm and f/5.6, f/8, and f/11:
Thoughts before the comparison 😊 :
Pentax-A 100mm f/4 has not been included in any comparison so far, so about time
I included Pentax SMC DA 50-200mm because at 100mm focal length, it was a better performer than Sigma 50-500mm. I excluded Sigma 50-500mm from this comparison for the same reason. As for Soligor 70-220mm f/3.5 Macro lens, it is a good performer at 220mm (better than Sigma 50-500mm) , but horrible at 135mm . So, how does it perform at 100mm? Lets see..
Comparison:
Set-up: Out-of-camera-jpegs; Same camera on tripod; Focus confirmation via OVF; no PP; Daylight WB in all photos; hood on all lenses.
F/5.6
Soligor f/5.6
DA 50-200mm f/5.6
Pentax-A 100mm Macro f/5.6
F/8
Soligor f/8
DA 50-200mm f/8
Pentax-A 100mm Macro f/8
F/11
Soligor f/11
DA 50-200mm f/11
Pentax-A 100mm Macro f/11
Kind regards,
Massao
First camera: Canon FTB; First autofocus SLR camera: Pentax; First Nikon: F601 (N6006); First digital camera: Sony DSC-W5; First DSLR: Nikon D70; First mirrorless ICL camera: Samsung nx11
 Massao's gear list:Massao's gear list
Sony Alpha NEX-3 Pentax K-r Samsung NX300 Samsung NX1100 A3000 +40 more
KentG Veteran Member • Posts: 4,825
Re: Which is optically better at 100mm? Pentax-A 100mm VS Soligor 70-220mm VS Pentax 50-200mm @100mm
I would consider this test as valid as all three lenses are shifting the aperture and the ISO at each position.
Kent Gittings
 KentG's gear list:KentG's gear list
Pentax K-3 II Pentax K-1 Canon EOS 80D Pentax smc DA 16-45mm F4 ED AL Sigma 120-300mm F2.8 EX DG HSM +7 more
chris gunn
chris gunn Veteran Member • Posts: 9,641
The Soligar is bad. The zoom has higher contrast. The Macro is lower contrast but may be sharper at f/8+. I'm not sure but low contrast may be an advantage for macro?
cheers!
Gunn
-- Get a big lens and get closer™.
 chris gunn's gear list:chris gunn's gear list
Pentax K-1 II
OP Massao Senior Member • Posts: 2,580
chris gunn wrote:
The Soligar is bad. The zoom has higher contrast. The Macro is lower contrast ..
I agree. Soligor is horrible at this focal length. I'll try to compare both Pentax DA 50-200mm and Pentax A100mm Macro further with a different scene.
Kind regards,
Massao
Further comparison between SMC Pentax-A 100mm Macro f/4 and Pentax SMC DA 50-200mm f/4-5.6
Further comparison of following two lenses at 100mm and f/4.5, f/5.6, and f/8:
Comparison:
Set-up: Out-of-camera-jpegs; Same camera on tripod; Focus confirmation via OVF; no PP; Daylight WB in all photos; hood on all lenses; no filter on any lenses.
F/4.5
50-200mm f/4.5
Pentax-A 100mm f/4.5
F/5.6
50-200mm f/5.6
Pentax-A 100mm f/5.6
F/8
50-200mm f/8
Pentax-A 100mm f/8
Kind regards,
Massao
chris gunn
Re: Further comparison between SMC Pentax-A 100mm Macro f/4 and Pentax SMC DA 50-200mm f/4-5.6
Seems massively different here. Strange?
cheers!
Gunn
Pentax K-1 II
You mean 50-200mm's performance?
Kind regards,
Massao
chris gunn
The zoom looks OOF.
cheers!
Gunn
Pentax K-1 II
Holger Bargen Veteran Member • Posts: 4,911
My impression:
Forget about the Soligor - at least if the aperture is almost open.
The Pentax zoom is OK. On the first sight and if you don't go the 100% view the Pentax zoom looks even better than the old Pentax macro - but things change at 100% view.
I would try to underexpose the photos with the Pentax macro and go into postprocessing with the RAWs.
Look at those parts of the photos where you have wood + gras in front. For the zoom lenses both parts drwon into a soup - but the Pentax macro clearly differentiates the subjects. This is what I want to see from a good lens and even though the Pentax lens is an old one it does a good job. For a better overall look (contrast, vibrancy, etc.) postprocesing would be the way.
Best regards
Holger
 Holger Bargen's gear list:Holger Bargen's gear list
Pentax K-5 Pentax K-S1 Pentax K-1 Pentax smc DA 55-300mm F4.0-5.8 ED Sigma 70mm F2.8 EX DG Macro +7 more
chris gunn wrote:
The zoom looks OOF.
Thanks Chris; you are right! I think DA 50-200 doesn't focus properly on surfaces that are not too contrasty (like pink flowers, blue wall, or a brown lock). See here also--looks like same issue. I'll try to repeat the test by using manual focus on DA 50-200mm.
Kind regards,
Massao
Holger Bargen wrote:
My impression:
Best regards
Holger
Thanks; I agree
Kind regards,
Massao
Take 3: SMC Pentax-A 100mm Macro f/4 VS Pentax SMC DA 50-200mm
Different lighting conditions and double lens hoods. Since DA 50-200mm f/4-5.6 doesn't seem to focus accurately, I used manual focus this time.
F/4.5
DA 50-200mm f/4.5
F/5.6
DA 50-200mm f/5.6
F/8
DA 50-200mm f/8
Pentax-A 100mm f/8
Kind regards,
Massao
chris gunn
Re: Take 3: SMC Pentax-A 100mm Macro f/4 VS Pentax SMC DA 50-200mm
Still a massive difference.
cheers!
Gunn
Pentax K-1 II
