Pentax-A vs DA 50-200mm at f/4.5 and f/5.6
Started Aug 23, 2019 | Discussions
Massao Senior Member • Posts: 2,580
The idea behind this test was that DA 50-200mm lens could have improved coatings (produced in 2000’s) which may deliver better results on a DSLR; it also has an ED glass element. Previous tests and comparisons of this lens showed that it performs best at 80-150mm range. At 100mm, it was better thanSigma 50-500mm F4-6.3 APO DG (older version without OS and HSM). DA 50-200mm lens has also AF So, how does it fare against an old manual Pentax-A 135mm f/2.8 lens from 1980’s? 😊
Comparison of SMC Pentax-A 135mm f/2.8 and SMC Pentax-DA 50-200mm (at ca 135mm) at f/4.5 and f/5.6.
Same camera on tripod; out-of-camera-jpegs; no PP; no filter on lenses; hood on both lenses.
Note 1: I tested at f/4.5 as thats the lowest f-number DA 50-200mm lens allows at ca 135mm focal length.
Note 2: my copy of Pentax-A 135mm f/2.8 has some scratches on one side of the rear glass element
Pentax-A 135mm lens @f/4.5
50-200mm lens at ca 135mm @f/4.5
Pentax-A 135mm lens @f/5.6
50-200mm lens at ca 135mm @f/5.6
Kind regards,
Massao
First camera: Canon FTB; First autofocus SLR camera: Pentax; First Nikon: F601 (N6006); First digital camera: Sony DSC-W5; First DSLR: Nikon D70; First mirrorless ICL camera: Samsung nx11
 Massao's gear list:Massao's gear list
Sony Alpha NEX-3 Pentax K-r Samsung NX300 Samsung NX1100 A3000 +40 more
OP Massao Senior Member • Posts: 2,580
Re: Pentax-A vs DA 50-200mm at f/4.5 and f/5.6
Not the best of copies:-)
Kind regards,
Massao
Take 2: Pentax-A 135mm vs DA 50-200mm
Since DA 50-200mm f/4-5.6 doesn't seem to focus accurately, I used manual focus this time.
F/5.6
Pentax-A 135mm f/5.6
DA 50-200mm f/5.6
F/8
Pentax-A 135mm f/8
DA 50-200mm f/8
Kind regards,
Massao
