panasonic 25mm f1.7 tight fit on e-pm2
Started Aug 20, 2019 | Discussions
ennemkay Senior Member • Posts: 1,573
i've only ever used the kit lens, olympus 40-150, and panasonic 12-32 on my e-pm2 which all twist smoothly onto the mount. all of those have plastic mounts. i just tried a new panasonic 25/1.7 on the e-pm2 body and it was a really tight fit, however it's the first aluminum mount i've tried on the e-pm2 body. is this normal, or is that a sign of a potential defect in the lens's mount? thanks
 ennemkay's gear list:ennemkay's gear list
Olympus OM-D E-M10 Sony a6000 Olympus Zuiko Digital ED 40-150mm 1:4.0-5.6 Sony E 50mm F1.8 OSS Panasonic Lumix G 25mm F1.7 ASPH +2 more
Olympus PEN E-PM2
Lichtspiel
Lichtspiel Veteran Member • Posts: 3,528
Re: panasonic 25mm f1.7 tight fit on e-pm2
I think it is normal that some lenses fit a bit more tightly than others. Especially comparing plastic to metal lens mounts.
Have you tried applying a smidgen of nose grease to the specific areas? Sometimes works wonders!
 Lichtspiel's gear list:Lichtspiel's gear list
Sony a7C Voigtlander 15mm F4.5 Super Wide Heliar Sony FE 20mm F1.8G Tamron 70-300 F4.5-6.3 Di RXD III Samyang Reflex 300mm F6.3 +5 more
TomFid Veteran Member • Posts: 4,000
Check the face of your body's mount for corrosion - I had an EPM2 that had that problem.
OP ennemkay Senior Member • Posts: 1,573
that worked. thanks. i guess the two metals create more friction than the plastic mounts do.
