Cheaper Alternative to Westcott 1x3 Rapid Box?
FuzzyKeys Regular Member • Posts: 119
I'm interested in getting a 1x3 softbox for location portraits. I was wondering if there are any other softboxes I may not be aware of that are similarly easy to assemble and break down but cost a bit less than $240?
 FuzzyKeys's gear list:FuzzyKeys's gear list
Sony a7 III Voigtlander 15mm F4.5 Super Wide Heliar Sony FE 85mm F1.8 Samyang AF 35mm F2.8 FE Tamron 28-75mm F2.8 III +2 more
robertfel Senior Member • Posts: 1,315
Re: Cheaper Alternative to Westcott 1x3 Rapid Box?
https://www.adorama.com/dnrbtr1236.html
I have owned 2 of the 1x6 strips for ~5 years, so far, so good. It's good enough that Dynalite rebrands it for their line.
I'm sure there are a bunch of Chinese off-brands on Amazon for even less, but I can't attest to their quality/durability.
 robertfel's gear list:robertfel's gear list
Nikon D800 Nikon D850 Nikon Z6 Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 24-70mm f/2.8G ED +25 more
OP FuzzyKeys Regular Member • Posts: 119
Awesome thanks! Are they fast enough to set up and break down for street location portraits?
If you're experienced with softboxes and speedrings, yes.
If you haven't used a strip box before, practice a few times at home. Make sure you get a speedring that can handle strip boxes, the holes for the strips are usually labeled 'S' on the good speedrings. If not, use some nail polish.
The Rapid Box and Aputure's Dome have terrible assemblies, I never understood the need to depart from the simple and reliable speedring.
tugwilson Senior Member • Posts: 1,372
If you are looking for good quality, fast setup, relatively inexpensive soft boxes look at Adorama's Glow range
Sailor Blue
Sailor Blue Forum Pro • Posts: 14,762
The major uses of a strip softbox are for hair or accent lights. If that is what you want then there are lots of those available.
I have a couple of 14"x6' strip softboxes I bought for a special shoot. I have fairly heavy duty light stands but I wouldn't trust those stands with one of these softboxes in any orientation except vertical with the bottom resting on the floor. They have gathered dust since the one time I needed them.
robertfel is also right about you needing practice. The best way to assemble or disassemble rod and speedring softboxes seems to vary with every softbox.
I think you should consider this umbrella opening strip softbox. It is a bit bulkier to transport because of the built-in speedring but opening one up and closing is is much simpler than it is with a rod and speedring softbox. It is also considerably less expensive than the Westcott.
Adorama - Glow EZ Lock 10x24" Quick Strip Softbox With Bowens Mount
Living and loving it in Pattaya, Thailand. Canon 5DS R & 7D - See the gear list for the rest.
 Sailor Blue's gear list:Sailor Blue's gear list
Fujifilm FinePix Real 3D W3 Canon EOS 7D Canon EOS 5DS R Tamron SP AF 90mm F/2.8 Di Macro Tokina AT-X 16-28mm f/2.8 Pro FX +9 more
Seems like the EZ lock series are the latest and most popular? Doesn’t seem like they have a 1x3 EZ lock though.
I am familiar with speed rings from assisting in a studio, though I’m certainly not as fast with them as I could be as I usually I just set them up and then move them around indoors without needing to break them down in between setups. For my own outdoor shoots, I’m currently using 32” square and umbrella style soft boxes and some 43” umbrellas, but I am looking for something compact and efficient for outdoor location shoots. There are some photographers that I admire that use a 1x3 as a go to outdoor modifier for fill. I’ve been surprised at how effective and versatile they are.
14X48 is 1X3.4, for all practical purposes this is 1X3
Absolutely! Excellent point haha.
Mark Kitaoka has done some tests on this curved softbox. I was rather surprised by his results having dismissed it as a gimmick.
Very interesting! Thanks for the link!
RKwasi Junior Member • Posts: 38
Check out the ones CheetahStand has...
I have 2 of the large strip softboxes from CheetahStand, they also have a smaller version.
https://www.cheetahstand.com/product-p/q9x35.htm
They setup and break down real quick, pus you even get a grid with them.
